K230如何缩小摄像头捕获到的画面
Viewed 720
一般通过修改sensor的不同通道的宽高配置可以设置该通道输出图像分辨率。
    sensor = Sensor()
    # sensor reset
    # set hmirror
    # sensor.set_hmirror(False)
    # sensor vflip
    # sensor.set_vflip(False)
    # set chn0 output size, 1920x1080
    # set chn0 output format
    # bind sensor chn0 to display layer video 1
    # set chn1 output format
    sensor.set_framesize(width = 640, height = 480, chn = CAM_CHN_ID_1)
    sensor.set_pixformat(Sensor.RGB888, chn = CAM_CHN_ID_1)
    # set chn2 output format
    sensor.set_framesize(width = 640, height = 480, chn = CAM_CHN_ID_2)
    sensor.set_pixformat(Sensor.RGB565, chn = CAM_CHN_ID_2)
    # use hdmi as display output
    # init media manager
    # sensor start run
如上述代码中修改通道1的输出分辨率可以设置sensor.set_framesize(width = 640, height = 480, chn = CAM_CHN_ID_1)中的width和height属性。
