K230使用only__rtsmart镜像,拿三路相机数据码流报错
Viewed 105
报错信息如下,请问这个是什么问题啊,用的是sample_venc例程改的
msh />cd sd
msh />cd sdcard/
msh /sdcard>ls
Directory /sdcard:
app                                     <DIR>
revision.txt                            503
start.sh                                72
sensor_capture_run                      2550800
camera_capture_run                      2540976
camera2_data.h265                       7361540
msh /sdcard>./cam
camera_capture_run
camera2_data.h265
msh /sdcard>./camera_c
msh /sdcard>./camera_capture_run
-----------venc sample test------------------------
venc create chn 0
venc start chn 0
<0>[6] [vi] wait stop timeout
[tuning] dev: 0
acq_win.width: 1920
acq_win.height: 1080
pipe_ctrl: 9
sensor_fd: 6
sensor_type: 23
sensor_name: gc2093_csi2
database_name: gc2093-1920x1080
buffer_num: 0
buffer_size: 0
[tuning] chn: 0
out_win.width: 1280
out_win.height: 720
bit_width: 0
pix_format: 5
buffer_num: 6
buffer_size: 1384448
yraw_size: 0
uv_size: 0
v_size: 0
block_type: 1
wait_time: 500
chn_enable: 1
kd_mpi_isp_set_output_chn_format, width(1280), height(720), pix_format(5)
[dw] init, version May 20 2025 00:06:18
venc bind venc and sensor
venc create chn 1
venc start chn 1
sys queue no space to push data
<3>[9] [Func]:venc_input_enqueue [Line]:417 [Info]:venc_input_enqueue>failed
[tuning] dev: 1
acq_win.width: 1920
pipe_ctrl: 9
sensor_fd: 11
sensor_type: 19
sensor_name: gc2093_csi1
buffer_num: 0
buffer_size: 0
[tuning] chn: 0
out_win.width: 0
out_win.height: 0
bit_width: 0
pix_format: 0
buffer_num: 0
buffer_size: 0
yraw_size: 0
uv_size: 0
v_size: 0
block_type: 0
wait_time: 0
chn_enable: 0
oslayer assert /builds/maix_sw/k230_sdk/src/big/mpp/userapps/src/vicap/src/isp/sdk/units/oslayer/source/oslayer_generic.c, 357  pQueue == NULL
[E/DBG] [FATAL ERROR] Exception 13:Load Page Fault
[E/DBG] scause:0x000000000000000d,stval:0x000000000000005c,sepc:0x0000000200091344
--------------Dump Registers-----------------
Function Registers:
        ra(x1) = 0x0000000200091340()
        user_sp(x2) = 0x000000010082edd0()
        gp(x3) = 0x0000000000000000()
        tp(x4) = 0x000000010082efe8()
Temporary Registers:
        t0(x5) = 0x0000000000000084()
        t1(x6) = 0x0000000000000007()
        t2(x7) = 0x0000000000000050()
        t3(x28) = 0x0000000000000072()
        t4(x29) = 0x000000000000008f()
        t5(x30) = 0x000000000000000e()
        t6(x31) = 0x000000000000000e()
Saved Registers:
        s0/fp(x8) = 0x000000010082ee00()
        s1(x9) = 0x000000010082eee0()
        s2(x18) = 0x000000010082efe8()
        s3(x19) = 0x00000002ffffe458()
        s4(x20) = 0x000000000000000c()
        s5(x21) = 0x0000000000000000()
        s6(x22) = 0x0000000200091ca8()
        s7(x23) = 0x00000003000f77e0()
        s8(x24) = 0x000000010082ef08()
        s9(x25) = 0x000000020025ac00()
        s10(x26) = 0x00000002ffffe5d8()
        s11(x27) = 0x000000010080c000()
Function Arguments Registers:
        a0(x10) = 0x0000000000000016()
        a1(x11) = 0x0000000000000001()
        a2(x12) = 0x0000000000000000()
        a3(x13) = 0x000000000000000c()
        a4(x14) = 0x0000000000000030()
        a5(x15) = 0x0000000000000000()
        a6(x16) = 0x0000000000000000()
        a7(x17) = 0x0000000000000000()
sstatus = 0x8000000200046620
        Supervisor Interrupt Disabled
        Last Time Supervisor Interrupt Enabled
        Last Privilege is User Mode
        Permit to Access User Page
        Not Permit to Read Executable-only Page
satp = 0x80000000000047c6
        Current Page Table(Physical) = 0x00000000047c6000
        Current ASID = 0x0000000000000000
        Mode = Page-based 39-bit Virtual Addressing Mode
-----------------Dump OK---------------------
riscv64-unknown-linux-musl-addr2line -e camera_capture_run -a -f 0000000200091340 00000002001dcb84 0000000200091cd2 000000020021c552Unhandled Exception 13:Load Page Fault
scause:0x000000000000000d,stval:0xfffffffffffffff8,sepc:0x000000000019bc60
Function Registers:
        ra(x1) = 0x000000000019bc8e()
        user_sp(x2) = 0x0000000000411318()
        gp(x3) = 0x0000000000401e58()
        t0(x5) = 0x0000000000411220()
        t1(x6) = 0x00000000004e45b0()
        t2(x7) = 0x0000000000000080()
        t3(x28) = 0x00000000003ceb80()
        t4(x29) = 0x0000000000000030()
        t5(x30) = 0x0000000000000000()
        t6(x31) = 0x0000000000411228()
Saved Registers:
        s0/fp(x8) = 0x0000000000411368()
        s1(x9) = 0x000000000000000d()
        s2(x18) = 0x0000000200091344()
        s3(x19) = 0x00000000004113d8()
        s4(x20) = 0x000000000000005c()
        a0(x10) = 0x0000000000000011()
        a1(x11) = 0x0000000000000032()
        a2(x12) = 0x00000000004e45a8()
        a3(x13) = 0x00000000c0007000()
        a4(x14) = 0x0000000000000000()
        a5(x15) = 0xfffffffffffffff8()
        a6(x16) = 0x00000000004e45b9()
        a7(x17) = 0x0000000000000032()
sstatus = 0x8000000200044700
        Last Time Supervisor Interrupt Disabled
        Last Privilege is Supervisor Mode
--------------Thread list--------------
current thread: camera_capture_run
PID  CMD                  thread               pri  status      sp     stack size max used left tick  error
     kernel               vpu_task              12  suspend 0x000004f8 0x00002000    34%   0x00000002 -09
     kernel               cmd_thread             6  suspend 0x00000558 0x00005000    12%   0x00000001 -09
     kernel               xmit_thread            7  suspend 0x00000528 0x00005000    06%   0x0000000a -09
     kernel               usbh_rtl8152_rx       15  suspend 0x00000598 0x00001000    41%   0x0000000a -09
     kernel               dwc2_lo_prio_bh        1  suspend 0x000004f8 0x00005000    06%   0x00000009 000
     kernel               dwc2_hi_prio_bh        0  suspend 0x000004f8 0x00005000    06%   0x00000008 000
     kernel               dwc2                  16  suspend 0x000004f8 0x00005000    06%   0x0000000a 000
     kernel               sdio_irq               4  suspend 0x000004f8 0x00002800    29%   0x00000006 -09
     kernel               mtp                   16  suspend 0x00000508 0x00005000    20%   0x00000006 -09
     kernel               mtp_inty              16  suspend 0x000007a8 0x00005000    13%   0x0000000a -09
     kernel               usbh_hub0             14  suspend 0x000005a8 0x00001000    48%   0x00000006 -09
     kernel               tshell                20  ready   0x000008b8 0x00014000    04%   0x00000001 -02
     kernel               thermal_detect_threa  29  suspend 0x000004d8 0x00002800    13%   0x0000000a -09
     kernel               auto_load_thread      29  suspend 0x00000498 0x00002800    12%   0x0000000a 000
     kernel               sys workq             17  suspend 0x00000598 0x00005000    07%   0x0000000a -09
     kernel               wlan                  15  suspend 0x000004f8 0x00001000    31%   0x0000000a 000
     kernel               mmcsd_detect          22  suspend 0x00000558 0x00008000    09%   0x00000014 -09
     kernel               tcpip                 10  suspend 0x00000578 0x00002800    14%   0x00000014 -09
     kernel               etx                   12  suspend 0x00000538 0x00002800    13%   0x00000010 -09
     kernel               erx                   12  suspend 0x00000558 0x00002800    18%   0x00000010 -09
     kernel               tsystem               30  suspend 0x000004f8 0x00004000    08%   0x00000020 -09
     kernel               tidle0                31  ready   0x00000448 0x00004000    06%   0x00000016 000
     kernel               timer                  4  suspend 0x000004d8 0x00004000    14%   0x00000009 -09
   2 ./camera_capture_run camera_capture_run     0  running 0x00000950 0x00004000    25%   0x000000bb 022
   2 ./camera_capture_run camera_capture_run     0  suspend 0x00000900 0x00004000    24%   0x0000009a 000
   2 ./camera_capture_run camera_capture_run     0  suspend 0x00000900 0x00004000    24%   0x000000c5 000
   2 ./camera_capture_run camera_capture_run     0  suspend 0x00000900 0x00004000    24%   0x000000c8 000
   2 ./camera_capture_run camera_capture_run     0  suspend 0x00000900 0x00004000    24%   0x000000c4 000
   2 ./camera_capture_run camera_capture_run     0  ready   0x00000900 0x00004000    25%   0x000000be -02
   2 ./camera_capture_run camera_capture_run     0  ready   0x00000950 0x00004000    24%   0x000000c2 000
   2 ./camera_capture_run camera_capture_run    25  ready   0x00000428 0x00004000    25%   0x00000045 000
--------------Backtrace--------------
riscv64-unknown-linux-musl-addr2line -e rtthread.elf -a -f 000000000019bc5c
1.simple_mpp_vb_init 只初始化了一个通道的vb,既然创建了三个sensor,vb也要分配足够多。
2.分别启动三路sensor的每一路的第0路通道。
3.建议你先把编码部分去掉,减少模块进一步调试。
