图像检测类的模型训练,如何调整判断阈值
Viewed 243
我训练了一个图像检测模型,然后他常常出现误报的情况,我想通过修改阈值调整识别的准确性
我希望了解阈值是哪几个变量,分别什么含义,能否修改。
硬件为K230。固件版本CanMV-K230_micropython_v1.0_sdk_v1.6_nncase_v2.8.3(创乐博V3.0)。
import aicube
from time import *
import utime
import random
import utime
from machine import Pin
from machine import FPIOA
DISPLAY_HEIGHT = 1080
OUT_RGB888P_WIDTH = ALIGN_UP(1080, 16)
OUT_RGB888P_HEIGH = 720
# 颜色盘
color_four = [(255, 220, 20, 60), (255, 119, 11, 32), (255, 0, 0, 142), (255, 0, 0, 230),
        (255, 0, 226, 252), (255, 182, 182, 255), (255, 0, 82, 0), (255, 120, 166, 157),
        (255, 110, 76, 0), (255, 174, 57, 255), (255, 199, 100, 0), (255, 72, 0, 118),
        (255, 255, 179, 240), (255, 0, 125, 92), (255, 209, 0, 151), (255, 188, 208, 182),
        (255, 0, 220, 176), (255, 255, 99, 164), (255, 92, 0, 73), (255, 133, 129, 255),
        (255, 78, 180, 255), (255, 0, 228, 0), (255, 174, 255, 243), (255, 45, 89, 255),
        (255, 134, 134, 103), (255, 145, 148, 174), (255, 255, 208, 186),
        (255, 197, 226, 255), (255, 171, 134, 1), (255, 109, 63, 54), (255, 207, 138, 255),
        (255, 151, 0, 95), (255, 9, 80, 61), (255, 84, 105, 51), (255, 74, 65, 105),
        (255, 166, 196, 102), (255, 208, 195, 210), (255, 255, 109, 65), (255, 0, 143, 149),
        (255, 179, 0, 194), (255, 209, 99, 106), (255, 5, 121, 0), (255, 227, 255, 205),
        (255, 147, 186, 208), (255, 153, 69, 1), (255, 3, 95, 161), (255, 163, 255, 0),
        (255, 119, 0, 170), (255, 0, 182, 199), (255, 0, 165, 120), (255, 183, 130, 88),
        (255, 95, 32, 0), (255, 130, 114, 135), (255, 110, 129, 133), (255, 166, 74, 118),
        (255, 219, 142, 185), (255, 79, 210, 114), (255, 178, 90, 62), (255, 65, 70, 15),
        (255, 127, 167, 115), (255, 59, 105, 106), (255, 142, 108, 45), (255, 196, 172, 0),
        (255, 95, 54, 80), (255, 128, 76, 255), (255, 201, 57, 1), (255, 246, 0, 122),
        (255, 191, 162, 208)]
root_path="/sdcard/app/tests/mpcode/"
config_path="/sdcard/app/tests/mpcode/deploy_config.json"
deploy_conf={}
debug_mode=1
# 实例化FPIOA
# 设置Pin2为GPIO2
fpioa.set_function(2, FPIOA.GPIO2)
# 实例化Pin2为输出
pin = Pin(2, Pin.OUT, pull=Pin.PULL_NONE, drive=7)
#pin.value(0)
class ScopedTiming:
    def __init__(self, info="", enable_profile=True):
        self.info = info
    def __enter__(self):
        if self.enable_profile:
        return self
    # 打开JSON文件以进行读取deploy_config
            # 从文件中加载JSON数据
            # 打印数据(可根据需要执行其他操作)
            #print(config)
        except ValueError as e:
            print("JSON 解析错误:", e)
    return config
def detection():
    print("det_infer start")
    # 使用json读取内容初始化部署变量
    kmodel_frame_size = img_size
    strides = [8,16,32]
    # 计算padding值
    ori_w = OUT_RGB888P_WIDTH;
    ori_h = OUT_RGB888P_HEIGH;
    width = kmodel_frame_size[0];
    height = kmodel_frame_size[1];
    ratiow = float(width) / ori_w;
    ratioh = float(height) / ori_h;
    if ratiow < ratioh:
        ratio = ratiow
        ratio = ratioh
    new_w = int(ratio * ori_w);
    new_h = int(ratio * ori_h);
    dw = float(width - new_w) / 2;
    dh = float(height - new_h) / 2;
    top = int(round(dh - 0.1));
    bottom = int(round(dh + 0.1));
    left = int(round(dw - 0.1));
    right = int(round(dw - 0.1));
    # init kpu and load kmodel
    kpu = nn.kpu()
    ai2d = nn.ai2d()
    kpu.load_kmodel("/sdcard/app/tests/mpcode/best_AnchorBaseDet_can2_10_s_20241021032100.kmodel")
                                   np.uint8, np.uint8)
    ai2d_builder = ai2d.build([1,3,OUT_RGB888P_HEIGH,OUT_RGB888P_WIDTH], [1,3,height,width])
    # 初始化并配置sensor
    sensor = Sensor(id=2)
    # 设置镜像
    sensor.set_hmirror(False)
    # 设置翻转
    sensor.set_vflip(False)
    # 通道0直接给到显示VO,格式为YUV420
    # 通道2给到AI做算法处理,格式为RGB888
    # 绑定通道0的输出到vo
    # 设置为LT9611显示,默认1920x1080
    #创建OSD图像
        # media初始化
        # 启动sensor
        rgb888p_img = None
        ai2d_input_tensor = None
        data = np.ones((1,3,width,height),dtype=np.uint8)
        while  True:
                # for rgb888planar
                    # set input
                    # run kmodel
                    kpu.run()
                    # get output
                    results = []
                        result = out_data.to_numpy()
                        del out_data
                        results.append(result)
                    # postprocess
                    elif model_type == "GFLDet":
                        det_boxes = aicube.gfldet_post_process( results[0], results[1], results[2], kmodel_frame_size, frame_size, strides, num_classes, confidence_threshold, nms_threshold, nms_option)
                        det_boxes = aicube.anchorfreedet_post_process( results[0], results[1], results[2], kmodel_frame_size, frame_size, strides, num_classes, confidence_threshold, nms_threshold, nms_option)
                    osd_img.clear()
                    if det_boxes:
                        pin.value(1)
                        for i in range(3):
                            img1=sensor.snapshot(chn=CAM_CHN_ID_2)
                           # img_np=img.to_rgb888().to_numpy_ref()
                        for det_boxe in det_boxes:
                            w = float(x2 - x1) * DISPLAY_WIDTH // OUT_RGB888P_WIDTH
                            h = float(y2 - y1) * DISPLAY_HEIGHT // OUT_RGB888P_HEIGH
                            osd_img.draw_rectangle(int(x1 * DISPLAY_WIDTH // OUT_RGB888P_WIDTH) , int(y1 * DISPLAY_HEIGHT // OUT_RGB888P_HEIGH) , int(w) , int(h) , color=color_four[det_boxe[0]][1:])
                            label = labels[det_boxe[0]]
                            osd_img.draw_string_advanced( int(x1 * DISPLAY_WIDTH // OUT_RGB888P_WIDTH) , int(y1 * DISPLAY_HEIGHT // OUT_RGB888P_HEIGH)-50,32, label + " " + score , color=color_four[det_boxe[0]][1:])
                    else :
                         pin.value(0)
                rgb888p_img = None
        print(f"An error occurred during buffer used: {e}")
        del ai2d_input_tensor
        del ai2d_output_tensor
        #停止摄像头输出
        #去初始化显示设备
        #释放媒体缓冲区
        time.sleep(1)
        nn.shrink_memory_pool()
    print("det_infer end")
    return 0
    detection()
调整阈值请修改deploy_config.json中的confidence_thresholdnms_threshold字段,两个字段分别是置信度阈值和NMS阈值。
推荐使用GPT等大语言模型或者搜索了解目标检测任务的相关知识学习如何调整阈值。
好的 谢谢 我先学习一下
