创乐博k230 V3.0 大核人脸识别程序无法自启动
Viewed 308
之前烧录双系统镜像后大核能够正常自启动人脸识别程序,然后后面再重新上电尝试的时候就无法启动了。
创乐博k230 V3.0
OpenSBI v0.9
vicap_mcm_initRT-SMART Hello RISC-V.
msh />mirror mirror is 0 , senpress 'q' to exit application!!
sor tpye is 39
ov5647_power_rest OV5647_CAM_PIN_CSI2 is 21
[tuning] dev: 0
acq_win.width: 1920
acq_win.height: 1080
pipe_ctrl: 4261412857
sensor_fd: 11
sensor_type: 39
sensor_name: ov5647_csi2
database_name: ov5647-1920x1080
buffer_num: 0
buffer_size: 0
[tuning] chn: 0
out_win.width: 1920
out_win.height: 1080
bit_width: 0
pix_format: 5
buffer_num: 10
buffer_size: 3110912
yraw_size: 0
uv_size: 0
v_size: 0
block_type: 1
wait_time: 500
chn_enable: 1
[D/lt9611] vtotal 1125 vactive 1080 htotal_sys 400
ov5647_sensor_power_on, iic read chip id err
kd_mpi_sensor_power_set, error(-1)
kd_mpi_sensor_init, error(1)
kd_mpi_isp_sensor_init, sensor open failed(1)
kd_mpi_isp_sensor_set_test_pattern failed(12)!
kd_mpi_isp_connect, vsi connect failed(13)!
kd_mpi_isp_init, isp connect failed.
kd_mpi_vicap_init, isp init failed.
sample_vicap, kd_mpi_vicap_init failed.
<3>[4] [Func]:vb_is_blk_valid [Line]:1133 [Info]:id 0, phys_addr = 0, pool_phys_addr = 100ec000, pool_size = 15554560
尝试过重新烧录镜像,还是没用。
你好,看日志是摄像头通信有问题,请检查硬件连接。
重新插拔摄像头的接口后解决,感谢!
