编译RT-Smart的UART例程出现错误
Viewed 363
编译RT-Smart工程下的helloworld例程成功后,直接修改的hellworld例程下的main.c代码内容,改为RT-Smart文档的UART例程,编译后出现错误,请问还要修改哪些文件,或者有什么解决方法吗
这是例程代码:
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
#include <sys/mman.h>
#include <pthread.h>
#include <fcntl.h>
#include <rtthread.h>
#include <rtdevice.h>
#include <poll.h>
#define IOC_SET_BAUDRATE            _IOW('U', 0x40, int)
struct uart_configure
    rt_uint32_t baud_rate;
    rt_uint32_t data_bits               :4;
    rt_uint32_t stop_bits               :2;
    rt_uint32_t parity                  :2;
    rt_uint32_t fifo_lenth              :2;
    rt_uint32_t auto_flow               :1;
    rt_uint32_t reserved                :21;
typedef enum _uart_parity
    UART_PARITY_NONE,
    UART_PARITY_ODD,
    UART_PARITY_EVEN
} uart_parity_t;
typedef enum _uart_receive_trigger
    UART_RECEIVE_FIFO_1,
    UART_RECEIVE_FIFO_8,
    UART_RECEIVE_FIFO_16,
    UART_RECEIVE_FIFO_30,
} uart_receive_trigger_t;
#define SEND_START_STR "uart test start !\n"
int main(int argc,char *argv[])
    int fd;
    int ret = 0;
    fd = open("/dev/uart3", O_RDWR); //打开串口
    if (fd < 0){
        printf("open dev  failed!\n");
        return 1;
    struct uart_configure config = {
        .baud_rate = 9600,
        .data_bits = 8,
        .stop_bits = 1,
        .parity = UART_PARITY_NONE,
        .fifo_lenth = UART_RECEIVE_FIFO_16,
        .auto_flow = 0,
    if (ioctl(fd, IOC_SET_BAUDRATE, &config)) { //设置参数为9600
        printf("ioctl failed!\n");
        close(fd);
        return 1;
    write(fd, SEND_START_STR, strlen(SEND_START_STR)); //发送字符串口
    while(1) {
        fd_set rfds;
        int retval;
        FD_ZERO(&rfds);
        FD_SET(fd, &rfds); // 监视标准输入流
        retval = select(fd+1, &rfds, NULL, NULL, NULL);  //等待数据
        if (retval < 0) {
            printf("select failed");
            break;
        if(FD_ISSET(fd, &rfds)){
            char buf[256];
            memset(buf, 0, sizeof(buf));
            ret = read(fd, buf, sizeof(buf)); //读取串口数据
            printf("ret =%x read :%s\n",ret, buf);
            if(strchr(buf,'q'))
                break;
    close(fd);//关闭串口
    return 0;
直接编译,出现如下错误:
[CC] main.c
In file included from /home/kaif/work/k230_rtos/src/rtsmart/rtsmart/userapps/sdk/rt-thread/include/rtlibc.h:21,
                 from /home/kaif/work/k230_rtos/src/rtsmart/rtsmart/userapps/sdk/rt-thread/include/rtdef.h:1130,
                 from /home/kaif/work/k230_rtos/src/rtsmart/rtsmart/userapps/sdk/rt-thread/include/rtthread.h:24,
                 from main.c:8:
/home/kaif/work/k230_rtos/src/rtsmart/rtsmart/userapps/sdk/rt-thread/include/libc/libc_signal.h:31:7: error: redefinition of 'union sigval'
   31 | union sigval
In file included from /home/kaif/work/k230_rtos/src/rtsmart/rtsmart/userapps/sdk/rt-thread/include/libc/libc_signal.h:23:
/root/.kendryte/k230_toolchains/riscv64-linux-musleabi_for_x86_64-pc-linux-gnu/riscv64-unknown-linux-musl/include/signal.h:92:7: note: originally defined here
   92 | union sigval {
/home/kaif/work/k230_rtos/src/rtsmart/rtsmart/userapps/sdk/rt-thread/include/libc/libc_signal.h:39:8: error: redefinition of 'struct sigevent'
   39 | struct sigevent
/root/.kendryte/k230_toolchains/riscv64-linux-musleabi_for_x86_64-pc-linux-gnu/riscv64-unknown-linux-musl/include/signal.h:179:8: note: originally defined here
  179 | struct sigevent {
/home/kaif/work/k230_rtos/src/rtsmart/rtsmart/userapps/sdk/rt-thread/include/libc/libc_signal.h:56:18: error: expected ':', ',', ';', '}' or '__attribute__' before '.' token
   56 |     union sigval si_value;
/home/kaif/work/k230_rtos/src/rtsmart/rtsmart/userapps/sdk/rt-thread/include/libc/libc_signal.h:58:24: error: conflicting types for 'siginfo_t'; have 'struct siginfo'
   58 | typedef struct siginfo siginfo_t;
/root/.kendryte/k230_toolchains/riscv64-linux-musleabi_for_x86_64-pc-linux-gnu/riscv64-unknown-linux-musl/include/signal.h:145:3: note: previous declaration of 'siginfo_t' with type 'siginfo_t'
  145 | } siginfo_t;
make: *** [Makefile:74:/home/kaif/work/k230_rtos/output/k230d_canmv_bpi_zero_defconfig/applications/helloworld//main.o] 错误 1
请问,如何解决这个报错
