我在写眼镜检测例程,使用face_glasses.kmodel 模型,通不过,推理展示也不会写,麻烦给看下
Viewed 669
是从C++程序移植过来的,前后处理写的有问题,输出展示写不了
希望能正常运行眼镜检测功能
板子是创乐博K230,刷了CanMV-K230_micropython_v1.0_sdcard_v1.6_nncase_v2.8.3.img
  File "<stdin>", line 319, in <module>
  File "<stdin>", line 274, in run
  File "/sdcard/libs/AIBase.py", line 72, in run
  File "/sdcard/libs/AIBase.py", line 44, in preprocess
  File "/sdcard/libs/AI2D.py", line 77, in run
AttributeError: 'NoneType' object has no attribute 'run'
from libs.AI2D import Ai2d
from time import *
import aidemo
import random
import math
# 自定义人脸检测任务类
class FaceDetApp(AIBase):
    def __init__(self,kmodel_path,model_input_size,anchors,confidence_threshold=0.25,nms_threshold=0.3,rgb888p_size=[1920,1080],display_size=[1920,1080],debug_mode=0):
        # kmodel路径
        self.kmodel_path=kmodel_path
        # 检测模型输入分辨率
        # 置信度阈值
        # nms阈值
        self.anchors=anchors
        # sensor给到AI的图像分辨率,宽16字节对齐
        # 视频输出VO分辨率,宽16字节对齐
        # debug模式
        self.debug_mode=debug_mode
        # 实例化Ai2d,用于实现模型预处理
        self.ai2d=Ai2d(debug_mode)
        # 设置Ai2d的输入输出格式和类型
            # 计算padding参数,并设置padding预处理
            self.ai2d.pad(self.get_pad_param(), 0, [104,117,123])
            # 设置resize预处理
            # 构建预处理流程,参数为预处理输入tensor的shape和预处理输出的tensor的shape
    # 自定义后处理,results是模型输出的array列表,这里使用了aidemo库的face_det_post_process接口
            res = aidemo.face_det_post_process(self.confidence_threshold,self.nms_threshold,self.model_input_size[0],self.anchors,self.rgb888p_size,results)
            if len(res)==0:
                return res,res
                return res[0],res[1]
    # 计算padding参数
    def get_pad_param(self):
        # 计算最小的缩放比例,等比例缩放
        ratio_w = dst_w / self.rgb888p_size[0]
        ratio_h = dst_h / self.rgb888p_size[1]
        if ratio_w < ratio_h:
            ratio = ratio_w
            ratio = ratio_h
        new_w = (int)(ratio * self.rgb888p_size[0])
        new_h = (int)(ratio * self.rgb888p_size[1])
        dw = (dst_w - new_w) / 2
        dh = (dst_h - new_h) / 2
        top = (int)(round(0))
        bottom = (int)(round(dh * 2 + 0.1))
        left = (int)(round(0))
        right = (int)(round(dw * 2 - 0.1))
        return [0,0,0,0,top, bottom, left, right]
# 自定义人脸注册任务类
class  FaceGlassesApp(AIBase):
    def __init__(self,kmodel_path,model_input_size,rgb888p_size=[1920,1080],display_size=[1920,1080],debug_mode=0):
        # kmodel路径
        # 检测模型输入分辨率
        # 视频输出VO分辨率,宽16字节对齐
        # debug模式
        # 标准5官
        self.umeyama_args_112 = [
            38.2946 , 51.6963 ,
            73.5318 , 51.5014 ,
            56.0252 , 71.7366 ,
            41.5493 , 92.3655 ,
            70.7299 , 92.2041
    # 配置预处理操作,这里使用了affine,Ai2d支持crop/shift/pad/resize/affine,具体代码请打开/sdcard/app/libs/AI2D.py查看
    def config_preprocess(self,landm,input_image_size=None):
            # 计算affine矩阵,并设置仿射变换预处理
            affine_matrix = self.get_affine_matrix(landm)
            self.ai2d.affine(nn.interp_method.cv2_bilinear,0, 0, 127, 1,affine_matrix)
    # 自定义后处理
        对模型推理结果进行后处理的函数,用于判断最终的类别(如是否佩戴眼镜等情况)并返回相应结果。
        功能:
        先将模型输出张量中的数据转换为numpy数组形式,然后进行softmax操作将结果转换为概率分布形式,
        通过找到概率最大的索引来判断最终结果,并根据一定规则设置相应的标签(如"no glasses"或"wear glasses")和得分。
        返回值:
        返回一个包含结果标签和得分的字典,用于后续展示等操作。
        pred_vec = np.array(self.p_outputs[0])
        softmax_pred_vec = self.softmax(pred_vec)
        max_index = np.argmax(softmax_pred_vec)
        result = {}
        if max_index == 0 and softmax_pred_vec[max_index] > 0.75:
            result['score'] = softmax_pred_vec[0]
            result['label'] = "no glasses"
            result['score'] = 1 - softmax_pred_vec[0]
            result['label'] = "wear glasses"
        return result
    def svd22(self,a):
        实现奇异值分解(SVD)相关操作的函数,用于处理2x2矩阵的SVD计算,按照特定的数学公式进行计算。
        参数:
        - a: 输入的2x2矩阵,以一维numpy数组形式传入(在调用时会进行相应的形状处理)。
        返回值:
        返回计算得到的U、S、V矩阵,分别表示左奇异向量矩阵、奇异值向量、右奇异向量矩阵,用于后续的图像变换等操作中的矩阵运算。
        s = [0.0, 0.0]
        u = [0.0, 0.0, 0.0, 0.0]
        v = [0.0, 0.0, 0.0, 0.0]
        s[0] = (math.sqrt((a[0] - a[3]) ** 2 + (a[1] + a[2]) ** 2) + math.sqrt((a[0] + a[3]) ** 2 + (a[1] - a[2]) ** 2)) / 2
        s[1] = abs(s[0] - math.sqrt((a[0] - a[3]) ** 2 + (a[1] + a[2]) ** 2))
        v[2] = math.sin((math.atan2(2 * (a[0] * a[1] + a[2] * a[3]), a[0] ** 2 - a[1] ** 2 + a[2] ** 2 - a[3] ** 2)) / 2) if \
        s[0] > s[1] else 0
        v[0] = math.sqrt(1 - v[2] ** 2)
        v[1] = -v[2]
        v[3] = v[0]
        u[0] = -(a[0] * v[0] + a[1] * v[2]) / s[0] if s[0] != 0 else 1
        u[2] = -(a[2] * v[0] + a[3] * v[2]) / s[0] if s[0] != 0 else 0
        u[1] = (a[0] * v[1] + a[1] * v[3]) / s[1] if s[1] != 0 else -u[2]
        u[3] = (a[2] * v[1] + a[3] * v[3]) / s[1] if s[1] != 0 else u[0]
        v[0] = -v[0]
        v[2] = -v[2]
        return u, s, v
    def image_umeyama_224(self,src):
        基于umeyama算法实现图像变换相关操作的函数,用于计算仿射变换矩阵。
        参数:
        - src: 源图像相关的坐标数据(通常是一些关键点坐标等),以合适的numpy数组形式传入。
        功能:
        先计算源图像和目标图像(这里目标图像参数相关值来自`umeyama_args_224`)的均值、去中心化后的坐标等,
        接着通过计算协方差矩阵、进行奇异值分解等一系列数学操作构建仿射变换矩阵,最后进行缩放等调整得到最终的变换矩阵。
        返回值:
        返回计算得到的仿射变换矩阵(以numpy数组形式表示),用于后续对图像进行仿射变换。
        SRC_NUM = 5
        SRC_DIM = 2
        src_mean = [0.0, 0.0]
        dst_mean = [0.0, 0.0]
        for i in range(0,SRC_NUM * 2,2):
            src_mean[0] += src[i]
            src_mean[1] += src[i + 1]
            dst_mean[0] += self.umeyama_args_112[i]
            dst_mean[1] += self.umeyama_args_112[i + 1]
        src_mean[0] /= SRC_NUM
        src_mean[1] /= SRC_NUM
        dst_mean[0] /= SRC_NUM
        dst_mean[1] /= SRC_NUM
        src_demean = [[0.0, 0.0] for _ in range(SRC_NUM)]
        dst_demean = [[0.0, 0.0] for _ in range(SRC_NUM)]
        for i in range(SRC_NUM):
            src_demean[i][0] = src[2 * i] - src_mean[0]
            src_demean[i][1] = src[2 * i + 1] - src_mean[1]
            dst_demean[i][0] = self.umeyama_args_112[2 * i] - dst_mean[0]
            dst_demean[i][1] = self.umeyama_args_112[2 * i + 1] - dst_mean[1]
        A = [[0.0, 0.0], [0.0, 0.0]]
        for i in range(SRC_DIM):
            for k in range(SRC_DIM):
                for j in range(SRC_NUM):
                    A[i][k] += dst_demean[j][i] * src_demean[j][k]
                A[i][k] /= SRC_NUM
        T = [[1, 0, 0], [0, 1, 0], [0, 0, 1]]
        U, S, V = self.svd22([A[0][0], A[0][1], A[1][0], A[1][1]])
        T[0][0] = U[0] * V[0] + U[1] * V[2]
        T[0][1] = U[0] * V[1] + U[1] * V[3]
        T[1][0] = U[2] * V[0] + U[3] * V[2]
        T[1][1] = U[2] * V[1] + U[3] * V[3]
        scale = 1.0
        src_demean_mean = [0.0, 0.0]
        src_demean_var = [0.0, 0.0]
            src_demean_mean[0] += src_demean[i][0]
            src_demean_mean[1] += src_demean[i][1]
        src_demean_mean[0] /= SRC_NUM
        src_demean_mean[1] /= SRC_NUM
            src_demean_var[0] += (src_demean_mean[0] - src_demean[i][0]) * (src_demean_mean[0] - src_demean[i][0])
            src_demean_var[1] += (src_demean_mean[1] - src_demean[i][1]) * (src_demean_mean[1] - src_demean[i][1])
        src_demean_var[0] /= SRC_NUM
        src_demean_var[1] /= SRC_NUM
        scale = 1.0 / (src_demean_var[0] + src_demean_var[1]) * (S[0] + S[1])
        T[0][2] = dst_mean[0] - scale * (T[0][0] * src_mean[0] + T[0][1] * src_mean[1])
        T[1][2] = dst_mean[1] - scale * (T[1][0] * src_mean[0] + T[1][1] * src_mean[1])
        T[0][0] *= scale
        T[0][1] *= scale
        T[1][0] *= scale
        T[1][1] *= scale
        return T
    def get_affine_matrix(self,sparse_points):
        # 获取affine变换矩阵
        with ScopedTiming("get_affine_matrix", self.debug_mode > 1):
            # 使用Umeyama算法计算仿射变换矩阵
            matrix_dst = self.image_umeyama_224(sparse_points)
            matrix_dst = [matrix_dst[0][0],matrix_dst[0][1],matrix_dst[0][2],
                          matrix_dst[1][0],matrix_dst[1][1],matrix_dst[1][2]]
            return matrix_dst
# 人脸眼镜检测任务类
class FaceGlasses:
    def __init__(self,face_det_kmodel,face_glasses_kmodel,det_input_size,face_glasses_input_size,anchors,confidence_threshold=0.25,nms_threshold=0.3,rgb888p_size=[1280,720],display_size=[1920,1080],debug_mode=0):
        # 人脸检测模型路径
        self.face_det_kmodel=face_det_kmodel
        # 人脸姿态模型路径
        self.face_glasses_kmodel=face_glasses_kmodel
        # 人脸检测模型输入分辨率
        self.det_input_size=det_input_size
        # 人脸姿态模型输入分辨率
        self.face_glasses_input_size= face_glasses_input_size
        # anchors
        # 置信度阈值
        # nms阈值
        # 视频输出VO分辨率,宽16字节对齐
        # debug_mode模式
        self.face_det=FaceDetApp(self.face_det_kmodel,model_input_size=self.det_input_size,anchors=self.anchors,confidence_threshold=self.confidence_threshold,nms_threshold=self.nms_threshold,rgb888p_size=self.rgb888p_size,display_size=self.display_size,debug_mode=0)
        self.face_glasses=FaceGlassesApp(self.face_glasses_kmodel,model_input_size=self.face_glasses_input_size,rgb888p_size=self.rgb888p_size,display_size=self.display_size)
    # run函数
    def run(self,input_np):
        # 执行人脸检测
        det_boxes,landms=self.face_det.run(input_np)
        glasses_res=[]
        for landm in landms:
            # 针对每个人脸五官点,推理得到人脸眼镜
            self.face_glasses.config_preprocess(landm)
            label,score=self.face_glasses.run(input_np)
            glasses_res.append((label,score))
    display_mode="hdmi"
    # k230保持不变,k230d可调整为[640,360]
    rgb888p_size = [1920, 1080]
    if display_mode=="hdmi":
        display_size=[800,480]
    # 人脸检测模型路径
    face_det_kmodel_path="/sdcard/examples/kmodel/face_detection_320.kmodel"
    # 人脸识别模型路径
    face_glasses_kmodel_path="/sdcard/examples/kmodel/face_glasses.kmodel"
    # 其它参数
    anchors_path="/sdcard/examples/utils/prior_data_320.bin"
    face_det_input_size=[320,320]
    face_glasses_input_size=[320,320]
    confidence_threshold=0.75
    nms_threshold=0.2
    anchor_len=4200
    det_dim=4
    anchors = anchors.reshape((anchor_len,det_dim))
    # 初始化PipeLine,只关注传给AI的图像分辨率,显示的分辨率
    fr=FaceGlasses(face_det_kmodel_path,face_glasses_kmodel_path,det_input_size=face_det_input_size,face_glasses_input_size=face_glasses_input_size,anchors=anchors,confidence_threshold=confidence_threshold,nms_threshold=nms_threshold,rgb888p_size=rgb888p_size,display_size=display_size)
                img=pl.get_frame()                      # 获取当前帧
                det_boxes,recg_res=fr.run(img)          # 推理当前帧
                #fr.draw_result(pl,det_boxes,recg_res)   # 绘制推理结果
                pl.show_image()                         # 展示推理效果
        fr.face_det.deinit()
        fr.face_glasses.deinit()
这个代码无法运行有两个原因:
(1)你的face_det没有配置预处理,需要增加self.face_det.config_preprocess()
(2)run方法没有写返回值,增加return det_boxes,glasses_res
按照如下代码进行修改:
class FaceGlasses:
        # 人脸检测模型路径
        # 人脸姿态模型路径
        # 人脸检测模型输入分辨率
        # 人脸姿态模型输入分辨率
        # anchors
        # 置信度阈值
        # nms阈值
        # 视频输出VO分辨率,宽16字节对齐
        # debug_mode模式
    # run函数
        # 执行人脸检测
        glasses_res=[]
戴眼镜的后处理部分还不对,需要你自行调试修改
