docker无法启用
Viewed 111
mengxing@mengxing-virtual-machine:/etc/docker$ sudo systemctl daemon-reload
mengxing@mengxing-virtual-machine:/etc/docker$ sudo systemctl restart docker
Job for docker.service failed because the control process exited with error code.
See "systemctl status docker.service" and "journalctl -xe" for details.
mengxing@mengxing-virtual-machine:/etc/docker$ systemctl status docker.service
● docker.service - Docker Application Container Engine
Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2025-05-19 21:45:14 CST; 9min ago
TriggeredBy: ● docker.socket
Docs: https://docs.docker.com
Process: 26896 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock (code=exited, status=1/FAILURE)
Main PID: 26896 (code=exited, status=1/FAILURE)
5月 19 21:45:14 mengxing-virtual-machine systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
5月 19 21:45:14 mengxing-virtual-machine systemd[1]: Stopped Docker Application Container Engine.
5月 19 21:45:14 mengxing-virtual-machine systemd[1]: docker.service: Start request repeated too quickly.
5月 19 21:45:14 mengxing-virtual-machine systemd[1]: docker.service: Failed with result 'exit-code'.
5月 19 21:45:14 mengxing-virtual-machine systemd[1]: Failed to start Docker Application Container Engine.
这样的报错该怎样解决
