yolo返回的res:array([[419.0, 40.0, 928.0, 579.0, 0.9150529, 0.0]],这个坐标是基于历程代码中哪一个帧图片尺寸得到的
Viewed 174
from libs.YOLO import YOLOv5
import os,sys,gc
if name=="main":
display_mode="hdmi"
rgb888p_size=[1280,720]
if display_mode=="hdmi":
display_size=[1920,1080]
display_size=[800,480]
labels = ["apple","banana","orange"]
confidence_threshold = 0.8
nms_threshold=0.45
model_input_size=[320,320]
# 初始化PipeLine
# 初始化YOLOv5实例
yolo=YOLOv5(task_type="detect",mode="video",kmodel_path=kmodel_path,labels=labels,rgb888p_size=rgb888p_size,model_input_size=model_input_size,display_size=display_size,conf_thresh=confidence_threshold,nms_thresh=nms_threshold,max_boxes_num=50,debug_mode=0)
yolo.config_preprocess()
with ScopedTiming("total",1):
# 逐帧推理
img=pl.get_frame()
res=yolo.run(img)
pl.show_image()
yolo.deinit()
你好,是基于原图的。也就是rgb888p_size
