K230如何取得图像上一块区域的灰度平均值。
Viewed 113
我希望获取到图像上一块区域的灰度值。
K230
参考如下代码:
import time, os, gc, sys
DETECT_WIDTH = ALIGN_UP(800, 16)
DETECT_HEIGHT = 480
sensor = None
sensor = Sensor(width=DETECT_WIDTH,height=DETECT_HEIGHT)
# sensor reset
# set chn0 output size
sensor.set_framesize(width=DETECT_WIDTH,height=DETECT_HEIGHT)
# set chn0 output format
# use IDE as display output
Display.init(Display.VIRT, width= DETECT_WIDTH, height = DETECT_HEIGHT,to_ide = True)
# init media manager
# sensor start run
    st=img.get_statistics(roi=(10,10,200,200))
    print(st.mean())
# sensor stop run
# deinit display
# sleep
# release media buffer
