CanMV IDE k230,点击启动按钮,不出图像也不报错,直接就软重启了。
Viewed 418
由于没有使用通道0,我设置sensor = Sensor(id = 2)串口终端输出这个:Traceback (most recent call last):
File "", line 221, in
File "", line 129, in detection
File "media/sensor.py", line 174, in init
RuntimeError: Can not found sensor on 0
MPY: soft reboot
det_infer start
use sensor 21, output 1920x1080@30
buffer pool : 5
sensor(2), mode 0, buffer_num 4, buffer_size 0
total took 1003.00 ms
An error occurred during buffer used: sensor(2) snapshot chn(2) failed(-1609203696)
det_infer end
MPY: soft reboot
import aicube
from time import *
import utime
import random
import utime
DISPLAY_HEIGHT = 1080
OUT_RGB888P_WIDTH = ALIGN_UP(1080, 16)
OUT_RGB888P_HEIGH = 720
颜色盘
color_four = [(255, 220, 20, 60), (255, 119, 11, 32), (255, 0, 0, 142), (255, 0, 0, 230),
(255, 0, 226, 252), (255, 182, 182, 255), (255, 0, 82, 0), (255, 120, 166, 157),
(255, 110, 76, 0), (255, 174, 57, 255), (255, 199, 100, 0), (255, 72, 0, 118),
(255, 255, 179, 240), (255, 0, 125, 92), (255, 209, 0, 151), (255, 188, 208, 182),
(255, 0, 220, 176), (255, 255, 99, 164), (255, 92, 0, 73), (255, 133, 129, 255),
(255, 78, 180, 255), (255, 0, 228, 0), (255, 174, 255, 243), (255, 45, 89, 255),
(255, 134, 134, 103), (255, 145, 148, 174), (255, 255, 208, 186),
(255, 197, 226, 255), (255, 171, 134, 1), (255, 109, 63, 54), (255, 207, 138, 255),
(255, 151, 0, 95), (255, 9, 80, 61), (255, 84, 105, 51), (255, 74, 65, 105),
(255, 166, 196, 102), (255, 208, 195, 210), (255, 255, 109, 65), (255, 0, 143, 149),
(255, 179, 0, 194), (255, 209, 99, 106), (255, 5, 121, 0), (255, 227, 255, 205),
(255, 147, 186, 208), (255, 153, 69, 1), (255, 3, 95, 161), (255, 163, 255, 0),
(255, 119, 0, 170), (255, 0, 182, 199), (255, 0, 165, 120), (255, 183, 130, 88),
(255, 95, 32, 0), (255, 130, 114, 135), (255, 110, 129, 133), (255, 166, 74, 118),
(255, 219, 142, 185), (255, 79, 210, 114), (255, 178, 90, 62), (255, 65, 70, 15),
(255, 127, 167, 115), (255, 59, 105, 106), (255, 142, 108, 45), (255, 196, 172, 0),
(255, 95, 54, 80), (255, 128, 76, 255), (255, 201, 57, 1), (255, 246, 0, 122),
(255, 191, 162, 208)]
deploy_conf={}
debug_mode=1
class ScopedTiming:
def init(self, info="", enable_profile=True):
self.info = info
def __enter__(self):
    if self.enable_profile:
    return self
# 打开JSON文件以进行读取deploy_config
# 从文件中加载JSON数据
        # 打印数据(可根据需要执行其他操作)
        #print(config)
    except ValueError as e:
        print("JSON 解析错误:", e)
return config
def detection():
print("det_infer start")
# 使用json读取内容初始化部署变量
kmodel_frame_size = img_size
strides = [8,16,32]
# 计算padding值
ori_w = OUT_RGB888P_WIDTH;
ori_h = OUT_RGB888P_HEIGH;
width = kmodel_frame_size[0];
height = kmodel_frame_size[1];
ratiow = float(width) / ori_w;
ratioh = float(height) / ori_h;
if ratiow < ratioh:
    ratio = ratiow
    ratio = ratioh
new_w = int(ratio * ori_w);
new_h = int(ratio * ori_h);
dw = float(width - new_w) / 2;
dh = float(height - new_h) / 2;
top = int(round(dh - 0.1));
bottom = int(round(dh + 0.1));
left = int(round(dw - 0.1));
right = int(round(dw - 0.1));
# init kpu and load kmodel
kpu = nn.kpu()
ai2d = nn.ai2d()
                               np.uint8, np.uint8)
ai2d_builder = ai2d.build([1,3,OUT_RGB888P_HEIGH,OUT_RGB888P_WIDTH], [1,3,height,width])
# 初始化并配置sensor
# 设置镜像
sensor.set_hmirror(False)
# 设置翻转
sensor.set_vflip(False)
# 通道0直接给到显示VO,格式为YUV420
# 通道2给到AI做算法处理,格式为RGB888
# 绑定通道0的输出到vo
# 设置为LT9611显示,默认1920x1080
#创建OSD图像
    # media初始化
    # 启动sensor
    rgb888p_img = None
    ai2d_input_tensor = None
    data = np.ones((1,3,width,height),dtype=np.uint8)
    while  True:
            # for rgb888planar
                # set input
                # run kmodel
                kpu.run()
                # get output
                results = []
                    result = out_data.to_numpy()
                    del out_data
                    results.append(result)
                # postprocess
                elif model_type == "GFLDet":
                    det_boxes = aicube.gfldet_post_process( results[0], results[1], results[2], kmodel_frame_size, frame_size, strides, num_classes, confidence_threshold, nms_threshold, nms_option)
                    det_boxes = aicube.anchorfreedet_post_process( results[0], results[1], results[2], kmodel_frame_size, frame_size, strides, num_classes, confidence_threshold, nms_threshold, nms_option)
                osd_img.clear()
                if det_boxes:
                    for det_boxe in det_boxes:
                        w = float(x2 - x1) * DISPLAY_WIDTH // OUT_RGB888P_WIDTH
                        h = float(y2 - y1) * DISPLAY_HEIGHT // OUT_RGB888P_HEIGH
                        osd_img.draw_rectangle(int(x1 * DISPLAY_WIDTH // OUT_RGB888P_WIDTH) , int(y1 * DISPLAY_HEIGHT // OUT_RGB888P_HEIGH) , int(w) , int(h) , color=color_four[det_boxe[0]][1:])
                        label = labels[det_boxe[0]]
                        osd_img.draw_string_advanced( int(x1 * DISPLAY_WIDTH // OUT_RGB888P_WIDTH) , int(y1 * DISPLAY_HEIGHT // OUT_RGB888P_HEIGH)-50,32, label + " " + score , color=color_four[det_boxe[0]][1:])
            rgb888p_img = None
    print(f"An error occurred during buffer used: {e}")
    del ai2d_input_tensor
    del ai2d_output_tensor
    #停止摄像头输出
    #去初始化显示设备
    #释放媒体缓冲区
    time.sleep(1)
    nn.shrink_memory_pool()
print("det_infer end")
return 0
if name=="main":
detection()
