Deprecated function, please use draw_string_advanced.Deprecated function, please use draw_string_advanced.total took 73.00 ms为什么模型引用代码力会提示这个?
Viewed 362
你好,原本得image.draw_string 效果比较差,如果可以接受这个效果,也可以使用这个接口的。
import aicube
from machine import UART
from machine import FPIOA
舵机控制初始化
fpioa.set_function(3,FPIOA.UART1_TXD)
fpioa.set_function(4,FPIOA.UART1_RXD)
uart = UART(UART.UART1, 115200)
sensor_id=0
系统配置
display_mode = "hdmi"
TRACK_THRESHOLD = 50 # 像素偏移阈值
SERVO_INIT = {1: 500, 2: 500, 3: 500} # 舵机初始位置
CAM_CHN_ID_0 = 0 # 主显示通道
CAM_CHN_ID_1 = 1 # AI处理通道
显示分辨率配置
if display_mode == "lcd":
DISPLAY_HEIGHT = 1080
OUT_RGB888P_WIDTH = ALIGN_UP(1280, 16)
OUT_RGB888P_HEIGH = 720
config_path = root_path + "deploy_config.json"
debug_mode = 1
def two_side_pad_param(input_size, output_size):
ratio_w = output_size[0] / input_size[0]
ratio_h = output_size[1] / input_size[1]
ratio = min(ratio_w, ratio_h)
new_w = int(ratio * input_size[0])
new_h = int(ratio * input_size[1])
dw = (output_size[0] - new_w) / 2
dh = (output_size[1] - new_h) / 2
top = int(round(dh - 0.1))
bottom = int(round(dh + 0.1))
left = int(round(dw - 0.1))
right = int(round(dw - 0.1))
return top, bottom, left, right, ratio
with open(config_path, 'r') as f:
return ujson.load(f)
def build_servo_packet(servo_id, time_ms, position):
if servo_id > 253 or position > 1000:
return None
packet = bytearray(10)
packet[0:2] = b'\x55\x55'
packet[2] = servo_id
packet[3] = 7
packet[4] = 0x01
packet[5] = position & 0xFF
packet[6] = (position >> 8) & 0xFF
packet[7] = time_ms & 0xFF
packet[8] = (time_ms >> 8) & 0xFF
packet[9] = (~sum(packet[2:9])) & 0xFF
return packet
def servo_control(servo_id, position, move_time=500):
packet = build_servo_packet(servo_id, move_time, int(position))
if packet:
uart.write(packet)
def servo_self_test():
# 水平舵机自检
servo_control(1, 1000, 1000)
time.sleep(1)
servo_control(1, 0, 1000)
time.sleep(1)
# 垂直舵机对称自检
servo_control(2, 0, 1000)
servo_control(3, 1000, 1000)
time.sleep(1)
servo_control(2, 1000, 1000)
servo_control(3, 0, 1000)
time.sleep(1)
# 返回初始位置
for sid, pos in SERVO_INIT.items():
    servo_control(sid, pos)
time.sleep(1)
def calculate_center(box):
x1, y1, x2, y2 = box[2], box[3], box[4], box[5]
center_x = int((x1 + x2) / 2 * DISPLAY_WIDTH / OUT_RGB888P_WIDTH)
center_y = int((y1 + y2) / 2 * DISPLAY_HEIGHT / OUT_RGB888P_HEIGH)
return center_x, center_y
def track_object(center_x, center_y):
screen_center_x = DISPLAY_WIDTH // 2
screen_center_y = DISPLAY_HEIGHT // 2
dx = center_x - screen_center_x
dy = center_y - screen_center_y
# 水平跟踪
if abs(dx) > TRACK_THRESHOLD:
    adj = (dx / TRACK_THRESHOLD) * 50
    new_pos = max(0, min(1000, SERVO_INIT[1] + adj))
    servo_control(1, new_pos, 200)
# 垂直跟踪(对称运动)
if abs(dy) > TRACK_THRESHOLD:
    vertical_adj = (dy / TRACK_THRESHOLD) * 50
    servo2_pos = max(0, min(1000, SERVO_INIT[2] + vertical_adj))
    servo3_pos = max(0, min(1000, SERVO_INIT[3] - vertical_adj))
    servo_control(2, servo2_pos, 200)
    servo_control(3, servo3_pos, 200)
def detection():
print("启动检测系统...")
deploy_conf = read_deploy_config(config_path)
kmodel_name = deploy_conf["kmodel_path"]
labels = deploy_conf["categories"]
confidence_threshold = deploy_conf["confidence_threshold"]
img_size = deploy_conf["img_size"]
num_classes = deploy_conf["num_classes"]
color_four = get_colors(num_classes)
    anchors = sum(deploy_conf["anchors"], [])
kpu = nn.kpu()
kpu.load_kmodel(root_path + kmodel_name)
ai2d = nn.ai2d()
top, bottom, left, right, _ = two_side_pad_param(
    [OUT_RGB888P_WIDTH, OUT_RGB888P_HEIGH], img_size)
ai2d.set_resize_param(True, nn.interp_method.tf_bilinear, nn.interp_mode.half_pixel)
ai2d_builder = ai2d.build([1,3,OUT_RGB888P_HEIGH,OUT_RGB888P_WIDTH],
                        [1,3,img_size[1],img_size[0]])
sensor = Sensor(id=sensor_id)
sensor.set_hmirror(False)
sensor.set_vflip(False)
sensor.set_framesize(width=DISPLAY_WIDTH, height=DISPLAY_HEIGHT)
sensor.set_framesize(width=OUT_RGB888P_WIDTH, height=OUT_RGB888P_HEIGH, chn=CAM_CHN_ID_2)
sensor_bind_info = sensor.bind_info(0, 0, CAM_CHN_ID_0)
Display.bind_layer(**sensor_bind_info, layer=Display.LAYER_VIDEO1)
    Display.init(Display.ST7701, to_ide=True)
    Display.init(Display.LT9611, to_ide=True)
print("执行舵机自检...")
servo_self_test()
print("自检完成,进入跟踪模式")
ai2d_output_tensor = nn.from_numpy(np.ones((1,3,img_size[1],img_size[0]), dtype=np.uint8))
    with ScopedTiming("total", debug_mode > 0):
            kpu.run()
            outputs = [kpu.get_output_tensor(i).to_numpy().flatten()
                      for i in range(kpu.outputs_size())]
            det_boxes = aicube.anchorbasedet_post_process(
                outputs[0], outputs[1], outputs[2], img_size,
                [OUT_RGB888P_WIDTH, OUT_RGB888P_HEIGH], [8,16,32],
                num_classes, confidence_threshold, nms_threshold,
                anchors, nms_option)
            osd_img.clear()
            if det_boxes:
                main_box = max(det_boxes, key=lambda x: (x[4]-x[2])*(x[5]-x[3]))
                center_x, center_y = calculate_center(main_box)
                # 显示中心坐标
                osd_img.draw_string(10, 10, f"X:{center_x} Y:{center_y}",
                                  color=(255,0,0), scale=2)
                # 执行跟踪控制
                # 绘制检测框
                x = int(main_box[2] * DISPLAY_WIDTH / OUT_RGB888P_WIDTH)
                y = int(main_box[3] * DISPLAY_HEIGHT / OUT_RGB888P_HEIGH)
                w = int((main_box[4]-main_box[2]) * DISPLAY_WIDTH / OUT_RGB888P_WIDTH)
                h = int((main_box[5]-main_box[3]) * DISPLAY_HEIGHT / OUT_RGB888P_HEIGH)
                osd_img.draw_rectangle(x, y, w, h, color=color_four[main_box[0]][1:])
                text = f"{labels[main_box[0]]} {main_box[1]:.2f}"
                osd_img.draw_string(x, y-30, text, color=color_four[main_box[0]][1:])
        rgb888p_img = None
nn.shrink_memory_pool()
print("系统关闭")
return 0
if name == "main":
# 初始化舵机位置
time.sleep(1)
detection()
这个代码里面为什么会提示这个信息呢?
