我想使用yolov8例程识别图像并通过按键保存识别的结果图像,我该如何将图像恢复到800*480的大小并将在图像上绘制识别的矩形框并保存?????
Viewed 368
from machine import Pin, Timer
from machine import FPIOA
import base64
from libs.AI2D import Ai2d
from time import *
import utime
import random
import aidemo
import io
# 自定义YOLOv8检测类
        self.kmodel_path=kmodel_path
        self.labels=labels
        # 模型输入分辨率
        # 阈值设置
        # sensor给到AI的图像分辨率
        # 显示分辨率
        self.debug_mode=debug_mode
        # 检测框预置颜色值
        self.color_four=[(255, 220, 20, 60), (255, 119, 11, 32), (255, 0, 0, 142), (255, 0, 0, 230),
                         (255, 0, 226, 252), (255, 182, 182, 255), (255, 0, 82, 0), (255, 120, 166, 157)]
        # 宽高缩放比例
        # Ai2d实例,用于实现模型预处理
        self.ai2d=Ai2d(debug_mode)
        # 设置Ai2d的输入输出格式和类型
    # 配置预处理操作,这里使用了resize,Ai2d支持crop/shift/pad/resize/affine,具体代码请打开/sdcard/libs/AI2D.py查看
    # 自定义当前任务的后处理
            result=results[0]
            result = result.reshape((result.shape[0] * result.shape[1], result.shape[2]))
            output_data = result.transpose()
            boxes_ori = output_data[:,0:4]
            scores_ori = output_data[:,4:]
            confs_ori = np.max(scores_ori,axis=-1)
            inds_ori = np.argmax(scores_ori,axis=-1)
            boxes,scores,inds = [],[],[]
            for i in range(len(boxes_ori)):
                if confs_ori[i] > self.confidence_threshold:
                    scores.append(confs_ori[i])
                    inds.append(inds_ori[i])
                    x = boxes_ori[i,0]
                    y = boxes_ori[i,1]
                    w = boxes_ori[i,2]
                    h = boxes_ori[i,3]
                    left = int((x - 0.5 * w) * self.x_factor)
                    top = int((y - 0.5 * h) * self.y_factor)
                    right = int((x + 0.5 * w) * self.x_factor)
                    bottom = int((y + 0.5 * h) * self.y_factor)
                    boxes.append([left,top,right,bottom])
            if len(boxes)==0:
                return []
            boxes = np.array(boxes)
            scores = np.array(scores)
            inds = np.array(inds)
            # NMS过程
            keep = self.nms(boxes,scores,self.nms_threshold)
            dets = np.concatenate((boxes, scores.reshape((len(boxes),1)), inds.reshape((len(boxes),1))), axis=1)
            dets_out = []
            for keep_i in keep:
                dets_out.append(dets[keep_i])
            dets_out = np.array(dets_out)
            dets_out = dets_out[:self.max_boxes_num, :]
            return dets_out
    # 绘制结果
    def draw_result(self,pl,dets):
            if dets:
                pl.osd_img.clear()
                for det in dets:
                    x= x1*self.display_size[0] // self.rgb888p_size[0]
                    y= y1*self.display_size[1] // self.rgb888p_size[1]
                    w = (x2 - x1) * self.display_size[0] // self.rgb888p_size[0]
                    h = (y2 - y1) * self.display_size[1] // self.rgb888p_size[1]
                    pl.osd_img.draw_rectangle(x,y, w, h, color=self.get_color(int(det[5])),thickness=4)
                    pl.osd_img.draw_string_advanced( x , y-50,32," " + self.labels[int(det[5])] + " " + str(round(det[4],2)) , color=self.get_color(int(det[5])))
                pl.osd_img.clear()
    # 多目标检测 非最大值抑制方法实现
    def nms(self,boxes,scores,thresh):
        x1,y1,x2,y2 = boxes[:, 0],boxes[:, 1],boxes[:, 2],boxes[:, 3]
        keep = []
        while order.size > 0:
            i = order[0]
            keep.append(i)
            new_x1,new_y1,new_x2,new_y2,new_areas = [],[],[],[],[]
            for order_i in order:
                new_x1.append(x1[order_i])
                new_x2.append(x2[order_i])
                new_y1.append(y1[order_i])
                new_y2.append(y2[order_i])
            new_x1 = np.array(new_x1)
            new_x2 = np.array(new_x2)
            new_y1 = np.array(new_y1)
            new_y2 = np.array(new_y2)
            inter = w * h
            new_order = []
                if ind < thresh:
        return keep
    # 根据当前类别索引获取框的颜色
    def get_color(self, x):
        idx=x%len(self.color_four)
        return self.color_four[idx]
#将GPIO52、GPIO21配置为普通GPIO模式
fpioa.set_function(21,FPIOA.GPIO21)
KEY=Pin(21,Pin.IN,Pin.PULL_UP) #构建KEY对象
def save_img(img, chn):
    if img.format() == image.YUV420:
        suffix = "yuv420sp"
    elif img.format() == image.RGB888:
        suffix = "rgb888"
    elif img.format() == image.RGBP888:
        suffix = "rgb888p"
        suffix = "unkown"
    filename = f"/sdcard/camera_chn_{chn:02d}_{img.width()}x{img.height()}.{suffix}"
    print("save capture image to file:", filename)
    img.save(filename)
     display_mode="lcd"
     if display_mode=="hdmi":
         display_size=[800,480]
     # 模型路径
     kmodel_path="/sdcard/examples/kmodel/yolov8n_320.kmodel"
     # 其它参数设置
     confidence_threshold = 0.2
     nms_threshold = 0.2
     max_boxes_num = 50
     rgb888p_size=[320,320]
     # 初始化PipeLine
     # 初始化自定义目标检测实例
     ob_det=ObjectDetectionApp(kmodel_path,labels=labels,model_input_size=[320,320],max_boxes_num=max_boxes_num,confidence_threshold=confidence_threshold,nms_threshold=nms_threshold,rgb888p_size=rgb888p_size,display_size=display_size,debug_mode=0)
     ob_det.config_preprocess()
        img = pl.get_frame() # 获取当前帧数据
        res=ob_det.run(img) # 推理当前帧
        ob_det.draw_result(pl,res) # 绘制结果到PipeLine的osd图像
        print(res)  # 打印当前结果
        pl.show_image() # 显示当前的绘制结果
        if KEY.value()==0:   #按键被按下
            time.sleep_ms(10) #消除抖动
            if KEY.value()==0: #确认按键被按下
                shape=img.shape
                img_tmp = img.reshape((shape[0], shape[1]*shape[2]))
                img_trans = img_tmp.transpose()
                img_hwc = img_trans.copy().reshape((shape[1],shape[2],shape[0]))
                img_new = image.Image(shape[2], shape[1], image.RGB888, alloc=image.ALLOC_REF,data =img_hwc)
                img_565=img_new.to_rgb565()
                img_565.save("/data/test.jpg")
                while not KEY.value(): #检测按键是否松开
                    pass
试一下这样:
shape=img.shape
for det in dets:
    x= x1
    y= y1
    w = (x2 - x1)
    h = (y2 - y1)
    img_new.draw_rectangle(x,y, w, h, color=ob_det.get_color(int(det[5])),thickness=4)
    img_new.draw_string_advanced( x , y-50,32," " + ob_det.labels[int(det[5])] + " " + str(round(det[4],2)) , color=ob_det.get_color(int(det[5])))
img_565.save("/sdcard/test.jpg")
太专业了,可以了
