使用yolov5转为kmodel之后,运行MicroPython报错误:IndexError: index is out of bounds
Viewed 358
参考k230关于yolo的pt模型转kmodel案例链接:
https://developer.canaan-creative.com/k230_canmv/zh/dev/zh/example/ai/YOLO%E5%A4%A7%E4%BD%9C%E6%88%98.html
将标准的yolov5s.pt模型转为yolov5s.kmodel模型,然后使用以上链接的案例运行如下代码:
from libs.YOLO import YOLOv5
import os,sys,gc
# 从本地读入图片,并实现HWC转CHW
def read_img(img_path):
    shape=img_hwc.shape
    img_res=img_tmp_trans.copy()
    return img_return,img_data_rgb888
    # 测试图位于test_yolov5\test_images下
    img_path="/data/test_apple.jpg"
    kmodel_path="/data/yolov5s.kmodel"
    confidence_threshold = 0.5
    model_input_size=[224,224]
    img,img_ori=read_img(img_path)
    # 初始化YOLOv5实例
    yolo=YOLOv5(task_type="classify",mode="image",kmodel_path=kmodel_path,labels=labels,rgb888p_size=rgb888p_size,model_input_size=model_input_size,conf_thresh=confidence_threshold,debug_mode=0)
    yolo.config_preprocess()
        res=yolo.run(img)
        yolo.draw_result(res,img_ori)
        yolo.deinit()
YOLOV.py自带源码报错:IndexError: index is out of bounds
CanMV-K230_LCKFB_micropython_v1.2.2-0-g4b8cae1_nncase_v2.9.0.img.gz
File "", line 31, in
File "/sdcard/libs/AIBase.py", line 74, in run
File "/sdcard/libs/YOLO.py", line 83, in postprocess
MPY: soft reboot
CanMV v1.2.2(based on Micropython e00a144) on 2024-12-18; k230_canmv_lckfb with K230
尝试设置的图片大小640x640导出onnx,kmodel或使用224x224大小导出onnx在转kmodel,并且修改MicroPython代码model_input_size=[224,224]匹配的图片尺寸,测试依然无效
转换的模型yolov5s.kmodel:
https://pan.baidu.com/s/1w9Ch1YI37Srbk0mYmWX_PA?pwd=b3j6
你好,yolov5官方模型是检测模型,你这里的任务类型选择的是分类
你好,从classify修改为detect之后,检测的位置是不准确,更改为其他多人场景图片打印结果:
res array([[0.0, 0.0, 1.0, 0.0, 0.6700015, 0.0],
[0.0, 0.0, 0.0, 1.0, 0.6450262, 0.0]], dtype=float32)
(1)检测结果位置不准确(0.0,0.0, 1.0, 0.0)
(2)检测精度下降非常多,yolov5人员检测一般在0.9左右,而kmodel检测结果一般是0.2-0.6
