Custom Image for Micropython
Viewed 245
As, I am new to SDKs and linux as well, till here i was running with canMV-k230-V1.1 with just downloaded img file from canna download center and burn it to sd card and using it.
Now, I want to make my custom img file for board, so as per https://developer.canaan-creative.com/k230_canmv/en/main/userguide/how_to_build.html suggest i have gone through link and suceesfullt generate img file in output folder, but that image is mainly blank even when i burn imag to sd card, canMV IDE can not connect to board as well with generated img.
My main purpose is
  1. Generate workable img file like cannan pre-built imgs for v0v1 board
  2. To generate and understand whole aspects of k230 mainly with both cores and RAM memory
Can you please give me details steps how can i do this?
Thank you so much.
can you upload the compile log, which is generated by make log
https://github.com/urvi-ai/log in this link log.txt contains log
It seems everything is ok, can you upload the image?
I have updated files in same link
