ai2d 多batch推理
Viewed 196
K230 1.1.2 nncase 2.9.0
import aicube
root_path="/sdcard/mp_deployment_source/"  # root_path要以/结尾
deploy_conf={}
debug_mode=1
def read_img(img_path):
    shape=img_hwc.shape
    img_res=img_tmp_trans.copy()
    return img_return
# 读取deploy_config.json文件
        except ValueError as e:
            print("JSON 解析错误:", e)
    return config
class AI_Detector():
    def __init__(self,origin_dir,machine_code,batch_size):
        self.bs = batch_size
        self.mc = machine_code
        self.od = origin_dir
        # 使用json读取内容初始化部署变量
        self.labels=deploy_conf["categories"]
        self.confidence_threshold = deploy_conf["confidence_threshold"]
        self.nms_threshold = deploy_conf["nms_threshold"]
        self.model_input_size=[640, 640]
        self.num_classes=deploy_conf["num_classes"]
        self.color_four=get_colors(self.num_classes)
        self.nms_option = deploy_conf["nms_option"]
        self.anchors = deploy_conf["anchors"][0] + deploy_conf["anchors"][1] + deploy_conf["anchors"][2]
        self.strides = [8,16,32]
        # ai2d输入输出初始化
        input_array = np.empty((self.bs, 3, 1080, 1920), dtype=np.uint8)
        for i in range(0,batch_size):
            image_partial_path = self.od + self.mc + f'_{i}.jpg'
            image_partial = read_img(image_partial_path).reshape((1,3,1080,1920))
            input_array[i] = image_partial
        print(input_array.shape)
        self.frame_size = [1920,1080]
        self.ai2d_input_tensor = nn.from_numpy(input_array)
        ai2d_input_shape=input_array.shape
        data = np.ones((self.bs,3,640,640),dtype=np.uint8)
        self.ai2d_output_tensor = nn.from_numpy(data)
        # kpu初始化并加载模型
        self.kpu = nn.kpu()
        self.kpu.load_kmodel(root_path+kmodel_name)
        # ai2d初始化
        ai2d = nn.ai2d()
        ai2d.set_dtype(nn.ai2d_format.NCHW_FMT,nn.ai2d_format.NCHW_FMT,np.uint8, np.uint8)
        ai2d.set_pad_param(True, [0,0,0,0,140,140,0,0], 0, [114,114,114])
        self.ai2d_builder = ai2d.build([self.bs,3,1080,1920], [self.bs,3,640,640])
    def get_result(self, origin_path, score_threshold, pos_threshold):
            # 使用ai2d实现预处理
            self.ai2d_builder.run(self.ai2d_input_tensor, self.ai2d_output_tensor)
            # 设置模型的输入tensor
            self.kpu.set_input_tensor(0, self.ai2d_output_tensor)
            # 模型推理
            print('ready to start')
            self.kpu.run()
            # 获取模型输出
            results = []
            print('done',self.kpu.outputs_size())
            output_numpy = self.ai2d_output_tensor.to_numpy()
            print(output_numpy.shape)
            for i in range(3):
                data = self.kpu.get_output_tensor(i)
                result = data.to_numpy()
                print(result.shape)
                del data
                results.append(result)
            # 后处理
            det_boxes = aicube.anchorbasedet_post_process( results[0], results[1], results[2],
                                                          self.model_input_size, self.frame_size, self.strides, self.num_classes,
                                                          self.confidence_threshold, self.nms_threshold, self.anchors, self.nms_option)
            # 绘制结果
            print(det_boxes)
#            image_draw=image.Image(image_path).to_rgb565()
#            if det_boxes:
#                for det_boxe in det_boxes:
#                    x1, y1, x2, y2 = det_boxe[2],det_boxe[3],det_boxe[4],det_boxe[5]
#                    x,y,w,h=int(x1),int(y1),int(x2 - x1),int((y2 - y1))
#                    image_draw.draw_rectangle(x, y, w, h, color=self.color_four[det_boxe[0]][1:])
#                    label = self.labels[det_boxe[0]]
#                    score = str(round(det_boxe[1],2))
#                    image_draw.draw_string_advanced( int(x1) , int(y1)-30,20, label + " " + score , color=color_four[det_boxe[0]][1:])
#                    print("\n" + label + " " + score)
#                image_draw.compress_for_ide()
#                image_draw.save(root_path+"det_result.jpg")
#            else:
#                print("No objects were identified.")
        input_numpy = self.ai2d_input_tensor.to_numpy()
        print(input_numpy.shape)
        del self.ai2d_input_tensor
        del self.ai2d_output_tensor
        print("---------------end------------------")
        nn.shrink_memory_pool()
    detecter =  AI_Detector('/sdcard/Origin/','143322',13)
    detecter.get_result(1,1,1)
这个推理能支持多张图像吗 为什么改了batchsize输出仍是单通道的? 有没有佬解决一下 官方文档也没有相关说法
您好,不支持多张推理,都是支持单张推理
