PipeLine初始化和PyAudio初始化冲突
Viewed 244
from libs.YOLO import YOLOv8
import os,sys,gc
from media.media import *   #导入media模块,用于初始化vb buffer
from media.pyaudio import * #导入pyaudio模块,用于采集和播放音频
import media.wave as wave   #导入wav模块,用于保存和加载wav音频文件
def exit_check():
        print("user stop: ", e)
        return True
    return False
def play_audio(filename):
        wf = wave.open(filename, 'rb')#打开wav文件
        CHUNK = int(wf.get_framerate()/25)#设置音频chunk值
        p = PyAudio()
        p.initialize(CHUNK) #初始化PyAudio对象
        MediaManager.init()    #vb buffer初始化
        #创建音频输出流,设置的音频参数均为wave中获取到的参数
        stream = p.open(format=p.get_format_from_width(wf.get_sampwidth()),
                    channels=wf.get_channels(),
                    rate=wf.get_framerate(),
                    output=True,frames_per_buffer=CHUNK)
        #设置音频输出流的音量
        stream.volume(vol=85)
        data = wf.read_frames(CHUNK)#从wav文件中读取数一帧数据
        while data:
            stream.write(data)  #将帧数据写入到音频输出流中
            data = wf.read_frames(CHUNK) #从wav文件中读取数一帧数据
            if exit_check():
            print(f"Exception {e}")
        stream.stop_stream() #停止音频输出流
        stream.close()#关闭音频输出流
        p.terminate()#释放音频对象
        wf.close()#关闭wav文件
        MediaManager.deinit() #释放vb buffer
    display_mode="hdmi"
    rgb888p_size=[1280,720]
    if display_mode=="hdmi":
        display_size=[1920,1080]
        display_size=[800,480]
    labels = ["Harmful","Kitchen","Other","Recyclable"]
    confidence_threshold = 0.8
    model_input_size=[224,224]
    # 初始化PipeLine
    # 初始化YOLOv8实例
    yolo=YOLOv8(task_type="classify",mode="video",kmodel_path=kmodel_path,labels=labels,rgb888p_size=rgb888p_size,model_input_size=model_input_size,display_size=display_size,conf_thresh=confidence_threshold,debug_mode=0)
    yolo.config_preprocess()
            with ScopedTiming("total",1):
                # 逐帧推理
                img=pl.get_frame()
                res=yolo.run(img)
                print(res[0])
                if res[0]==0:
                    play_audio('/sdcard/examples/harmful.wav')
                elif res[0]==1:
                    play_audio('/sdcard/examples/kitchen.wav')
                elif res[0]==2:
                    play_audio('/sdcard/examples/other.wav')
                elif res[0]==3:
                    play_audio('/sdcard/examples/recyclable.wav')
                pl.show_image()
        yolo.deinit()
报错
Exception please run MediaManager._config() before MediaManager.init()
