k230怎么使用两个摄像头进行yolo识别
Viewed 329
给一个双摄显示的demo,你自己改一下:
# Camera Example
import time, os, sys
sensor2 = None
sensor1=None
    print("camera_test")
    sensor2 = Sensor(id=2)
    # sensor reset
    sensor2.reset()
    # set hmirror
    # sensor.set_hmirror(False)
    # sensor vflip
    # sensor.set_vflip(False)
    # set chn0 output size
    sensor2.set_framesize(width = 400, height = 240, chn = CAM_CHN_ID_0)
    # set chn0 output format
    sensor2.set_pixformat(Sensor.RGB565, chn = CAM_CHN_ID_0)
    # set chn1 output format
    sensor2.set_framesize(width=400,height=240, chn = CAM_CHN_ID_1)
    sensor2.set_pixformat(Sensor.RGB888, chn = CAM_CHN_ID_1)
    # 构建 Sensor 对象 sensor1
    sensor1 = Sensor(id=1)
    sensor1.reset()
    # 设置通道 0 分辨率为 960x540
    sensor1.set_framesize(width=400, height=240, chn = CAM_CHN_ID_0)
    # 设置通道 0 格式为 YUV420
    sensor1.set_pixformat(Sensor.RGB565, chn = CAM_CHN_ID_0)
    sensor1.set_framesize(width=400,height=240,chn = CAM_CHN_ID_1)
    sensor1.set_pixformat(Sensor.RGB565, chn = CAM_CHN_ID_1)
    # use hdmi as display output
    Display.init(Display.ST7701, to_ide = True, osd_num = 2)
    # init media manager
    # sensor start run
    sensor1.run()
        img1 = sensor1.snapshot(chn = CAM_CHN_ID_0)
        Display.show_image(img1, x=0,y=0, layer = Display.LAYER_OSD0)
        img2 = sensor2.snapshot(chn = CAM_CHN_ID_0)
        Display.show_image(img2, x=400,y=240, layer = Display.LAYER_OSD1)
    print("user stop: ", e)
    print(f"Exception {e}")
    sensor1.stop()
    sensor2.stop()
    # deinit display
    # release media buffer
