cancollectorplus_onboard执行main.elf 报错
Viewed 276
按照教程,将解压缩包移动到sharefs文件夹后,小核执行连接成功,但是大核执行main.elf报错。
2
msh /sharefs/cancollectorplus_onboard>./main.elf 1
期待实时采集数据,在PC客户端展示摄像头画面。
实际报错:
01studio开发板 K230
镜像:官网的CanMV-K230_01studio_sdcard_v1.7_nncase_v2.9.0.img.gz
case ./main.elf built at Mar 4 2024 13:57:54
datafifo_init finish
sample_vicap ...
<3>[4] [Func]:vb_set_config [Line]:1243 [Info]:VB is initialized!
vb_set_config failed ret:-1610317806
dump dev(0)chn(1) failed.
sample_vicap...kd_mpi_vicap_dump_frame failed.
read capture took 1006.69 ms
total time took 1009.3 ms
@@Wy001
@Wy001
@Wy001 快来解决一下,能否提供main.elf源码?
你用的是双系统吗
