How about modify CAM2_RST pin for K230 SOC?
Viewed 272
I design a board (base on K230 CanMV), with IO62 (T14) to CAM2_RST
I want add IO62 -> CAM2_RST.But, i don't see node IO for CSI describe.
HW: Modify K230 (base on Dongshanpi)
FW: K230_Linux_SDK
How about edit IO62 ->CAM2_RST
At present, the Linux driver is not perfect, and the reset operation is currently missing in the driver.
Thank you for your feedback!
I check in 01studio.dts and dongshanpi.dts file. I see 01studio use CAM2_RST is IO62, dongshanpi use CAM2_RST is IO21. But, I don't see the node describing them. Is there some way to change CAM2_RST from dts or from application?
