Does the eMMC0 circuit of k230 SOC need registers pull-up?
Viewed 141
I design PCB for K230 Soc, with eMMC0 connect to KLMAG1JETD-B041.
I check design guide of Kendryte but couldn't find Resgister Pull-up.
In "9.5 Bus signal Line Load" of eMMC KLMAG1JETD-B041 datasheet: Pull-up CMD, DAT0-DAT7. 4.7K,10k to 100k Ohm.
so, does eMMC0 need pull-up register?
eMMC0 need pull-up resistors to prevent bus floating
