我在调用显示功能的时候,出现ValueError: cannot reshape array的报错,请问是何种错误
Viewed 487
训练模型生成video.py文件,将该文件判断有对应物体画框的位置,进行图像的存储,存储的图像640*480的bin格式,调用show.py(对应显示功能),报错。
同时偶尔video.py文件偶尔会出现卡死或者缓冲区报错的问题,但频率并不高。
解决运行报错的问题,能够存储并显示抓取到的目标图像
硬件为K230。固件版本CanMV-K230_micropython_v1.0_sdk_v1.6_nncase_v2.8.3(创乐博V3.0)。
###抓取存储
video.py的save部分仅添加此代码
osd_img.clear()
if det_boxes:
                    pin.value(1)
                    for i in range(1):
                        img1=sensor.snapshot(chn=CAM_CHN_ID_2)
                        img_np=img1.to_rgb888().to_numpy_ref()
                        with open("/sdcard/examples/output.bin", "wb") as file:
                            file.write(img_np.tobytes())
                            print('发现目标!')
这贴的代码里也没有reshape方法啊,给出完整代码
完整代码好像太长了加不进来 该怎么办
import aicube
from time import *
import utime
import random
import utime
from machine import Pin
from machine import FPIOA
#DISPLAY_HEIGHT = 1080
DISPLAY_HEIGHT = 640
OUT_RGB888P_WIDTH = ALIGN_UP(1080, 16)
#OUT_RGB888P_HEIGH = 720
OUT_RGB888P_HEIGH = 480
# 颜色盘
color_four = [(255, 220, 20, 60), (255, 119, 11, 32), (255, 0, 0, 142), (255, 0, 0, 230),
        (255, 0, 226, 252), (255, 182, 182, 255), (255, 0, 82, 0), (255, 120, 166, 157),
        (255, 110, 76, 0), (255, 174, 57, 255), (255, 199, 100, 0), (255, 72, 0, 118),
        (255, 255, 179, 240), (255, 0, 125, 92), (255, 209, 0, 151), (255, 188, 208, 182),
        (255, 0, 220, 176), (255, 255, 99, 164), (255, 92, 0, 73), (255, 133, 129, 255),
        (255, 78, 180, 255), (255, 0, 228, 0), (255, 174, 255, 243), (255, 45, 89, 255),
        (255, 134, 134, 103), (255, 145, 148, 174), (255, 255, 208, 186),
        (255, 197, 226, 255), (255, 171, 134, 1), (255, 109, 63, 54), (255, 207, 138, 255),
        (255, 151, 0, 95), (255, 9, 80, 61), (255, 84, 105, 51), (255, 74, 65, 105),
        (255, 166, 196, 102), (255, 208, 195, 210), (255, 255, 109, 65), (255, 0, 143, 149),
        (255, 179, 0, 194), (255, 209, 99, 106), (255, 5, 121, 0), (255, 227, 255, 205),
        (255, 147, 186, 208), (255, 153, 69, 1), (255, 3, 95, 161), (255, 163, 255, 0),
        (255, 119, 0, 170), (255, 0, 182, 199), (255, 0, 165, 120), (255, 183, 130, 88),
        (255, 95, 32, 0), (255, 130, 114, 135), (255, 110, 129, 133), (255, 166, 74, 118),
        (255, 219, 142, 185), (255, 79, 210, 114), (255, 178, 90, 62), (255, 65, 70, 15),
        (255, 127, 167, 115), (255, 59, 105, 106), (255, 142, 108, 45), (255, 196, 172, 0),
        (255, 95, 54, 80), (255, 128, 76, 255), (255, 201, 57, 1), (255, 246, 0, 122),
        (255, 191, 162, 208)]
root_path="/sdcard/app/tests/mpcode/"
config_path="/sdcard/app/tests/mpcode/deploy_config.json"
deploy_conf={}
debug_mode=1
# 实例化FPIOA
# 设置Pin2为GPIO2
fpioa.set_function(2, FPIOA.GPIO2)
# 实例化Pin2为输出
pin = Pin(2, Pin.OUT, pull=Pin.PULL_NONE, drive=7)
#pin.value(0)
class ScopedTiming:
    def __init__(self, info="", enable_profile=True):
        self.info = info
    def __enter__(self):
        if self.enable_profile:
        return self
    # 打开JSON文件以进行读取deploy_config
            # 从文件中加载JSON数据
            # 打印数据(可根据需要执行其他操作)
            #print(config)
        except ValueError as e:
            print("JSON 解析错误:", e)
    return config
def detection():
    print("det_infer start")
    # 使用json读取内容初始化部署变量
    kmodel_frame_size = img_size
    strides = [8,16,32]
    # 计算padding值
    ori_w = OUT_RGB888P_WIDTH;
    ori_h = OUT_RGB888P_HEIGH;
    width = kmodel_frame_size[0];
    height = kmodel_frame_size[1];
    ratiow = float(width) / ori_w;
    ratioh = float(height) / ori_h;
    if ratiow < ratioh:
        ratio = ratiow
        ratio = ratioh
    new_w = int(ratio * ori_w);
    new_h = int(ratio * ori_h);
    dw = float(width - new_w) / 2;
    dh = float(height - new_h) / 2;
    top = int(round(dh - 0.1));
    bottom = int(round(dh + 0.1));
    left = int(round(dw - 0.1));
    right = int(round(dw - 0.1));
    # init kpu and load kmodel
    kpu = nn.kpu()
    ai2d = nn.ai2d()
    kpu.load_kmodel("/sdcard/app/tests/mpcode/best_AnchorBaseDet_can2_10_s_20241021032100.kmodel")
                                   np.uint8, np.uint8)
    ai2d_builder = ai2d.build([1,3,OUT_RGB888P_HEIGH,OUT_RGB888P_WIDTH], [1,3,height,width])
    # 初始化并配置sensor
    sensor = Sensor(id=2)
    # 设置镜像
    sensor.set_hmirror(False)
    # 设置翻转
    sensor.set_vflip(False)
    # 通道0直接给到显示VO,格式为YUV420
    # 通道2给到AI做算法处理,格式为RGB888
    # 绑定通道0的输出到vo
    # 设置为LT9611显示,默认1920x1080
    #创建OSD图像
        # media初始化
        # 启动sensor
        rgb888p_img = None
        ai2d_input_tensor = None
        data = np.ones((1,3,width,height),dtype=np.uint8)
        while  True:
                # for rgb888planar
                    # set input
                    # run kmodel
                    kpu.run()
                    # get output
                    results = []
                        result = out_data.to_numpy()
                        del out_data
                        results.append(result)
                    # postprocess
                    elif model_type == "GFLDet":
                        det_boxes = aicube.gfldet_post_process( results[0], results[1], results[2], kmodel_frame_size, frame_size, strides, num_classes, confidence_threshold, nms_threshold, nms_option)
                        det_boxes = aicube.anchorfreedet_post_process( results[0], results[1], results[2], kmodel_frame_size, frame_size, strides, num_classes, confidence_threshold, nms_threshold, nms_option)
                    osd_img.clear()
                    if det_boxes:
                        pin.value(1)
                        for i in range(1):
                                print('发现目标!')
                                #62.5kbit  8k
                        for det_boxe in det_boxes:
                            w = float(x2 - x1) * DISPLAY_WIDTH // OUT_RGB888P_WIDTH
                            h = float(y2 - y1) * DISPLAY_HEIGHT // OUT_RGB888P_HEIGH
                            osd_img.draw_rectangle(int(x1 * DISPLAY_WIDTH // OUT_RGB888P_WIDTH) , int(y1 * DISPLAY_HEIGHT // OUT_RGB888P_HEIGH) , int(w) , int(h) , color=color_four[det_boxe[0]][1:])
                            label = labels[det_boxe[0]]
                            osd_img.draw_string_advanced( int(x1 * DISPLAY_WIDTH // OUT_RGB888P_WIDTH) , int(y1 * DISPLAY_HEIGHT // OUT_RGB888P_HEIGH)-50,32, label + " " + score , color=color_four[det_boxe[0]][1:])
                    else :
                         pin.value(0)
                rgb888p_img = None
        print(f"An error occurred during buffer used: {e}")
        del ai2d_input_tensor
        del ai2d_output_tensor
        #停止摄像头输出
        #去初始化显示设备
        #释放媒体缓冲区
        time.sleep(1)
        nn.shrink_memory_pool()
    print("det_infer end")
    return 0
    detection()
rgb888p_img = sensor.snapshot(chn=CAM_CHN_ID_2) 这一句代码已经snapshot一帧图像了,不用再继续用img1=sensor.snapshot(chn=CAM_CHN_ID_2)继续获取了。
建议修改代码:
for i in range(1):
        print('发现目标!')
为:
img_np=rgb888p_img.to_rgb888().to_numpy_ref()
    print('发现目标!')
这个应该是解决那个卡死或者缓冲区报错的问题,应该算是我重复调用了的问题看来。可是这样生成的那个bin文件,依旧没有办法用您之前分享的那个save/show函数进行显示,请问是我哪里配置不对吗
然后我这里那个运行就会提示一个ValueError: cannot reshape array的错误
你的代码里只有 result = result.reshape((result.shape[0]*result.shape[1]*result.shape[2]*result.shape[3])) 这里用到了reshape,查一下result的类型和shape;另外你的代码还添加了GPIO,并且修改了DISPLAY和RGB888P的分辨率(高度变了),修改的部分逐个复原,采用排除法debug。
