如何使用MicroPython同时运行两个AI应用
Viewed 845
方案一:双线程,双OSD层,分别运行单独的程序,因为KPU不支持并行,所以需要在推理的时候加锁同步,这里给出示例代码:
from libs.PipeLine import PipeLine,ScopedTiming
from libs.AI2D import Ai2d
from time import *
import aidemo
import time, os, sys, gc
import lvgl as lv
from machine import TOUCH
from machine import RTC
import _thread
sensor = None
rgb888p_size=[1280,720]
display_size = [800, 480]
face_det_stop=False
yolo_det_stop=False
face_osd_img=None
yolo_osd_img=None
lock = _thread.allocate_lock()
# 自定义YOLOv8检测类
        self.kmodel_path=kmodel_path
        self.labels=labels
        self.debug_mode=debug_mode
        self.color_four=get_colors(len(self.labels))
        self.ai2d=Ai2d(debug_mode)
    # 配置预处理操作,这里使用了resize,Ai2d支持crop/shift/pad/resize/affine,具体代码请打开/sdcard/app/libs/AI2D.py查看
            top,bottom,left,right,self.scale=letterbox_pad_param(self.rgb888p_size,self.model_input_size)
            new_result=results[0][0].transpose()
            det_res = aidemo.yolov8_det_postprocess(new_result.copy(),[self.rgb888p_size[1],self.rgb888p_size[0]],[self.model_input_size[1],self.model_input_size[0]],[self.display_size[1],self.display_size[0]],len(self.labels),self.confidence_threshold,self.nms_threshold,self.max_boxes_num)
            return det_res
    def draw_result(self,osd_img,dets):
            osd_img.clear()
            if dets:
                for i in range(len(dets[0])):
                    x, y, w, h = map(lambda x: int(round(x, 0)), dets[0][i])
                    osd_img.draw_rectangle(x,y, w, h, color=self.color_four[dets[1][i]],thickness=4)
                    osd_img.draw_string_advanced(x, y-50,32," " + self.labels[dets[1][i]] + " " + str(round(dets[2][i],2)) , color=self.color_four[dets[1][i]])
# 自定义人脸检测类,继承自AIBase基类
        super().__init__(kmodel_path, model_input_size, rgb888p_size, debug_mode)  # 调用基类的构造函数
        self.kmodel_path = kmodel_path  # 模型文件路径
        self.model_input_size = model_input_size  # 模型输入分辨率
        self.confidence_threshold = confidence_threshold  # 置信度阈值
        self.nms_threshold = nms_threshold  # NMS(非极大值抑制)阈值
        self.anchors = anchors  # 锚点数据,用于目标检测
        self.rgb888p_size = [ALIGN_UP(rgb888p_size[0], 16), rgb888p_size[1]]  # sensor给到AI的图像分辨率,并对宽度进行16的对齐
        self.display_size = [ALIGN_UP(display_size[0], 16), display_size[1]]  # 显示分辨率,并对宽度进行16的对齐
        self.debug_mode = debug_mode  # 是否开启调试模式
        self.ai2d = Ai2d(debug_mode)  # 实例化Ai2d,用于实现模型预处理
        self.ai2d.set_ai2d_dtype(nn.ai2d_format.NCHW_FMT, nn.ai2d_format.NCHW_FMT, np.uint8, np.uint8)  # 设置Ai2d的输入输出格式和类型
        with ScopedTiming("set preprocess config", self.debug_mode > 0):  # 计时器,如果debug_mode大于0则开启
            ai2d_input_size = input_image_size if input_image_size else self.rgb888p_size  # 初始化ai2d预处理配置,默认为sensor给到AI的尺寸,可以通过设置input_image_size自行修改输入尺寸
            top, bottom, left, right,_ = letterbox_pad_param(self.rgb888p_size,self.model_input_size)
            self.ai2d.pad([0, 0, 0, 0, top, bottom, left, right], 0, [104, 117, 123])  # 填充边缘
            self.ai2d.resize(nn.interp_method.tf_bilinear, nn.interp_mode.half_pixel)  # 缩放图像
            self.ai2d.build([1,3,ai2d_input_size[1],ai2d_input_size[0]],[1,3,self.model_input_size[1],self.model_input_size[0]])  # 构建预处理流程
    # 自定义当前任务的后处理,results是模型输出array列表,这里使用了aidemo库的face_det_post_process接口
            if len(post_ret) == 0:
                return post_ret
                return post_ret[0]
    # 绘制检测结果到画面上
    def draw_result(self, osd_img, dets):
            osd_img.clear()
            if dets:
                for det in dets:
                    # 将检测框的坐标转换为显示分辨率下的坐标
                    osd_img.draw_rectangle(x, y, w, h, color=(255, 255, 0, 255), thickness=2)
def face_det_thread():
    global sensor,osd_img,rgb888p_size,display_size,face_osd_img
    # 设置模型路径和其他参数
    # 其它参数
    confidence_threshold = 0.5
    nms_threshold = 0.2
    anchor_len = 4200
    det_dim = 4
    face_det.config_preprocess()  # 配置预处理
        if face_det_stop:
        img_2 = sensor.snapshot(chn = CAM_CHN_ID_2)
        img_np =img_2.to_numpy_ref()
        with lock:
            res = face_det.run(img_np)         # 推理当前帧
        face_det.draw_result(face_osd_img, res)   # 绘制结果
        Display.show_image(face_osd_img, 0, 0, Display.LAYER_OSD2)
    face_det.deinit()
def yolov8_det_thread():
    global sensor,osd_img,rgb888p_size,display_size,yolo_osd_img
    kmodel_path="/sdcard/examples/kmodel/yolov8n_224.kmodel"
    confidence_threshold = 0.3
    nms_threshold = 0.4
    ob_det=ObjectDetectionApp(kmodel_path,labels=labels,model_input_size=[224,224],max_boxes_num=50,confidence_threshold=confidence_threshold,nms_threshold=nms_threshold,rgb888p_size=rgb888p_size,display_size=display_size,debug_mode=0)
    ob_det.config_preprocess()
        if yolo_det_stop:
        with lock:
            det_res = ob_det.run(img_np)
        ob_det.draw_result(yolo_osd_img, det_res)
        Display.show_image(yolo_osd_img, 0, 0, Display.LAYER_OSD1)
    ob_det.deinit()
def media_init():
    global sensor,osd_img,rgb888p_size,display_size,face_osd_img,yolo_osd_img
    Display.init(Display.ST7701, width = DISPLAY_WIDTH, height = DISPLAY_HEIGHT, to_ide = True, osd_num=3)
    sensor = Sensor(fps=30)
    sensor.set_framesize(w = 800, h = 480,chn=CAM_CHN_ID_0)
    sensor.set_framesize(w = rgb888p_size[0], h = rgb888p_size[1], chn=CAM_CHN_ID_2)
    sensor.set_pixformat(Sensor.RGBP888, chn=CAM_CHN_ID_2)
    face_osd_img = image.Image(display_size[0], display_size[1], image.ARGB8888)
    yolo_osd_img = image.Image(display_size[0], display_size[1], image.ARGB8888)
def media_deinit():
    global sensor
    time.sleep_ms(50)
    media_init()
    _thread.start_new_thread(yolov8_det_thread,())
    _thread.start_new_thread(face_det_thread,())
            time.sleep_ms(50)
        yolo_det_stop=True
        face_det_stop=True
    media_deinit()
方案二:使用一个线程,一个OSD层,串行运行两个应用,并将结果绘制在同一层,缺点是如果某一个应用后处理耗时长,会影响另一个应用的运行时间,代码如下:
from time import *
import aidemo
import lvgl as lv
import _thread
sensor = None
osd_img=None
# 自定义YOLOv8检测类
        self.labels=labels
            return det_res
            if dets:
                return post_ret
                return post_ret[0]
    # 绘制检测结果到画面上
            if dets:
                for det in dets:
def media_init():
def media_deinit():
    global sensor
    time.sleep_ms(50)
    media_init()
    # 设置模型路径和其他参数
    face_kmodel_path = "/sdcard/examples/kmodel/face_detection_320.kmodel"
    # 其它参数
    face_confidence_threshold = 0.5
    face_nms_threshold = 0.2
    anchor_len = 4200
    det_dim = 4
    face_det = FaceDetectionApp(face_kmodel_path, model_input_size=[320, 320], anchors=anchors, confidence_threshold=face_confidence_threshold, nms_threshold=face_nms_threshold, rgb888p_size=rgb888p_size, display_size=display_size, debug_mode=0)
    yolo_kmodel_path="/sdcard/examples/kmodel/yolov8n_224.kmodel"
    yolo_labels = ["person", "bicycle", "car", "motorcycle", "airplane", "bus", "train", "truck", "boat", "traffic light", "fire hydrant", "stop sign", "parking meter", "bench", "bird", "cat", "dog", "horse", "sheep", "cow", "elephant", "bear", "zebra", "giraffe", "backpack", "umbrella", "handbag", "tie", "suitcase", "frisbee", "skis", "snowboard", "sports ball", "kite", "baseball bat", "baseball glove", "skateboard", "surfboard", "tennis racket", "bottle", "wine glass", "cup", "fork", "knife", "spoon", "bowl", "banana", "apple", "sandwich", "orange", "broccoli", "carrot", "hot dog", "pizza", "donut", "cake", "chair", "couch", "potted plant", "bed", "dining table", "toilet", "tv", "laptop", "mouse", "remote", "keyboard", "cell phone", "microwave", "oven", "toaster", "sink", "refrigerator", "book", "clock", "vase", "scissors", "teddy bear", "hair drier", "toothbrush"]
    yolo_confidence_threshold = 0.3
    yolo_nms_threshold = 0.4
    yolo_det=ObjectDetectionApp(yolo_kmodel_path,labels=yolo_labels,model_input_size=[224,224],max_boxes_num=50,confidence_threshold=yolo_confidence_threshold,nms_threshold=yolo_nms_threshold,rgb888p_size=rgb888p_size,display_size=display_size,debug_mode=0)
    yolo_det.config_preprocess()
        face_res = face_det.run(img_np)         # 推理当前帧
        yolo_res = yolo_det.run(img_np)
        osd_img.clear()
        face_det.draw_result(osd_img, face_res)   # 绘制结果
        yolo_det.draw_result(osd_img, yolo_res)
        Display.show_image(osd_img, 0, 0, Display.LAYER_OSD2)
    face_det.deinit()
    yolo_det.deinit()
    media_deinit()
