如何提取yolov8分割的掩码图像
Viewed 260
在K230部署yolov8分割模型进行裂缝分割,想从分割的掩码图像中找到裂缝的轮廓,但是提取的掩码图像有检测框,该怎么提取出不包含检测框的分割后的掩码图像。代码是这样的,该怎么修改呢
        x1, y1, w, h = map(int, det)
        x1 = max(0, x1)
        y1 = max(0, y1)
        x2 = min(self.display_size[0], x1 + w)
        y2 = min(self.display_size[1], y1 + h)
        # 提取Alpha通道并二值化
        mask_region = self.masks[0, y1:y2, x1:x2, 3]
        binary_mask = np.array(np.where(mask_region > 0, 255, 0), dtype=np.uint8)
        binary_bytes = binary_mask.tobytes()
        # 转换为图像对象(假设是单通道)
        H, W = binary_mask.shape[0], binary_mask.shape[1]
        print(f"H:{H},W:{W}")
        img_mask = image.Image(W, H, image.GRAYSCALE, alloc=image.ALLOC_REF, data=binary_bytes)
        img_mask.save("/data/mask_debug.jpg")
        edges = img_mask.find_edges(image.EDGE_CANNY)
        img_mask.save("/data/mask_edges.jpg")
# 自定义YOLOv8分割类
class SegmentationApp(AIBase):
    def __init__(self,task_type="segment",mode="video",kmodel_path="",labels=[],rgb888p_size=[320,320],model_input_size=[320,320],display_size=[1920,1080],conf_thresh=0.5,nms_thresh=0.45,mask_thresh=0.5,max_boxes_num=50,debug_mode=0):
#        if task_type not in ["classify","detect","segment"]:
#            print("Please select the correct task_type parameter, including 'classify', 'detect', 'segment'.")
#            return
        self.task_type=task_type
        self.mode=mode
        # 模型路径
        self.kmodel_path=kmodel_path
        # 分割类别标签
        self.labels=labels
        self.class_num=len(labels)
        # sensor给到AI的图像分辨率
        if mode=="video":
            self.rgb888p_size=[rgb888p_size[0],rgb888p_size[1]]
        # 模型输入分辨率
        # 显示分辨率
        # 置信度阈值
        self.conf_thresh=conf_thresh
        # nms阈值
        self.nms_thresh=nms_thresh
        # mask阈值
        self.mask_thresh=mask_thresh
        self.debug_mode=debug_mode
        self.scale=1.0
        self.colors=get_colors(len(self.labels))
        self.masks=None
        self.sock = None  # Socket连接对象
        self.last_heartbeat = time.ticks_ms()
#        self.widths_info = []  # 新增:存储宽度信息
        if self.task_type=="segment":
            if self.mode=="image":
                self.masks=np.zeros((1,self.rgb888p_size[1],self.rgb888p_size[0],4),dtype=np.uint8)
            elif self.mode=="video":
                self.masks=np.zeros((1,self.display_size[1],self.display_size[0],4),dtype=np.uint8)
        # Ai2d实例,用于实现模型预处理
        self.ai2d=Ai2d(self.debug_mode)
        # 设置Ai2d的输入输出格式和类型
#        # 初始化UART串口
#        self.uart = UART(UART.UART1,baudrate=115200) #设置串口号1和波特率
            top,bottom,left,right,scale=letterbox_pad_param(self.rgb888p_size,self.model_input_size)
            # build参数包含输入shape和输出shape
    # 自定义当前任务的后处理
            new_result=results[0][0].transpose()
                seg_res = aidemo.yolov8_seg_postprocess(new_result.copy(),results[1][0],[self.rgb888p_size[1],self.rgb888p_size[0]],[self.model_input_size[1],self.model_input_size[0]],[self.rgb888p_size[1],self.rgb888p_size[0]],len(self.labels),self.conf_thresh,self.nms_thresh,self.mask_thresh,self.masks)
                seg_res = aidemo.yolov8_seg_postprocess(new_result.copy(),results[1][0],[self.rgb888p_size[1],self.rgb888p_size[0]],[self.model_input_size[1],self.model_input_size[0]],[self.display_size[1],self.display_size[0]],len(self.labels),self.conf_thresh,self.nms_thresh,self.mask_thresh,self.masks)
            return seg_res
    def calculate_crack_width_2(self, det):
        从分割掩模中提取裂缝边缘并计算宽度
#        x1, y1, w, h = map(int, det)
        x1, y1, w, h = map(lambda x: int(round(x, 0)), det)
        x1 = max(0, x1)
        y1 = max(0, y1)
        # 提取Alpha通道并二值化
        mask_data = self.masks[0, y1:y2, x1:x2, 3]
        # 裁剪出裂缝区域
#        roi = mask_data[y1:y1+h, x1:x1+w]
#        roi = roi * 255
#        roi_uint8 = np.array(roi, dtype=np.uint8)
        roi_uint8 = np.array(np.where(mask_data > 0, 255, 0), dtype=np.uint8)  # 确保数据是 uint8 类型并转换为 bytes
        roi_bytes = roi_uint8.tobytes()
        # 转换为图像对象(假设是单通道)
        H, W = mask_data.shape[0], mask_data.shape[1]
        img_mask = image.Image(W, H, image.GRAYSCALE, alloc=image.ALLOC_REF, data=roi_bytes)
        # 查找裂缝区域
        thresholds = [(127, 255)]
        blobs = img_mask.find_blobs(thresholds, area_threshold=100, merge=True)
#        edges = img_mask.find_edges(image.EDGE_CANNY)
#        print(blobs)
        if blobs:
            blob = max(blobs, key=lambda b: b.area())
            print("blob.rect():", blob.rect())          # 输出 (x, y, w, h)
            print("blob.area():", blob.area())          # 输出 blob 面积
            print("blob.pixels():", blob.pixels())
            x_blob, y_blob, w_blob, h_blob = blob.rect()
            width = min(w_blob, h_blob)
            # 可选:像素到毫米转换
            pixel_to_mm = 0.007625  # 示例值,应根据实际标定
            width = width * pixel_to_mm
            return width
            print("未检测到裂缝区域")
            return 0
    # 绘制结果
    def draw_result(self, res, img):
        with ScopedTiming("draw result", self.debug_mode > 0):
            if self.mode == "video":
                if res[0]:
                    img.clear()
                    mask_img = image.Image(self.display_size[0], self.display_size[1], image.ARGB8888, alloc=image.ALLOC_REF, data=self.masks)
                    img.copy_from(mask_img)
                    dets, ids, scores = res[0], res[1], res[2]
                    for i, det in enumerate(dets):
                        width = self.calculate_crack_width_2(det)
                        cx = x1 + w//2
                        cy = y1 + h//2
                        print("width:",width)
                        display_text = f" {self.labels[int(ids[i])]} Width: {width}mm"
                        img.draw_string_advanced(x1, y1 - 50, 32, display_text, color=self.colors[int(ids[i])])
                    img.clear()
            elif self.mode == "image":
                if res[0]:
                    mask_rgb = self.masks[0, :, :, 1:4]
                    mask_img = image.Image(self.rgb888p_size[0], self.rgb888p_size[1], image.RGB888, alloc=image.ALLOC_REF, data=mask_rgb.copy())
                        x, y, w, h = map(lambda x: int(round(x, 0)), det)
                        width = self.calculate_crack_width_1(det)
                        display_text = f" {self.labels[int(ids[i])]} {round(scores[i], 2)} Width: {width}mm"
                        mask_img.draw_string_advanced(x, y - 50, 32, display_text, color=self.colors[int(ids[i])])
                    mask_img.compress_for_ide()
                    img.clear()
    # 多目标检测 非最大值抑制方法实现
    def nms(self,boxes,scores,thresh):
        x1,y1,x2,y2 = boxes[:, 0],boxes[:, 1],boxes[:, 2],boxes[:, 3]
        keep = []
        while order.size > 0:
            i = order[0]
            keep.append(i)
            new_x1,new_y1,new_x2,new_y2,new_areas = [],[],[],[],[]
            for order_i in order:
                new_x1.append(x1[order_i])
                new_x2.append(x2[order_i])
                new_y1.append(y1[order_i])
                new_y2.append(y2[order_i])
            new_x1 = np.array(new_x1)
            new_x2 = np.array(new_x2)
            new_y1 = np.array(new_y1)
            new_y2 = np.array(new_y2)
            inter = w * h
            new_order = []
                if ind < thresh:
        return keep
#    uart.write('Hello 01Studio!')#发送一条数据
    print("裂缝检测启动...")
    #显示
    display_mode="lcd"
    rgb888p_size=[640,640]
    if display_mode=="hdmi":
        display_size=[800,480]
    #模型配置
    labels = ["Crack"]
    confidence_threshold = 0.5
    nms_threshold=0.45
    mask_threshold=0.5
    # 初始化PipeLine
    # 初始化YOLOv8实例
   yolo=SegmentationApp(task_type="segment",mode="video",kmodel_path=kmodel_path,labels=labels,rgb888p_size=rgb888p_size,model_input_size=model_input_size,display_size=display_size,conf_thresh=confidence_threshold,nms_thresh=nms_threshold,mask_thresh=mask_threshold,max_boxes_num=50,debug_mode=0)
    yolo.config_preprocess()
    check = 0
            with ScopedTiming("total",1):
                # 逐帧推理
                check = check+1
                img=pl.get_frame()
                res=yolo.run(img)
                pl.show_image()
                time.sleep(0.1) #100ms
        print("发生错误:", e)
        yolo.deinit()
        print("系统已关闭")
你是用的YOLO库实现的吗
是的
代码补充在问题里了
