k230_sdk 编译的镜像 启动报错 01studio
Viewed 1190
按照文档操作:https://developer.canaan-creative.com/k230/zh/dev/01_software/board/K230_SDK_%E4%BD%BF%E7%94%A8%E8%AF%B4%E6%98%8E.html#id12
配置完sdk编译环境,编译01studio板子的系统镜像
整个过程完全按照文档操作,仅修改编译的配置(make CONF=k230_canmv_01studio_defconfig)
将编译的镜像烧写到sd卡后,启动报错。
sdk为git上最新版本
硬件;01studio CanMV K230
小核中断打印内容:
U-Boot SPL 2022.10 (Dec 17 2024 - 17:51:45 +0800)
U-Boot 2022.10 (Dec 17 2024 - 17:51:45 +0800)
CPU: rv64imafdcvsu
Model: kendryte k230 canmv 01studio
DRAM: 1 GiB
Core: 21 devices, 12 uclasses, devicetree: embed
MMC: mmc0@91580000: 0
Loading Environment from MMC... GUID Partition Table Entry Array CRC is wrong: 0x267284b5 != 0xab54d286
find_valid_gpt: *** ERROR: Invalid GPT ***
find_valid_gpt: *** Using Backup GPT ***
OK
In: serial@91400000
Out: serial@91400000
Err: serial@91400000
Net: No ethernet found.
OpenSBI v0.9
[ 0.000000] Linux version 5.10.4 (root@155cd8f21a13) (riscv64-unknown-linux-gnu-gcc (Xuantie-900 linux-5.10.4 glibc gcc Toolchain V2.6.0 B-20220715) 10.2.0, GNU ld (GNU Binutils) 2.35) #3 SMP Tue Dec 17 17:49:34 CST 2024
[ 0.000000] earlycon: sbi0 at I/O port 0x0 (options '')
[ 0.000000] printk: bootconsole [sbi0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] Initial ramdisk at: 0x(ptrval) (22515712 bytes)
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000008200000-0x000000000fffefff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000008200000-0x000000000fffefff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000008200000-0x000000000fffefff]
[ 0.000000] On node 0 totalpages: 32255
[ 0.000000] DMA32 zone: 441 pages used for memmap
[ 0.000000] DMA32 zone: 0 pages reserved
[ 0.000000] DMA32 zone: 32255 pages, LIFO batch:7
[ 0.000000] SBI specification v0.3 detected
[ 0.000000] SBI implementation ID=0x1 Version=0x9
[ 0.000000] SBI v0.2 TIME extension detected
[ 0.000000] SBI v0.2 IPI extension detected
[ 0.000000] SBI v0.2 RFENCE extension detected
[ 0.000000] SBI v0.2 HSM extension detected
[ 0.000000] riscv: ISA extensions acdefhimtv
[ 0.000000] riscv: ELF capabilities acdfimv
[ 0.000000] percpu: Embedded 25 pages/cpu s65112 r8192 d29096 u102400
[ 0.000000] pcpu-alloc: s65112 r8192 d29096 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 31814
[ 0.000000] Kernel command line: root=/dev/mmcblk0p3 loglevel=8 rw rootdelay=4 rootfstype=ext4 console=ttyS0,115200 crashkernel=256M-:128M earlycon=sbi
[ 0.000000] Dentry cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.000000] Sorting __ex_table...
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 83556K/129020K available (9648K kernel code, 4365K rwdata, 4096K rodata, 267K init, 396K bss, 45464K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] riscv-intc: 64 local interrupts mapped
[ 0.000000] plic: interrupt-controller@f00000000: mapped 200 interrupts with 1 handlers for 2 contexts.
[ 0.000000] random: get_random_bytes called from start_kernel+0x388/0x4fe with crng_init=0
[ 0.000000] riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [0]
[ 0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x63a1e71a3, max_idle_ns: 440795203123 ns
[ 0.000006] sched_clock: 64 bits at 27MHz, resolution 37ns, wraps every 4398046511093ns
[ 0.008550] Console: colour dummy device 80x25
[ 0.012976] Calibrating delay loop (skipped), value calculated using timer frequency.. 54.00 BogoMIPS (lpj=108000)
[ 0.023346] pid_max: default: 32768 minimum: 301
[ 0.028165] Mount-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.035332] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.044447] ASID allocator initialised with 65536 entries
[ 0.049970] rcu: Hierarchical SRCU implementation.
[ 0.055040] EFI services will not be available.
[ 0.059686] smp: Bringing up secondary CPUs ...
[ 0.064168] smp: Brought up 1 node, 1 CPU
[ 0.068651] devtmpfs: initialized
[ 0.091208] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.100920] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[ 0.108246] NET: Registered protocol family 16
[ 0.113038] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
[ 0.120087] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.128506] thermal_sys: Registered thermal governor 'step_wise'
[ 0.323677] [K230_RESET]:sysctl reset phy addr 0x91101000
[ 0.329648] [K230_RESET]:k230_reset_probe ok!
[ 0.397275] k230-powerdomain 91103000.sysctl_power: powerdomain init ok
[ 0.408810] SCSI subsystem initialized
[ 0.412771] usbcore: registered new interface driver usbfs
[ 0.418269] usbcore: registered new interface driver hub
[ 0.423626] usbcore: registered new device driver usb
[ 0.428812] mc: Linux media interface: v0.10
[ 0.433084] videodev: Linux video capture interface: v2.00
[ 0.439364] Canaan Hard Lock Driver init.
[ 0.445098] clocksource: Switched to clocksource riscv_clocksource
[ 1.403954] NET: Registered protocol family 2
[ 1.408921] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 1.417274] TCP established hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 1.424954] TCP bind hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 1.432167] TCP: Hash tables configured (established 1024 bind 1024)
[ 1.438664] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 1.445195] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 1.452371] NET: Registered protocol family 1
[ 1.457459] RPC: Registered named UNIX socket transport module.
[ 1.463355] RPC: Registered udp transport module.
[ 1.468095] RPC: Registered tcp transport module.
[ 1.472862] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.480507] Unpacking initramfs...
[ 1.483905] Initramfs unpacking failed: invalid magic at start of compressed archive
[ 1.499751] Freeing initrd memory: 21984K
[ 1.504803] Initialise system trusted keyrings
[ 1.509471] workingset: timestamp_bits=62 max_order=15 bucket_order=0
[ 1.524099] NFS: Registering the id_resolver key type
[ 1.529162] Key type id_resolver registered
[ 1.533361] Key type id_legacy registered
[ 1.537559] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.544242] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.548982] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 1.555763] fuse: init (API version 7.32)
[ 1.560163] 9p: Installing v9fs 9p2000 file system support
[ 1.566021] NET: Registered protocol family 38
[ 1.570431] Key type asymmetric registered
[ 1.574567] Asymmetric key parser 'x509' registered
[ 1.579564] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 1.586988] io scheduler mq-deadline registered
[ 1.591577] io scheduler kyber registered
[ 1.597312] k230-gpio 9140b000.gpio22: request hardlock 0 success!
[ 1.603698] gpio gpiochip0: (9140b000.gpio22): added GPIO chardev (254:0)
[ 1.610543] gpio gpiochip0: registered GPIOs 22 to 22 on 9140b000.gpio22
[ 1.617655] gpio gpiochip1: (9140b000.gpio23): added GPIO chardev (254:1)
[ 1.624509] gpio gpiochip1: registered GPIOs 23 to 23 on 9140b000.gpio23
[ 1.631629] gpio gpiochip2: (9140b000.gpio27): added GPIO chardev (254:2)
[ 1.638489] gpio gpiochip2: registered GPIOs 27 to 27 on 9140b000.gpio27
[ 1.645549] gpio gpiochip3: (9140c000.gpio33): added GPIO chardev (254:3)
[ 1.652406] gpio gpiochip3: registered GPIOs 33 to 33 on 9140c000.gpio33
[ 1.659473] gpio gpiochip4: (9140c000.gpio34): added GPIO chardev (254:4)
[ 1.666327] gpio gpiochip4: registered GPIOs 34 to 34 on 9140c000.gpio34
[ 1.769470] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 1.777836] printk: console [ttyS0] disabled
[ 1.782086] dw-apb-uart 91400000.serial: GPIO lookup for consumer rs485-term
[ 1.789115] dw-apb-uart 91400000.serial: using device tree for GPIO lookup
[ 1.796044] of_get_named_gpiod_flags: can't parse 'rs485-term-gpios' property of node '/soc/serial@91400000[0]'
[ 1.806150] of_get_named_gpiod_flags: can't parse 'rs485-term-gpio' property of node '/soc/serial@91400000[0]'
[ 1.816159] dw-apb-uart 91400000.serial: using lookup tables for GPIO lookup
[ 1.859050] printk: console [ttyS0] enabled0x91400000 (irq = 1, base_baud = 3125000) is a 16550A
[ 1.867345] printk: bootconsole [sbi0] disabled
[ 1.879989] k230-rng 91213000.trng: K230 TRNG driver register!
[ 1.887374] canaan-mipi-dsi 90850000.dsi: Attached device hx8399
[ 1.895290] canaan-drm soc:display-subsystem: bound 90840000.vo (ops 0xffffffe000cea970)
[ 1.903471] canaan-drm soc:display-subsystem: bound 90850000.dsi (ops 0xffffffe000ceb020)
[ 1.912380] [drm] Initialized canaan-drm 1.0.0 20230501 for soc:display-subsystem on minor 0
[ 1.926578] canaan-drm soc:display-subsystem: [drm] fb0: canaan-drmdrmfb frame buffer device
[ 1.935112] canaan-drm soc:display-subsystem: [drm:canaan_drm_bind] Canaan K230 DRM driver register successfully
[ 1.954757] loop: module loaded
[ 1.959940] mdio_bus fixed-0: GPIO lookup for consumer reset
[ 1.965677] mdio_bus fixed-0: using lookup tables for GPIO lookup
[ 1.971802] mdio_bus fixed-0: No GPIO consumer reset found
[ 1.977329] libphy: Fixed MDIO Bus: probed
[ 1.981968] usbcore: registered new interface driver catc
[ 1.987481] usbcore: registered new interface driver kaweth
[ 1.993084] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 2.000539] usbcore: registered new interface driver pegasus
[ 2.006269] usbcore: registered new interface driver rtl8150
[ 2.011998] usbcore: registered new interface driver r8152
[ 2.017552] usbcore: registered new interface driver lan78xx
[ 2.023287] usbcore: registered new interface driver asix
[ 2.028748] usbcore: registered new interface driver ax88179_178a
[ 2.034907] usbcore: registered new interface driver cdc_ether
[ 2.040796] usbcore: registered new interface driver net1080
[ 2.046520] usbcore: registered new interface driver cdc_subset
[ 2.052507] usbcore: registered new interface driver zaurus
[ 2.058163] usbcore: registered new interface driver cdc_ncm
[ 2.189152] dwc2 91500000.usb-otg: EPs: 7, dedicated fifos, 3016 entries in SPRAM
[ 2.196984] dwc2 91500000.usb-otg: DWC OTG Controller
[ 2.202130] dwc2 91500000.usb-otg: new USB bus registered, assigned bus number 1
[ 2.209582] dwc2 91500000.usb-otg: irq 15, io mem 0x91500000
[ 2.215477] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 2.223786] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.231025] usb usb1: Product: DWC OTG Controller
[ 2.235746] usb usb1: Manufacturer: Linux 5.10.4 dwc2_hsotg
[ 2.241333] usb usb1: SerialNumber: 91500000.usb-otg
[ 2.246989] hub 1-0:1.0: USB hub found
[ 2.250877] hub 1-0:1.0: 1 port detected
[ 2.273200] dwc2 91540000.usb-otg: DWC OTG Controller
[ 2.278322] dwc2 91540000.usb-otg: new USB bus registered, assigned bus number 2
[ 2.285783] dwc2 91540000.usb-otg: irq 16, io mem 0x91540000
[ 2.291693] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 2.299995] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.307242] usb usb2: Product: DWC OTG Controller
[ 2.311958] usb usb2: Manufacturer: Linux 5.10.4 dwc2_hsotg
[ 2.317545] usb usb2: SerialNumber: 91540000.usb-otg
[ 2.323196] hub 2-0:1.0: USB hub found
[ 2.327074] hub 2-0:1.0: 1 port detected
[ 2.333295] usbcore: registered new interface driver usb-storage
[ 2.340191] i2c /dev entries driver
[ 2.345490] canaan_thermal 91107000.tsensor: request hardlock 2 success!
[ 2.379460] sdhci: Secure Digital Host Controller Interface driver
[ 2.385730] sdhci: Copyright(c) Pierre Ossman
[ 2.390104] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.397012] sdhci-dwcmshc-kendryte 91580000.sdhci0: GPIO lookup for consumer cd
[ 2.404407] sdhci-dwcmshc-kendryte 91580000.sdhci0: using device tree for GPIO lookup
[ 2.412285] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/soc/sdhci0@91580000[0]'
[ 2.421719] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/soc/sdhci0@91580000[0]'
[ 2.431047] sdhci-dwcmshc-kendryte 91580000.sdhci0: using lookup tables for GPIO lookup
[ 2.439090] sdhci-dwcmshc-kendryte 91580000.sdhci0: No GPIO consumer cd found
[ 2.446248] sdhci-dwcmshc-kendryte 91580000.sdhci0: GPIO lookup for consumer wp
[ 2.453576] sdhci-dwcmshc-kendryte 91580000.sdhci0: using device tree for GPIO lookup
[ 2.461436] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/soc/sdhci0@91580000[0]'
[ 2.470863] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/soc/sdhci0@91580000[0]'
[ 2.480188] sdhci-dwcmshc-kendryte 91580000.sdhci0: using lookup tables for GPIO lookup
[ 2.488210] sdhci-dwcmshc-kendryte 91580000.sdhci0: No GPIO consumer wp found
[ 2.496008] sdhci-dwcmshc-kendryte 91581000.sdhci1: GPIO lookup for consumer cd
[ 2.503380] sdhci-dwcmshc-kendryte 91581000.sdhci1: using device tree for GPIO lookup
[ 2.511257] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/soc/sdhci1@91581000[0]'
[ 2.520689] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/soc/sdhci1@91581000[0]'
[ 2.530020] sdhci-dwcmshc-kendryte 91581000.sdhci1: using lookup tables for GPIO lookup
[ 2.538044] sdhci-dwcmshc-kendryte 91581000.sdhci1: No GPIO consumer cd found
[ 2.545198] sdhci-dwcmshc-kendryte 91581000.sdhci1: GPIO lookup for consumer wp
[ 2.552521] sdhci-dwcmshc-kendryte 91581000.sdhci1: using device tree for GPIO lookup
[ 2.560379] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/soc/sdhci1@91581000[0]'
[ 2.569806] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/soc/sdhci1@91581000[0]'
[ 2.579131] sdhci-dwcmshc-kendryte 91581000.sdhci1: using lookup tables for GPIO lookup
[ 2.587152] sdhci-dwcmshc-kendryte 91581000.sdhci1: No GPIO consumer wp found
[ 2.594548] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.601180] Kendryte crypto driver probe!
[ 2.605256] kendryte-crypto 91210200.aes: request hardlock 7 success!
[ 2.612280] usbcore: registered new interface driver usbhid
[ 2.617936] usbhid: USB HID core driver
[ 2.623418] [perf] T-HEAD C900 PMU probed
[ 2.629007] kendryte_otp 91213500.otp: GPIO lookup for consumer wp
[ 2.635283] kendryte_otp 91213500.otp: using device tree for GPIO lookup
[ 2.642032] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/soc/security/otp@91213500[0]'
[ 2.651987] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/soc/security/otp@91213500[0]'
[ 2.661841] kendryte_otp 91213500.otp: using lookup tables for GPIO lookup
[ 2.668736] kendryte_otp 91213500.otp: No GPIO consumer wp found
[ 2.675840] NET: Registered protocol family 10
[ 2.681593] Segment Routing with IPv6
[ 2.685438] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.692116] NET: Registered protocol family 17
[ 2.696849] 9pnet: Installing 9P2000 support
[ 2.701271] Key type dns_resolver registered
[ 2.705790] Loading compiled-in X.509 certificates
[ 2.727184] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio_keys/key1[0]' - status (0)
[ 2.736783] gpio gpiochip3: (9140c000.gpio33): allocate IRQ 26, hwirq 0
[ 2.743437] gpio gpiochip3: (9140c000.gpio33): found parent hwirq 65
[ 2.749817] gpio gpiochip3: (9140c000.gpio33): alloc_irqs_parent for 26 parent hwirq 65
[ 2.757937] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio_keys/key2[0]' - status (0)
[ 2.767431] gpio gpiochip2: (9140b000.gpio27): allocate IRQ 27, hwirq 0
[ 2.774082] gpio gpiochip2: (9140b000.gpio27): found parent hwirq 59
[ 2.780456] gpio gpiochip2: (9140b000.gpio27): alloc_irqs_parent for 27 parent hwirq 59
[ 2.788710] input: gpio_keys as /devices/platform/gpio_keys/input/input0
[ 2.797288] Waiting 4 sec before mounting root device...
[ 2.809116] mmc0: SDHCI controller on 91580000.sdhci0 [91580000.sdhci0] using ADMA
[ 2.816901] mmc1: SDHCI controller on 91581000.sdhci1 [91581000.sdhci1] using ADMA
[ 2.837812] sdhci-dwcmshc-kendryte 91581000.sdhci1: card claims to support voltages below defined range
[ 2.857599] mmc1: new high speed SDIO card at address 0001
[ 2.865454] random: fast init done
[ 2.886039] mmc0: new high speed SDHC card at address 0001
[ 2.893412] mmcblk0: mmc0:0001 SD 29.1 GiB
[ 6.949301] VFS: Cannot open root device "mmcblk0p3" or unknown-block(179,3): error -6
[ 6.957290] Please append a correct "root=" boot option; here are the available partitions:
[ 6.965686] b300 30533632 mmcblk0
[ 6.965693] driver: mmcblk
[ 6.972518] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,3)
[ 6.980963] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.10.4 #3
[ 6.986885] Call Trace:
[ 6.989349] [] walk_stackframe+0x0/0xaa
[ 6.994756] [] show_stack+0x32/0x3e
[ 6.999812] [] dump_stack+0x76/0x90
[ 7.004869] [] panic+0xfc/0x2b2
[ 7.009578] [] mount_block_root+0x1b6/0x24e
[ 7.015328] [] mount_root+0x100/0x12a
[ 7.020556] [] prepare_namespace+0x136/0x16c
[ 7.026392] [] kernel_init_freeable+0x1b2/0x1ce
[ 7.032490] [] kernel_init+0x12/0x100
[ 7.037721] [] ret_from_exception+0x0/0xc
[ 7.043305] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,3) ]---
大核启动过程打印内容:
OpenSBI v0.9
vicap_mcm_initRT-SMART Hello RISC-V.
msh />mirror mirror is 0 , sepress 'q' to exit application!!
nsor tpye is 39
ov5647_power_rest OV5647_CAM_PIN_CSI2 is 62
[D/lt9611] vtotal 1125 vactive 220 htotal_sys 400
<0>[6] [vi] wait stop timeout
[tuning] dev: 0
acq_win.width: 1920
acq_win.height: 1080
pipe_ctrl: 4261412857
sensor_fd: 11
sensor_type: 39
sensor_name: ov5647_csi2
database_name: ov5647-1920x1080
buffer_num: 0
buffer_size: 0
[tuning] chn: 0
out_win.width: 1920
out_win.height: 1080
bit_width: 0
pix_format: 5
buffer_num: 10
buffer_size: 3110912
yraw_size: 0
uv_size: 0
v_size: 0
block_type: 1
wait_time: 500
chn_enable: 1
ov5647_sensor_power_on, iic read chip id err
kd_mpi_sensor_power_set, error(-1)
kd_mpi_sensor_init, error(1)
kd_mpi_isp_sensor_init, sensor open failed(1)
kd_mpi_isp_sensor_set_test_pattern failed(12)!
kd_mpi_isp_connect, vsi connect failed(13)!
kd_mpi_isp_init, isp connect failed.
kd_mpi_vicap_init, isp init failed.
sample_vicap, kd_mpi_vicap_init failed.
<3>[4] [Func]:vb_is_blk_valid [Line]:1133 [Info]:id 0, phys_addr = 0, pool_phys_addr = 100ec000, pool_size = 15554560
感谢提供的思路,经过测试确实是烧录工具的问题。分别使用两个版本(4.2和4.6)的rufus进行烧录,烧录前还对SD卡进行格式化,结果还是报错。后来换成balenaEtcher工具烧录镜像成功了。
balenaEtcher工具烧录镜像成功,但是取下卡,用读卡器拷贝app到文件夹内,再插上板子,问题又复现了.怎么解决?
拔下tf卡前,先把tf从电脑上删除硬件
请问你烧写的镜像是哪个
也有可能是读卡器的问题,用我同学电脑上自带的读卡器就正常,我自己买的读卡器刷写就是你的情况
