求助,K230的SPI通信连接失败
Viewed 55
我使用两个K230,意象建立SPI通信,但是目前一个发送成功,但是另外一边没有接收到
1.我使用的代码,和历程的SPI一致,只是包装成了接口函数
2.两个可执行文件初始化一致
    SPI_Config cfg = {.mode = 0, .cs_pin = 0, .speed_hz = 10000000};
    if (!SPI::Init("spi0", &cfg)) {
        printf("SPI init failed!\n");
        return -1;
3.发送端的部分代码:
        const char* tx_buf = "333666";
        size_t length = 6;
        if (SPI_Write(tx_buf, length) < 0) {
            printf("SPI_Write failed!\n");
            return -1;
4.接收端的部分代码:
        uint8_t rx_buf[6] = {0};
        size_t length = 6;
        if (SPI_Read(rx_buf, length) < 0) {
            printf("SPI_Read failed!\n");
            return -1;
        printf("Received: ");
        for (int i = 0; i < length; i++) {
            printf("%02X ", rx_buf[i]);
        printf("\n");
5.接收端调试信息一直显示00 00 00 00 00 00
发送端一直发送
6.除了代码外,我还怀疑是dts文件配置IO口可能不是SPI,但是我不清楚这个怎么配置
/dts-v1/;
#include <dt-bindings/pinctrl/k230-pinctrl.h>
#define BANK_VOLTAGE_IO0_IO1	 K230_MSC_1V8  // FIXED
#define BANK_VOLTAGE_IO2_IO13	 K230_MSC_3V3
#define BANK_VOLTAGE_IO14_IO25	 K230_MSC_3V3
#define BANK_VOLTAGE_IO26_IO37	 K230_MSC_3V3
#define BANK_VOLTAGE_IO38_IO49	 K230_MSC_3V3
#define BANK_VOLTAGE_IO50_IO61	 K230_MSC_3V3
#define BANK_VOLTAGE_IO62_IO63	 K230_MSC_1V8
#include "k230.dtsi"
	model = "kendryte k230 canmv 01studio";
	compatible = "kendryte,k230_canmv_01studio";
	memory@0 {
		device_type = "memory";
		reg = <
				0x0 0 0x0 0x40000000
&mmc0 {
	status = "okay";
&usbotg0 {
	status = "okay";
&iomux {
	pinctrl-names = "default";
	pinctrl-0 = <&pins>;
//	Please pay attention to the bank voltage! will damage the chip.
	pins: iomux_pins {
		u-boot,dm-pre-reloc;
		pinctrl-single,pins = <
		// S3 KEY
		(IO0 ) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO0_IO1 <<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 2<<DS | 0<<ST )
		(IO1 ) ( 1<<SEL | 0<<SL | BANK_VOLTAGE_IO0_IO1 <<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 2<<DS | 0<<ST )
		// JP1-PIN7 JTAG
		(IO2 ) ( 1<<SEL | 0<<SL | BANK_VOLTAGE_IO2_IO13 <<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 4<<DS | 0<<ST )
		(IO3 ) ( 3<<SEL | 0<<SL | BANK_VOLTAGE_IO2_IO13 <<MSC | 0<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
		(IO4 ) ( 3<<SEL | 0<<SL | BANK_VOLTAGE_IO2_IO13 <<MSC | 1<<IE | 0<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
		(IO5 ) ( 1<<SEL | 0<<SL | BANK_VOLTAGE_IO2_IO13 <<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 4<<DS | 0<<ST )
		(IO6 ) ( 1<<SEL | 0<<SL | BANK_VOLTAGE_IO2_IO13 <<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 4<<DS | 0<<ST )
		// CAM2_I2C4_SCL
		(IO7 ) ( 2<<SEL | 0<<SL | BANK_VOLTAGE_IO2_IO13 <<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
		// CAM2_I2C4_SDA
		(IO8 ) ( 2<<SEL | 0<<SL | BANK_VOLTAGE_IO2_IO13 <<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
		// CAM0_GPIO9
		(IO9 ) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO2_IO13 <<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
		// CAM0_GPIO10
		(IO10) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO2_IO13 <<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 8<<DS | 0<<ST )
		// GPIO11
		(IO11) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO2_IO13 <<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 8<<DS | 0<<ST )
		// GPIO12
		(IO12) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO2_IO13 <<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 8<<DS | 0<<ST )
		(IO13) ( 1<<SEL | 0<<SL | BANK_VOLTAGE_IO2_IO13 <<MSC | 0<<IE | 1<<OE | 0<<PU | 1<<PD | 4<<DS | 1<<ST )
		// GPIO14 ~ GPIO20
		(IO14) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO14_IO25<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 15<<DS | 1<<ST )
		(IO15) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO14_IO25<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 15<<DS | 1<<ST )
		(IO16) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO14_IO25<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 15<<DS | 1<<ST )
		(IO17) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO14_IO25<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 15<<DS | 1<<ST )
		(IO18) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO14_IO25<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 15<<DS | 1<<ST )
		(IO19) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO14_IO25<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 15<<DS | 1<<ST )
		(IO20) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO14_IO25<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 15<<DS | 1<<ST )
		// KEY_GPIO21
		(IO21) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO14_IO25<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 15<<DS | 1<<ST )
		// TP_RST - HDMI_RSTN
		(IO22) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO14_IO25<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 15<<DS | 1<<ST )
		// TP_INT - HDMI_INT
		(IO23) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO14_IO25<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 15<<DS | 1<<ST )
		// LCD_RST
		(IO24) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO14_IO25<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 15<<DS | 1<<ST )
		// LCD_EN
		(IO25) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO14_IO25<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
		(IO26) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO26_IO37<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
		(IO27) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO26_IO37<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
		(IO28) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO26_IO37<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
		(IO29) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO26_IO37<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
		(IO30) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO26_IO37<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
		(IO31) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO26_IO37<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
		// GPIO32 ~ GPIO35
		(IO32) ( 2<<SEL | 0<<SL | BANK_VOLTAGE_IO26_IO37<<MSC | 0<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
		(IO33) ( 2<<SEL | 0<<SL | BANK_VOLTAGE_IO26_IO37<<MSC | 0<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
		(IO34) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO26_IO37<<MSC |	1<<IE | 0<<OE | 0<<PU | 1<<PD | 7<<DS | 0<<ST )
		(IO35) ( 2<<SEL | 0<<SL | BANK_VOLTAGE_IO26_IO37<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
		// TP_I2C3_SC - HDMI_CSCL
		(IO36) ( 1<<SEL | 0<<SL | BANK_VOLTAGE_IO26_IO37<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 3<<DS | 1<<ST )
		// TP_I2C3_SDA - HDMI_CSDA
		(IO37) ( 1<<SEL | 0<<SL | BANK_VOLTAGE_IO26_IO37<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 3<<DS | 1<<ST )
		// UART0_TXD
		(IO38) ( 1<<SEL | 0<<SL | BANK_VOLTAGE_IO38_IO49<<MSC | 0<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
		// UART0_RXD
		(IO39) ( 1<<SEL | 0<<SL | BANK_VOLTAGE_IO38_IO49<<MSC | 1<<IE | 0<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
		// I2C1_SCL -> camera
		(IO40) ( 2<<SEL | 0<<SL | BANK_VOLTAGE_IO38_IO49<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
		// I2C1_SDA -> camera
		(IO41) ( 2<<SEL | 0<<SL | BANK_VOLTAGE_IO38_IO49<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
		// GPIO42
		(IO42) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO38_IO49<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
		// GPIO43
		(IO43) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO38_IO49<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
		// CAM1_GPIO44
		(IO44) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO38_IO49<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
		// CAM1_GPIO45
		(IO45) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO38_IO49<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
		// GPIO46
		(IO46) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO38_IO49<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
		// GPIO47
		(IO47) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO38_IO49<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
		//iic0
		(IO48) ( 3<<SEL | 0<<SL | BANK_VOLTAGE_IO38_IO49<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
		(IO49) ( 3<<SEL | 0<<SL | BANK_VOLTAGE_IO38_IO49<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
		// UART3_TXD
		(IO50) ( 1<<SEL | 0<<SL | BANK_VOLTAGE_IO50_IO61<<MSC | 0<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
		// UART3_RXD
		(IO51) ( 1<<SEL | 0<<SL | BANK_VOLTAGE_IO50_IO61<<MSC | 1<<IE | 0<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
		// LED_GPIO52
		(IO52) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO50_IO61<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
		// WIFI_REGON
		(IO53) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO50_IO61<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
		// MMC1 -> WIFI
		(IO54) ( 2<<SEL | 0<<SL | BANK_VOLTAGE_IO50_IO61<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
		(IO55) ( 2<<SEL | 0<<SL | BANK_VOLTAGE_IO50_IO61<<MSC | 0<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
		(IO56) ( 2<<SEL | 0<<SL | BANK_VOLTAGE_IO50_IO61<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
		(IO57) ( 2<<SEL | 0<<SL | BANK_VOLTAGE_IO50_IO61<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
		(IO58) ( 2<<SEL | 0<<SL | BANK_VOLTAGE_IO50_IO61<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
		(IO59) ( 2<<SEL | 0<<SL | BANK_VOLTAGE_IO50_IO61<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
		(IO60) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO50_IO61<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
		(IO61) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO50_IO61<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
		// CAM2_RST
		(IO62) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO62_IO63<<MSC | 0<<IE | 1<<OE | 0<<PU | 1<<PD | 4<<DS | 1<<ST )
		// CAM2_MCLK
		(IO63) ( 1<<SEL | 0<<SL | BANK_VOLTAGE_IO62_IO63<<MSC | 0<<IE | 1<<OE | 0<<PU | 1<<PD | 4<<DS | 1<<ST )
7.平台是01Studio,用的是RTOS的SDK,RT-Smart
连线按照其图纸:
连接SPI0的MOSI、MISO、CS0、SCLK,互相连接
求助大佬帮忙解答!
而且我看你的应用,其中一个230应该做spi从机,但是230的驱动目前是不支持spi从机的。
K230不支持主从配置呀,那建议使用什么进行快速通信呢,感谢大佬解答
用串口吧……
也可以用usb
你好,可以参考https://www.kendryte.com/k230_rtos/zh/main/api_reference/peripheral/spi.html 这个需要拉最新的sdk
