Implementing a Custom warpAffine Function for MicroPython in CanMV and Addressing K230 v1.1 Hardware Stuck Issues with Aligned/Non-Aligned Face Code.
Viewed 176
Hey CanMV Community,
I’m new to hardware programming and currently working on face detection using the K230 (hardware v1.1) with CanMV Micropython. Below are the functions I’ve added for post-processing to improve the shape of detected faces. However, I’m facing performance issues when using them.
Steps to Reproduce
  1. Set up a face detection pipeline on the K230 with CanMV Micropython, using a YuNet model for detection.
  2. Add the following functions (see code below) to post-process and align detected faces based on eye landmarks.
  3. Run the pipeline with rgb888p_size = [1920, 1080] and display_size = [1920, 1080] on an HDMI display, processing live video frame by frame.
  4. Observe the system behavior during continuous face detection.
Expected Results and Actual Results
  • Expected Results: Smooth live face detection at a reasonable frame rate (e.g., 10-15 FPS) with properly aligned faces for further processing (e.g., recognition).
  • Actual Results: When using these alignment functions, the K230 lags significantly, often freezing or stuttering during live detection. Without these functions, detection runs smoother (around 10-12 FPS), with occasional minor stutters (once per hour), but it’s much less laggy compared to when the alignment code is included.
Software and Hardware Version Information
  • Hardware: K230 development board, version 1.1.
  • Software: CanMV Micropython (latest version as of March 17, 2025), YuNet model (k230_face_detection_yunet.kmodel).
Error Log
  • No specific error messages appear in the console.
  • The system slows down or freezes intermittently when the alignment functions are active, especially during live frame processing. Timing logs (e.g., via ScopedTiming) aren’t captured yet, but the lag is visually noticeable.
Solution Attempts
  • Removed the alignment code: Detection runs smoothly without align_img_wrt_eyes and related functions, though minor stutters still occur occasionally (once per hour).
  • Adjusted resolution: Tested with rgb888p_size = [640, 320], which reduces lag but compromises detection accuracy, so I reverted to 1920x1080.
  • Considered optimization: Thought about simplifying the M = np.array transformation or offloading it to hardware, but I’m unsure how to proceed with the K230’s capabilities.
Supplementary Materials
Here are the functions I’m using to post-process and align faces after detection:
def align_img_wrt_eyes(img, left_eye, right_eye):
    if not left_eye or not right_eye:
        return img, 0
    angle = float(np.degrees(np.arctan2(left_eye[1] - right_eye[1], left_eye[0] - right_eye[0])))
    # Handle NCHW format (C, H, W)
    if len(img.shape) == 3 and img.shape[0] == 3:  # NCHW
        channels, h, w = img.shape
    elif len(img.shape) == 3 and img.shape[2] == 3:  # NHWC
        h, w, channels = img.shape
    elif len(img.shape) == 2:  # Grayscale
        h, w = img.shape
        channels = 1
        raise ValueError("Unsupported image shape: {}".format(img.shape))
    center = (w // 2, h // 2)
    cos_val = np.cos(np.radians(angle))
    sin_val = np.sin(np.radians(angle))
    M = np.array([
        [cos_val, sin_val, (1 - cos_val) * center[0] - sin_val * center[1]],
        [-sin_val, cos_val, sin_val * center[0] + (1 - cos_val) * center[1]]
    ], dtype=np.float)
    # Process based on input format
        aligned_img = np.zeros((channels, h, w), dtype=np.uint8)
        for i in range(h):
            for j in range(w):
                src_x = int(M[0, 0] * j + M[0, 1] * i + M[0, 2])
                src_y = int(M[1, 0] * j + M[1, 1] * i + M[1, 2])
                if 0 <= src_x < w and 0 <= src_y < h:
                    for k in range(channels):
                        aligned_img[k, i, j] = img[k, src_y, src_x]
        aligned_img = np.zeros((h, w, channels), dtype=np.uint8)
        for i in range(h):
            for j in range(w):
                        aligned_img[i, j, k] = img[src_y, src_x, k]
        aligned_img = np.zeros((h, w), dtype=np.uint8)
        for i in range(h):
            for j in range(w):
                    aligned_img[i, j] = img[src_y, src_x]
    return aligned_img, angle
def project_facial_area(facial_area, angle, size):
    # Rotate the four corners of the bounding box
    x1, y1, x2, y2 = facial_area
    h, w = size
    def rotate_point(x, y):
        x -= center[0]
        y -= center[1]
        new_x = x * cos_val + y * sin_val + center[0]
        new_y = -x * sin_val + y * cos_val + center[1]
        return new_x, new_y
    rx1, ry1 = rotate_point(x1, y1)
    rx2, ry2 = rotate_point(x2, y2)
    return min(rx1, rx2), min(ry1, ry2), max(rx1, rx2), max(ry1, ry2)
def expand_and_align_face(img, x, y, w, h, landmarks, align=True, expand_percentage=0):
    left_eye = (landmarks[0], landmarks[1]) if len(landmarks) >= 2 else None
    right_eye = (landmarks[2], landmarks[3]) if len(landmarks) >= 4 else None
    if expand_percentage > 0:
        expanded_w = w + int(w * expand_percentage / 100)
        expanded_h = h + int(h * expand_percentage / 100)
        x = max(0, x - int((expanded_w - w) / 2))
        y = max(0, y - int((expanded_h - h) / 2))
        w = min(img.shape[1] - x, expanded_w)
        h = min(img.shape[0] - y, expanded_h)
    # Ensure valid dimensions
    if w <= 0 or h <= 0:
        return {"x": x, "y": y, "w": 0, "h": 0, "left_eye": None, "right_eye": None,
                "nose": None, "mouth_left": None, "mouth_right": None}, None
    detected_face = img[y:y+h, x:x+w]
    if align and left_eye and right_eye:
        aligned_face, angle = align_img_wrt_eyes(detected_face, left_eye, right_eye)
        rotated_x1, rotated_y1, rotated_x2, rotated_y2 = project_facial_area((0, 0, w, h), angle, (h, w))
        cropped_face = aligned_face[int(rotated_y1):int(rotated_y2), int(rotated_x1):int(rotated_x2)]
        cropped_face = detected_face
        angle = 0
    facial_area = {
        "x": x, "y": y, "w": w, "h": h,
        "left_eye": left_eye, "right_eye": right_eye,
        "nose": (landmarks[4], landmarks[5]) if len(landmarks) >= 6 else None,
        "mouth_left": (landmarks[6], landmarks[7]) if len(landmarks) >= 8 else None,
        "mouth_right": (landmarks[8], landmarks[9]) if len(landmarks) >= 10 else None
    return facial_area, cropped_face
Dear user, regarding the issue you mentioned, I think it can be considered for solution from the following aspects:
(1) You can use the provided YUNet face detection model example. The post-processing interface of this model is implemented in Cpp, which improves the efficiency of face detection. The code can be found in CanMV/sdcard/examples/05-AI-Demo/face_detect_yunet.py in the PreRelease image.
(2) You can optimize the code for the alignment part. Find the time-consuming part through debugging and make special optimizations for that part. It should be noted that the efficiency of micropython is poor, and it may not achieve good results.
(3) Implement the code for the alignment part in Cpp and encapsulate it into an interface for micropython to use. For the method of interface definition, please refer to: canmv_k230/src/canmv/port/include/ai_demo/aidemo_wrap.h. For the interface implementation part, please refer to the Cpp files under canmv_k230/src/canmv/port/ai_demo. For the code of the interface encapsulation part, please refer to the file canmv_k230/src/canmv/port/ai_demo/ai_demo.c. Its principle is to define the interface of the micropython ai_demo module in ai_demo.c, define the API of Cpp in the aidemo_wrap.h, and implement the defined API in the ai_demo/***.cpp file.
