立创K230开发板使用only_rtsmart镜像,同时采集三路摄像头数据的时候报错
Viewed 254
这是我的main函数:
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <signal.h>
#include <string.h>
#include <pthread.h>
#include <sys/time.h>
#include "simple_mpp.h"
#define CAMERA1_ENABLE
#define CAMERA2_ENABLE
#define CAMERA3_ENABLE
#ifdef CAMERA1_ENABLE
FILE* camera1_file = NULL;
void camera1_data_handler(unsigned int idx, unsigned int len, unsigned char* buf)
    printf("camera1_data_handler, idx[%d] len[%d]\n", idx, len);
    if (camera1_file == NULL) {
        camera1_file = fopen("camera1_data.h265", "wb");
    fwrite(buf, len, 1, camera1_file);
#endif
#ifdef CAMERA2_ENABLE
FILE* camera2_file = NULL;
void camera2_data_handler(unsigned int idx, unsigned int len, unsigned char* buf)
    printf("camera2_data_handler, idx[%d] len[%d]\n", idx, len);
    if (camera2_file == NULL) {
        camera2_file = fopen("camera2_data.h265", "wb");
    fwrite(buf, len, 1, camera2_file);
#endif
#ifdef CAMERA3_ENABLE
FILE* camera3_file = NULL;
void camera3_data_handler(unsigned int idx, unsigned int len, unsigned char* buf)
    printf("camera3_data_handler, idx[%d] len[%d]\n", idx, len);
    if (camera3_file == NULL) {
        camera3_file = fopen("camera3_data.h265", "wb");
    fwrite(buf, len, 1, camera3_file);
#endif
static int  loop_run_flag;
static void signal_handler(int signal)
    printf("signal [%d] exit.\n", signal);
    loop_run_flag = 0;
    loop_run_flag = 1;
    signal(SIGINT, signal_handler);  // crtc + c
    signal(SIGTERM, signal_handler);  // killall
    simple_mpp_vb_init(3);
    simple_mpp_config_t config1 = {0};
    config1.ch = 0;
    config1.dev = 0;
    config1.width = 1280;
    config1.height = 720;
    config1.sensor_type = GC2093_MIPI_CSI2_1920X1080_30FPS_10BIT_LINEAR;
    config1.bitrate = 4000;
    simple_mpp_init(&config1);
#endif
    simple_mpp_config_t config2 = {0};
    config2.ch = 1;
    config2.dev = 1;
    config2.width = 1280;
    config2.height = 720;
    config2.sensor_type = GC2093_MIPI_CSI1_1920X1080_30FPS_10BIT_LINEAR;
    config2.bitrate = 4000;
    simple_mpp_init(&config2);
#endif
    simple_mpp_config_t config3 = {0};
    config3.ch = 2;
    config3.dev = 2;
    config3.width = 1280;
    config3.height = 720;
    config3.sensor_type = GC2093_MIPI_CSI0_1920X1080_30FPS_10BIT_LINEAR;
    config3.bitrate = 4000;
    simple_mpp_init(&config3);
#endif
    while (loop_run_flag) {
        simple_mpp_recv(&config1, camera1_data_handler);
#endif
        simple_mpp_recv(&config2, camera2_data_handler);
#endif
        simple_mpp_recv(&config3, camera3_data_handler);
#endif
        simple_mpp_deinit(&config1);
        if (camera1_file != NULL) {
            fclose(camera1_file);
#endif
        simple_mpp_deinit(&config2);
        if (camera2_file!= NULL) {
            fclose(camera2_file);
#endif
        simple_mpp_deinit(&config3);
        if (camera3_file!= NULL) {
            fclose(camera3_file);
#endif
    simple_mpp_vb_deinit();
    return 0;
这是我封装的MPP库头文件:
#ifndef SIMPLE_MPP_H
#define SIMPLE_MPP_H
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <unistd.h>
#include "k_module.h"
#include "k_sensor_comm.h"
#include "k_type.h"
#include "k_vb_comm.h"
#include "k_video_comm.h"
#include "k_sys_comm.h"
#include "mpi_vb_api.h"
#include "mpi_venc_api.h"
#include "mpi_sys_api.h"
#include "mpi_sensor_api.h"
#include "k_venc_comm.h"
#include "mpi_vvi_api.h"
typedef enum
    VENC_SAMPLE_STATUS_IDLE = 0,
    VENC_SAMPLE_STATUS_INIT,
    VENC_SAMPLE_STATUS_START,
    VENC_SAMPLE_STATUS_BINDED,
    VENC_SAMPLE_STATUS_UNBINDED,
    VENC_SAMPLE_STATUE_RUNING,
    VENC_SAMPLE_STATUS_STOPED,
    VENC_SAMPLE_STATUS_BUTT
} simple_mpp_status_t;
    int width;
    int height;
    unsigned int bitrate;
    // int chnum;
    int ch;
    int dev;
    simple_mpp_status_t status;
    unsigned int frame_cnt;
} simple_mpp_config_t;
int simple_mpp_vb_init(int ch_cnt);
int simple_mpp_vb_deinit();
int simple_mpp_init(simple_mpp_config_t* config);
int simple_mpp_deinit(simple_mpp_config_t* config);
int simple_mpp_recv(simple_mpp_config_t* config, void (*frame_handler)(unsigned int idx, unsigned int len, unsigned char* buf));
#endif//SIMPLE_MPP_H
当我执行编译后的文件,只拿一路相机数据的时候是没有问题的,但当我同时拿3路相机数据的时候就失败了,报错如下:
msh />cd sd
msh />cd sdcard/
msh /sdcard>ls
Directory /sdcard:
app                                     <DIR>
revision.txt                            503
start.sh                                72
sensor_capture_run                      2550800
camera_capture_run                      2540976
camera2_data.h265                       7361540
msh /sdcard>./cam
camera_capture_run
camera2_data.h265
msh /sdcard>./camera_c
msh /sdcard>./camera_capture_run
-----------venc sample test------------------------
venc create chn 0
venc start chn 0
<0>[6] [vi] wait stop timeout
[tuning] dev: 0
acq_win.width: 1920
acq_win.height: 1080
pipe_ctrl: 9
sensor_fd: 6
sensor_type: 23
sensor_name: gc2093_csi2
database_name: gc2093-1920x1080
buffer_num: 0
buffer_size: 0
[tuning] chn: 0
out_win.width: 1280
out_win.height: 720
bit_width: 0
pix_format: 5
buffer_num: 6
buffer_size: 1384448
yraw_size: 0
uv_size: 0
v_size: 0
block_type: 1
wait_time: 500
chn_enable: 1
kd_mpi_isp_set_output_chn_format, width(1280), height(720), pix_format(5)
[dw] init, version May 20 2025 00:06:18
venc bind venc and sensor
venc create chn 1
venc start chn 1
sys queue no space to push data
<3>[9] [Func]:venc_input_enqueue [Line]:417 [Info]:venc_input_enqueue>failed
[tuning] dev: 1
acq_win.width: 1920
pipe_ctrl: 9
sensor_fd: 11
sensor_type: 19
sensor_name: gc2093_csi1
buffer_num: 0
buffer_size: 0
[tuning] chn: 0
out_win.width: 0
out_win.height: 0
bit_width: 0
pix_format: 0
buffer_num: 0
buffer_size: 0
yraw_size: 0
uv_size: 0
v_size: 0
block_type: 0
wait_time: 0
chn_enable: 0
oslayer assert /builds/maix_sw/k230_sdk/src/big/mpp/userapps/src/vicap/src/isp/sdk/units/oslayer/source/oslayer_generic.c, 357  pQueue == NULL
[E/DBG] [FATAL ERROR] Exception 13:Load Page Fault
[E/DBG] scause:0x000000000000000d,stval:0x000000000000005c,sepc:0x0000000200091344
--------------Dump Registers-----------------
Function Registers:
        ra(x1) = 0x0000000200091340()
        user_sp(x2) = 0x000000010082edd0()
        gp(x3) = 0x0000000000000000()
        tp(x4) = 0x000000010082efe8()
Temporary Registers:
        t0(x5) = 0x0000000000000084()
        t1(x6) = 0x0000000000000007()
        t2(x7) = 0x0000000000000050()
        t3(x28) = 0x0000000000000072()
        t4(x29) = 0x000000000000008f()
        t5(x30) = 0x000000000000000e()
        t6(x31) = 0x000000000000000e()
Saved Registers:
        s0/fp(x8) = 0x000000010082ee00()
        s1(x9) = 0x000000010082eee0()
        s2(x18) = 0x000000010082efe8()
        s3(x19) = 0x00000002ffffe458()
        s4(x20) = 0x000000000000000c()
        s5(x21) = 0x0000000000000000()
        s6(x22) = 0x0000000200091ca8()
        s7(x23) = 0x00000003000f77e0()
        s8(x24) = 0x000000010082ef08()
        s9(x25) = 0x000000020025ac00()
        s10(x26) = 0x00000002ffffe5d8()
        s11(x27) = 0x000000010080c000()
Function Arguments Registers:
        a0(x10) = 0x0000000000000016()
        a1(x11) = 0x0000000000000001()
        a2(x12) = 0x0000000000000000()
        a3(x13) = 0x000000000000000c()
        a4(x14) = 0x0000000000000030()
        a5(x15) = 0x0000000000000000()
        a6(x16) = 0x0000000000000000()
        a7(x17) = 0x0000000000000000()
sstatus = 0x8000000200046620
        Supervisor Interrupt Disabled
        Last Time Supervisor Interrupt Enabled
        Last Privilege is User Mode
        Permit to Access User Page
        Not Permit to Read Executable-only Page
satp = 0x80000000000047c6
        Current Page Table(Physical) = 0x00000000047c6000
        Current ASID = 0x0000000000000000
        Mode = Page-based 39-bit Virtual Addressing Mode
-----------------Dump OK---------------------
riscv64-unknown-linux-musl-addr2line -e camera_capture_run -a -f 0000000200091340 00000002001dcb84 0000000200091cd2 000000020021c552Unhandled Exception 13:Load Page Fault
scause:0x000000000000000d,stval:0xfffffffffffffff8,sepc:0x000000000019bc60
Function Registers:
        ra(x1) = 0x000000000019bc8e()
        user_sp(x2) = 0x0000000000411318()
        gp(x3) = 0x0000000000401e58()
        t0(x5) = 0x0000000000411220()
        t1(x6) = 0x00000000004e45b0()
        t2(x7) = 0x0000000000000080()
        t3(x28) = 0x00000000003ceb80()
        t4(x29) = 0x0000000000000030()
        t5(x30) = 0x0000000000000000()
        t6(x31) = 0x0000000000411228()
Saved Registers:
        s0/fp(x8) = 0x0000000000411368()
        s1(x9) = 0x000000000000000d()
        s2(x18) = 0x0000000200091344()
        s3(x19) = 0x00000000004113d8()
        s4(x20) = 0x000000000000005c()
        a0(x10) = 0x0000000000000011()
        a1(x11) = 0x0000000000000032()
        a2(x12) = 0x00000000004e45a8()
        a3(x13) = 0x00000000c0007000()
        a4(x14) = 0x0000000000000000()
        a5(x15) = 0xfffffffffffffff8()
        a6(x16) = 0x00000000004e45b9()
        a7(x17) = 0x0000000000000032()
sstatus = 0x8000000200044700
        Last Time Supervisor Interrupt Disabled
        Last Privilege is Supervisor Mode
--------------Thread list--------------
current thread: camera_capture_run
PID  CMD                  thread               pri  status      sp     stack size max used left tick  error
     kernel               vpu_task              12  suspend 0x000004f8 0x00002000    34%   0x00000002 -09
     kernel               cmd_thread             6  suspend 0x00000558 0x00005000    12%   0x00000001 -09
     kernel               xmit_thread            7  suspend 0x00000528 0x00005000    06%   0x0000000a -09
     kernel               usbh_rtl8152_rx       15  suspend 0x00000598 0x00001000    41%   0x0000000a -09
     kernel               dwc2_lo_prio_bh        1  suspend 0x000004f8 0x00005000    06%   0x00000009 000
     kernel               dwc2_hi_prio_bh        0  suspend 0x000004f8 0x00005000    06%   0x00000008 000
     kernel               dwc2                  16  suspend 0x000004f8 0x00005000    06%   0x0000000a 000
     kernel               sdio_irq               4  suspend 0x000004f8 0x00002800    29%   0x00000006 -09
     kernel               mtp                   16  suspend 0x00000508 0x00005000    20%   0x00000006 -09
     kernel               mtp_inty              16  suspend 0x000007a8 0x00005000    13%   0x0000000a -09
     kernel               usbh_hub0             14  suspend 0x000005a8 0x00001000    48%   0x00000006 -09
     kernel               tshell                20  ready   0x000008b8 0x00014000    04%   0x00000001 -02
     kernel               thermal_detect_threa  29  suspend 0x000004d8 0x00002800    13%   0x0000000a -09
     kernel               auto_load_thread      29  suspend 0x00000498 0x00002800    12%   0x0000000a 000
     kernel               sys workq             17  suspend 0x00000598 0x00005000    07%   0x0000000a -09
     kernel               wlan                  15  suspend 0x000004f8 0x00001000    31%   0x0000000a 000
     kernel               mmcsd_detect          22  suspend 0x00000558 0x00008000    09%   0x00000014 -09
     kernel               tcpip                 10  suspend 0x00000578 0x00002800    14%   0x00000014 -09
     kernel               etx                   12  suspend 0x00000538 0x00002800    13%   0x00000010 -09
     kernel               erx                   12  suspend 0x00000558 0x00002800    18%   0x00000010 -09
     kernel               tsystem               30  suspend 0x000004f8 0x00004000    08%   0x00000020 -09
     kernel               tidle0                31  ready   0x00000448 0x00004000    06%   0x00000016 000
     kernel               timer                  4  suspend 0x000004d8 0x00004000    14%   0x00000009 -09
   2 ./camera_capture_run camera_capture_run     0  running 0x00000950 0x00004000    25%   0x000000bb 022
   2 ./camera_capture_run camera_capture_run     0  suspend 0x00000900 0x00004000    24%   0x0000009a 000
   2 ./camera_capture_run camera_capture_run     0  suspend 0x00000900 0x00004000    24%   0x000000c5 000
   2 ./camera_capture_run camera_capture_run     0  suspend 0x00000900 0x00004000    24%   0x000000c8 000
   2 ./camera_capture_run camera_capture_run     0  suspend 0x00000900 0x00004000    24%   0x000000c4 000
   2 ./camera_capture_run camera_capture_run     0  ready   0x00000900 0x00004000    25%   0x000000be -02
   2 ./camera_capture_run camera_capture_run     0  ready   0x00000950 0x00004000    24%   0x000000c2 000
   2 ./camera_capture_run camera_capture_run    25  ready   0x00000428 0x00004000    25%   0x00000045 000
--------------Backtrace--------------
riscv64-unknown-linux-musl-addr2line -e rtthread.elf -a -f 000000000019bc5c
请问我的代码对mpp的使用流程有什么问题吗
这个是我封装的MPP库具体实现:
#define MAX_WIDTH 1920
#define MAX_HEIGHT 1080
#define STREAM_BUF_SIZE ((MAX_WIDTH*MAX_HEIGHT/2 + 0xfff) & ~0xfff)
#define FRAME_BUF_SIZE ((MAX_WIDTH*MAX_HEIGHT*2 + 0xfff) & ~0xfff)
#define OSD_MAX_WIDTH 100
#define OSD_MAX_HEIGHT 100
#define OSD_BUF_SIZE OSD_MAX_WIDTH*OSD_MAX_HEIGHT*4
#define INPUT_BUF_CNT   6
#define OUTPUT_BUF_CNT  15
#define OSD_BUF_CNT     20
#define VI_ALIGN_UP(addr, size) (((addr)+((size)-1U))&(~((size)-1U)))
//#define ENABLE_VDSS 1
#define ENABLE_VENC_DEBUG
static inline void CHECK_RET(k_s32 ret, const char *func, const int line)
    if (ret)
        printf("error ret %d, func %s line %d\n", ret, func, line);
#ifdef ENABLE_VENC_DEBUG
    #define venc_debug  printf
#else
    #define venc_debug(ARGS...)
#endif
void sample_vicap_stop(k_u32 ch, k_u32 dev)
#ifdef ENABLE_VDSS
    k_s32 ret;
    ret = kd_mpi_vdss_stop_pipe(0, ch);
    CHECK_RET(ret, __func__, __LINE__);
#else
    k_s32 ret;
    ret = kd_mpi_vicap_stop_stream(VICAP_DEV_ID_0);
    ret = kd_mpi_vicap_deinit(VICAP_DEV_ID_0);
#endif
void sample_vicap_start(k_u32 ch, k_u32 dev)
#ifdef ENABLE_VDSS
    k_s32 ret;
    ret = kd_mpi_vdss_start_pipe(0, ch);
#else
    k_s32 ret;
    ret = kd_mpi_vicap_start_stream(dev);
#endif
static void sample_vi_unbind_venc(k_u32 chn_id)
    k_mpp_chn venc_mpp_chn;
    k_mpp_chn vi_mpp_chn;
    venc_mpp_chn.mod_id = K_ID_VENC;
    venc_mpp_chn.dev_id = 0;
    venc_mpp_chn.chn_id = chn_id;
#ifdef ENABLE_VDSS
    vi_mpp_chn.mod_id = K_ID_VICAP;
#else
    vi_mpp_chn.mod_id = K_ID_VI;
#endif
    vi_mpp_chn.dev_id = chn_id;
    vi_mpp_chn.chn_id = chn_id;
    kd_mpi_sys_unbind(&vi_mpp_chn, &venc_mpp_chn);
    return;
static void sample_vicap_config(k_u32 ch, k_u32 dev, k_u32 width, k_u32 height, k_vicap_sensor_type sensor_type)
#ifdef ENABLE_VDSS
    k_vicap_dev_attr dev_attr;
    k_vicap_chn_attr chn_attr;
    mpi_vdss_rst_all(2);
    memset(&dev_attr, 0, sizeof(dev_attr));
    dev_attr.dev_num = ch;
    dev_attr.height = height;
    dev_attr.width = width;
    dev_attr.sensor_type = 1;
    dev_attr.artr.csi = CSI0;
    dev_attr.artr.type = CLOSE_3D_MODE;
    dev_attr.artr.mode = LINERA_MODE;
    dev_attr.artr.dev_format[0] = RAW10;
    dev_attr.artr.phy_attr.lan_num = MIPI_1LAN;
    dev_attr.artr.phy_attr.freq = MIPI_800M;
    dev_attr.artr.bind_dvp = DVP_CSI1_FLASE_TRIGGER0;
    kd_mpi_vdss_set_dev_attr(&dev_attr);
    memset(&chn_attr, 0, sizeof(chn_attr));
    chn_attr.format = PIXEL_FORMAT_YVU_SEMIPLANAR_420;
    chn_attr.height = height;
    chn_attr.width = width;
    chn_attr.enable = 1;
    kd_mpi_vdss_set_chn_attr(ch, ch, &chn_attr);
#else
    k_s32 ret;
    k_vicap_dev vicap_dev = dev;
    k_vicap_chn vicap_chn = ch;
    sensor_info.sensor_type = sensor_type;
    ret = kd_mpi_vicap_get_sensor_info(sensor_info.sensor_type, &sensor_info);
    dev_attr.acq_win.width = sensor_info.width;
    dev_attr.acq_win.height = sensor_info.height;
    dev_attr.mode = VICAP_WORK_ONLINE_MODE;
    dev_attr.pipe_ctrl.bits.ae_enable = 1;
    dev_attr.pipe_ctrl.bits.awb_enable = 1;
    width = VI_ALIGN_UP(width,16);
    chn_attr.out_win.width = width;
    chn_attr.out_win.height = height;
    chn_attr.crop_win = chn_attr.out_win;
    chn_attr.chn_enable = K_TRUE;
    chn_attr.alignment = 12;
    //chn_attr.bit_width = ISP_PIXEL_YUV_8_BIT;
    chn_attr.pix_format = PIXEL_FORMAT_YUV_SEMIPLANAR_420;
    chn_attr.buffer_num = INPUT_BUF_CNT;
    chn_attr.buffer_size = (width * height * 3 / 2 + 0xfff) & ~ 0xfff;
    //chn_attr.block_type = ISP_BUFQUE_TIMEOUT_TYPE;
    //chn_attr.wait_time = 500;
#endif
static k_s32 sample_vb_exit(void)
    k_s32 ret;
    ret = kd_mpi_vb_exit();
    if (ret)
        printf("vb_exit failed ret:%d\n", ret);
    return ret;
static void sample_vi_bind_venc(k_u32 chn_id)
    k_s32 ret;
#ifdef ENABLE_VDSS
#else
#endif
    ret = kd_mpi_sys_bind(&vi_mpp_chn, &venc_mpp_chn);
    if (ret)
        printf("kd_mpi_sys_bind failed:0x%x\n", ret);
    return;
static k_s32 sample_vb_init(k_u32 ch_cnt, k_bool osd_enable)
    k_s32 ret;
    k_vb_config config;
    if (osd_enable)
        config.max_pool_cnt = 3;
        config.comm_pool[2].blk_cnt = OSD_BUF_CNT * ch_cnt;
        config.comm_pool[2].blk_size = OSD_BUF_SIZE;
        config.comm_pool[2].mode = VB_REMAP_MODE_NOCACHE;
    else
        config.max_pool_cnt = 2;
    config.comm_pool[0].blk_cnt = INPUT_BUF_CNT * ch_cnt;
    config.comm_pool[0].blk_size = FRAME_BUF_SIZE;
    config.comm_pool[1].blk_cnt = OUTPUT_BUF_CNT * ch_cnt;
    config.comm_pool[1].blk_size = STREAM_BUF_SIZE;
    ret = kd_mpi_vb_set_config(&config);
    venc_debug("-----------venc sample test------------------------\n");
    if (ret)
        venc_debug("vb_set_config failed ret:%d\n", ret);
    ret = kd_mpi_vb_init();
    if (ret)
        venc_debug("vb_init failed ret:%d\n", ret);
    return ret;
// 在使用过程中只需要初始化一次
    return sample_vb_init(ch_cnt, K_FALSE);
    return sample_vb_exit();
    int ret;
    if (config == NULL) {
        return -1;
    // 初始化vb
    // 初始化venc
    k_venc_chn_attr attr;
    memset(&attr, 0, sizeof(attr));
    attr.venc_attr.pic_width = config->width;
    attr.venc_attr.pic_height = config->height;
    attr.venc_attr.stream_buf_size = STREAM_BUF_SIZE;
    attr.venc_attr.stream_buf_cnt = OUTPUT_BUF_CNT;
    attr.rc_attr.rc_mode = K_VENC_RC_MODE_CBR;
    attr.rc_attr.cbr.src_frame_rate = 30;
    attr.rc_attr.cbr.dst_frame_rate = 30;
    attr.rc_attr.cbr.bit_rate = config->bitrate;
    attr.venc_attr.type = K_PT_H265;
    attr.venc_attr.profile = VENC_PROFILE_H265_MAIN;
    ret = kd_mpi_venc_create_chn(config->ch, &attr);
    printf("venc create chn %d\n", config->ch);
    config->status = VENC_SAMPLE_STATUS_INIT;
    // 启动venc
    ret = kd_mpi_venc_start_chn(config->ch);
    printf("venc start chn %d\n", config->ch);
    config->status = VENC_SAMPLE_STATUS_START;
    // 绑定venc和sensor
    sample_vicap_config(config->ch, config->dev, config->width, config->height, config->sensor_type);
    sample_vi_bind_venc(config->ch);
    sample_vicap_start(config->ch, config->dev);
    printf("venc bind venc and sensor\n");
    config->status = VENC_SAMPLE_STATUS_BINDED;
    // 其他
    config->frame_cnt = 0;
    int ch = config->ch;
    int dev = config->dev;
    int ret = 0;
    printf("%s>g_venc_sample_status = %d\n", __FUNCTION__, config->status);
    switch (config->status)
    case VENC_SAMPLE_STATUE_RUNING:
    case VENC_SAMPLE_STATUS_BINDED:
        sample_vicap_stop(ch, dev);
        sample_vi_unbind_venc(ch);
    case VENC_SAMPLE_STATUS_START:
        kd_mpi_venc_stop_chn(ch);
    case VENC_SAMPLE_STATUS_INIT:
        kd_mpi_venc_destroy_chn(ch);
        break;
    default:
        break;
    // 关闭venc
    ret = kd_mpi_venc_close_fd();
    // 释放vb
    // sample_vb_exit();
    return 0;
    int ret;
    k_venc_chn_status status;
    k_venc_stream output;
    // 等待venc输出数据
    ret = kd_mpi_venc_query_status(config->ch, &status);
    if (status.cur_packs > 0)
        output.pack_cnt = status.cur_packs;
    else
        output.pack_cnt = 1;
    // 获取venc输出数据
    output.pack = malloc(sizeof(k_venc_pack) * output.pack_cnt);
    ret = kd_mpi_venc_get_stream(config->ch, &output, 1000);
    if (ret != K_SUCCESS) {
        return ret;
    config->frame_cnt += output.pack_cnt;
    for (int i = 0; i < output.pack_cnt; i++) {
        if (output.pack[i].type == K_VENC_HEADER) {
            // 处理header
        k_u8 *pData;
        pData = (k_u8 *)kd_mpi_sys_mmap(output.pack[i].phys_addr, output.pack[i].len);
        if (frame_handler)
            frame_handler(config->frame_cnt, output.pack[i].len, pData);
        kd_mpi_sys_munmap(pData, output.pack[i].len);
    ret = kd_mpi_venc_release_stream(config->ch, &output);
    free(output.pack);
1.simple_mpp_vb_init 只初始化了一个通道的vb,既然创建了三个sensor,vb也要分配足够多。
2.分别启动三路sensor的每一路的第0路通道。
3.建议你先把编码部分去掉,减少模块进一步调试。
