K230庐山派代码求助,求求各位大佬
Viewed 1090
求助大佬,为了做21年送药小车电赛题我写了个循迹的代码又在在线平台上训练了个数字识别的模型,这两份代码单独运行都好好的,但是怎么弄都不能把这两份代码合在一个程序里面运行,怎么改都有报错,ai也问了,弄了好久好久,求解答
from media.sensor import *  # 导入sensor模块,使用摄像头相关接口
from media.display import *  # 导入display模块,使用display相关接口
from media.media import *    # 导入media模块,使用media相关接口
from machine import UART, FPIOA, Pin
# FPIOA 和 UART 初始化
fpioa.set_function(53, FPIOA.GPIO53)
KEY = Pin(53, Pin.IN, Pin.PULL_DOWN)
uart = UART(UART.UART2, baudrate=115200, bits=UART.EIGHTBITS, parity=UART.PARITY_NONE, stop=UART.STOPBITS_ONE)
# 红色检测阈值
thresholds = [(23, 57, 30, 127, -128, 127)]
# 摄像头与显示初始化
sensor = Sensor(width=1280, height=720)
sensor.set_framesize(width=800, height=480)
Display.init(Display.ST7701, to_ide=True)
# 中间三条 ROI (权重)
ROIS1 = [
    (225,   0,   400, 160, 0.3),
    (225, 160,   400, 160, 0.35),
    (225, 320,   400, 160, 0.35),
# 左右检测 ROI
ROIS2 = [
    (0,   150, 250, 300),  # 左
    (550, 150, 250, 300),  # 右
# 状态变量
key_flag = 0
flag = 0
turn_flag = 0
move_record = []       # 拐弯记录
return_mode = False    # 去程/回程模式
current_index = 0
cross_detected = False # 上一帧是否检测到十字
num = 1               # 模拟外部识别(1=左转, 2=右转, else 直行)
# 计算红线偏差函数
def calculate_error(blobs, rois):
    global flag, turn_flag
    detected_any = False
    weight_sum = 0
    centroid_sum = 0
    for i, roi in enumerate(rois):
        if blobs[i]:
            detected_any = True
            largest = max(blobs[i], key=lambda b: b.pixels())
            img.draw_rectangle(largest.x(), largest.y(), largest.w(), largest.h(), (0,0,255))
            centroid_sum += largest.cx() * roi[4]
            weight_sum += roi[4]
    flag = 1 if detected_any else 0
    if weight_sum:
        center_x = centroid_sum/weight_sum
        dx = center_x - 400
        if dx > 0:
            turn_flag = 1
            dx = -dx
            turn_flag = 2
        return dx
    return 0
def filter_blob(blob):
    # 忽略面积小或位于特定位置的 blob
    if blob.pixels() < 2000:
        return False
    if 140 < blob.cx() < 160 and 240 < blob.cy() < 260:
        return False
    if 640 < blob.cx() < 660 and 240 < blob.cy() < 260:
        return False
    return True
    img = sensor.snapshot()
    # 中间 ROI 检测
    mid_blobs = [img.find_blobs(thresholds, roi=roi[:4], merge=True) for roi in ROIS1]
    delta_pos_x = int(calculate_error(mid_blobs, ROIS1))
    # 按键切换模式
    if KEY.value() == 1:
        if flag == 0:
            return_mode = True
            current_index = len(move_record)-1
            print("切换到回程模式")
            return_mode = False
            move_record.clear()
            print("切换到正常模式")
        key_flag = 1 - key_flag
        time.sleep_ms(300)
    # 画出所有 ROI 框
    for r in ROIS1 + ROIS2:
        img.draw_rectangle(r[0], r[1], r[2], r[3], (255,0,0))
    if key_flag:
        img.draw_string(0,0, 'RUNNING', color=(255,0,0), scale=5)
        # 1. 检测左右色块
        left = img.find_blobs(thresholds, roi=ROIS2[0], merge=True)
        right = img.find_blobs(thresholds, roi=ROIS2[1], merge=True)
        # 2. 过滤不合格的 blob
        left = [b for b in left if filter_blob(b)]
        right = [b for b in right if filter_blob(b)]
        # 3. 可视化与调试输出
        if left:
            lb = max(left, key=lambda b: b.pixels())
            img.draw_rectangle(lb.x(), lb.y(), lb.w(), lb.h(), (255,0,0))
            print(f"✔ 左红块:cx={lb.cx()}, cy={lb.cy()}, area={lb.pixels()}")
            print("✘ 左红块未检测到")
        if right:
            rb = max(right, key=lambda b: b.pixels())
            img.draw_rectangle(rb.x(), rb.y(), rb.w(), rb.h(), (255,0,0))
            print(f"✔ 右红块:cx={rb.cx()}, cy={rb.cy()}, area={rb.pixels()}")
            print("✘ 右红块未检测到")
        is_cross = bool(left and right)
        # 自动进入回程
        if flag==0 and not return_mode:
            return_mode = True
            print("自动切换到回程模式")
        # 模拟外部动作
        move_prepare = 1 if num==1 else (3 if num==2 else 2)
        # 十字边沿检测
        # 只在首次进入十字时记录路径(去程)
        if is_cross and not cross_detected:
            print("检测到十字边沿,记录动作")
            if not return_mode:
                if move_prepare == 1:
                    move_record.append(1)  # 左
                elif move_prepare == 3:
                    move_record.append(3)  # 右
                    move_record.append(2)  # 直行
                print("记录动作:", move_record)
                if current_index >= 0:
                    print(f"回程:准备执行动作 {move_record[current_index]}")
            # 注意这里只记录,不执行转弯
        #  只要当前帧处于十字,就执行转弯(持续输出)
        if is_cross:
            if not return_mode:
                    delta_pos_x = 400
                    turn_flag = 2  # 左转
                    delta_pos_x = 400
                    turn_flag = 1  # 右转
                    delta_pos_x = 0
                    turn_flag = 0  # 直行
                    m = move_record[current_index]
                    if m == 1:
                        delta_pos_x = 410
                        turn_flag = 1  # 左转
                    elif m == 3:
                        delta_pos_x = 400
                        turn_flag = 2  # 右转
                        delta_pos_x = 0
                        turn_flag = 0  # 直行
        # 状态更新放在最后
        cross_detected = is_cross
        # 串口输出
        print(f"[DEBUG] dx={delta_pos_x}, flag={flag}, turn_flag={turn_flag}, 记录路径={move_record}")
        uart.write(f"S:{num},{delta_pos_x},{flag},{turn_flag}\n".encode())
以上是循迹部分的代码
import os, gc
# Set display mode: options are 'hdmi', 'lcd', 'lt9611', 'st7701', 'hx8399'
# 'hdmi' defaults to 'lt9611' (1920x1080); 'lcd' defaults to 'st7701' (800x480)
display_mode = "lcd"
# Define the input size for the RGB888P video frames
rgb888p_size = [1280, 720]
# Set root directory path for model and config
# Load deployment configuration
kmodel_path = root_path + deploy_conf["kmodel_path"]              # KModel path
labels = deploy_conf["categories"]                                # Label list
confidence_threshold = deploy_conf["confidence_threshold"]        # Confidence threshold
nms_threshold = deploy_conf["nms_threshold"]                      # NMS threshold
model_input_size = deploy_conf["img_size"]                        # Model input size
nms_option = deploy_conf["nms_option"]                            # NMS strategy
model_type = deploy_conf["model_type"]                            # Detection model type
anchors = []
# Inference configuration
inference_mode = "video"                                          # Inference mode: 'video'
debug_mode = 0                                                    # Debug mode flag
# Create and initialize the video/display pipeline
# Initialize object detection application
det_app = DetectionApp(inference_mode,kmodel_path,labels,model_input_size,anchors,model_type,confidence_threshold,nms_threshold,rgb888p_size,display_size,debug_mode=debug_mode)
# Configure preprocessing for the model
det_app.config_preprocess()
# Main loop: capture, run inference, display results
        img = pl.get_frame()                          # Capture current frame
        res = det_app.run(img)                        # Run inference
        det_app.draw_result(pl.osd_img, res)          # Draw detection results
        pl.show_image()                               # Show result on display
        gc.collect()                                  # Run garbage collection
# Cleanup: These lines will only run if the loop is interrupted (e.g., by an IDE break or external interruption)
det_app.deinit()                                      # De-initialize detection app
pl.destroy()                                          # Destroy pipeline instance
以上就是训练平台给的代码
import os, gc
# 定义 RGB888P 视频帧的输入尺寸
# 设置模型和配置文件的根目录路径
# 加载部署配置
kmodel_path = root_path + deploy_conf["kmodel_path"]              # KModel 文件路径
labels = deploy_conf["categories"]                                # 标签列表
confidence_threshold = deploy_conf["confidence_threshold"]        # 置信度阈值
nms_threshold = deploy_conf["nms_threshold"]                      # 非极大值抑制阈值
model_input_size = deploy_conf["img_size"]                        # 模型输入尺寸
nms_option = deploy_conf["nms_option"]                            # NMS 策略
model_type = deploy_conf["model_type"]                            # 检测模型类型
anchors = []
# 推理配置
inference_mode = "video"                                          # 推理模式:'video'
debug_mode = 0                                                    # 调试模式标志
# 创建并初始化视频/显示流水线
# 初始化目标检测应用
det_app = DetectionApp(inference_mode, kmodel_path, labels, model_input_size, anchors, model_type, confidence_threshold, nms_threshold, rgb888p_size, display_size, debug_mode=debug_mode)
# 配置模型的预处理参数
# FPIOA 和 UART 初始化
# 红色检测阈值
# 摄像头与显示初始化(避免重复初始化,使用标准分辨率常量)
sensor = Sensor()                     # 直接初始化,避免传参导致重复初始化错误
sensor.set_framesize(sensor.QVGA)    # 320x240,摄像头支持的标准分辨率,可改为 VGA、QVGA 等
# 中间三条 ROI (权重)
ROIS1 = [
# 左右检测 ROI
ROIS2 = [
# 状态变量
key_flag = 0
flag = 0
turn_flag = 0
current_index = 0
# 计算红线偏差函数
    weight_sum = 0
    centroid_sum = 0
        if blobs[i]:
            detected_any = True
    if weight_sum:
        dx = center_x - 400
        if dx > 0:
            turn_flag = 1
            dx = -dx
            turn_flag = 2
        return dx
    return 0
        return False
        return False
        return False
    return True
    # 处理目标检测结果
    scores = res['scores']
    idxs = res['idx']
    boxes = res['boxes']
    for i in range(len(idxs)):
        class_id = idxs[i]
        score = scores[i]
        box = boxes[i]
        name = labels[class_id]
        print(f"检测到物品: {name}, 置信度: {score:.2f}, 位置: {box}")
    # 中间 ROI 检测
    # 按键切换模式
        if flag == 0:
            return_mode = True
            print("切换到回程模式")
            return_mode = False
            move_record.clear()
            print("切换到正常模式")
        time.sleep_ms(300)
    # 画出所有 ROI 框
    if key_flag:
        # 1. 检测左右色块
        # 2. 过滤不合格的 blob
        # 3. 可视化与调试输出
        if left:
            print("✘ 左红块未检测到")
        if right:
            print("✘ 右红块未检测到")
        # 自动进入回程
            return_mode = True
            print("自动切换到回程模式")
        # 模拟外部动作
        # 十字边沿检测
            if not return_mode:
            # 这里只记录,不执行转弯
        if is_cross:
            if not return_mode:
                    delta_pos_x = 400
                    turn_flag = 2  # 左转
                    delta_pos_x = 400
                    turn_flag = 1  # 右转
                    delta_pos_x = 0
                    turn_flag = 0  # 直行
                    if m == 1:
                        delta_pos_x = 410
                        turn_flag = 1  # 左转
                    elif m == 3:
                        delta_pos_x = 400
                        turn_flag = 2  # 右转
                        delta_pos_x = 0
                        turn_flag = 0  # 直行
        # 串口输出
以上是我自己写的合在一起的版本但是这个报错我不知道该怎么改,求大佬解答,真的球球了
  File "<stdin>", line 58, in <module>
  File "media/sensor.py", line 1, in __init__
OSError: sensor(2) is already inited.
MPY: soft reboot
CanMV v1.2.2(based on Micropython e00a144) on 2025-06-16; k230_canmv_lckfb with K230
代码已经在群里发给你了,同时附在这里:
import time, gc, _thread, ujson
# ---------- 全局配置 ----------
sensor=None
display_size=[800,480]
redline_img_size=[640,480]
det_stop=False
redline_stop=False
det_osd_img=None
redline_osd_img=None
# ---------- 串口 & 按键 ----------
uart = UART(UART.UART2, baudrate=115200)
# ---------- 红线识别参数 ----------
ROIS1 = [(225, 0, 400, 160, 0.3), (225, 160, 400, 160, 0.35), (225, 320, 400, 160, 0.35)]
ROIS2 = [(0, 150, 250, 300), (550, 150, 250, 300)]
# ---------- 状态变量 ----------
key_flag = 0
flag = 0
turn_flag = 0
move_record = []
return_mode = False
current_index = 0
def media_init():
    global sensor,osd_img,rgb888p_size,display_size,det_osd_img,yolo_osd_img
    Display.init(Display.ST7701, width = display_size[0], height = display_size[1], to_ide = True, osd_num=3)
    sensor = Sensor(fps=30)
    sensor.set_framesize(w = display_size[0], h = display_size[1],chn=CAM_CHN_ID_0)
    sensor.set_pixformat(Sensor.YUV420SP,chn=CAM_CHN_ID_0)
    sensor.set_framesize(w = redline_img_size[0], h = redline_img_size[1], chn=CAM_CHN_ID_1)
    sensor.set_pixformat(Sensor.RGB565,chn=CAM_CHN_ID_1)
    sensor.set_framesize(w = rgb888p_size[0], h = rgb888p_size[1], chn=CAM_CHN_ID_2)
    sensor.set_pixformat(Sensor.RGBP888,chn=CAM_CHN_ID_2)
    Display.init(Display.ST7701, osd_num=2, to_ide=True)
    det_osd_img = image.Image(display_size[0], display_size[1], image.ARGB8888)
    redline_osd_img = image.Image(display_size[0], display_size[1], image.ARGB8888)
def media_deinit():
    global sensor
    time.sleep_ms(50)
# ---------- 红线线程 ----------
    weight_sum = 0
    centroid_sum = 0
        if blobs[i]:
            detected_any = True
    if weight_sum:
        center_x = centroid_sum / weight_sum
        dx = center_x - 400
        if dx > 0:
            turn_flag = 1
            dx = -dx
            turn_flag = 2
        return dx
    return 0
        return False
        return False
        return False
    return True
def redline_thread():
    global sensor,flag, turn_flag, return_mode, move_record, key_flag, cross_detected, current_index
        if redline_stop:
        img = sensor.snapshot(chn=CAM_CHN_ID_1)
        # ROI 红色检测
        # 按键切换
            if flag == 0:
                return_mode = True
                current_index = len(move_record) - 1
                print("切换到回程模式")
                return_mode = False
                move_record.clear()
                print("切换到正常模式")
            time.sleep_ms(300)
        if not key_flag:
            time.sleep_ms(50)
        # 左右色块检测
        # 自动回程切换
        if flag == 0 and not return_mode:
            return_mode = True
            print("自动切换到回程模式")
        move_prepare = 1 if num == 1 else (3 if num == 2 else 2)
            if not return_mode:
                move_record.append(move_prepare)
        if is_cross:
            if not return_mode:
                    delta_pos_x = 400
                    turn_flag = 2
                    delta_pos_x = 400
                    turn_flag = 1
                    delta_pos_x = 0
                    turn_flag = 0
                    if m == 1:
                        delta_pos_x = 410
                        turn_flag = 1
                    elif m == 3:
                        delta_pos_x = 400
                        turn_flag = 2
                        delta_pos_x = 0
                        turn_flag = 0
        time.sleep_ms(50)
# ---------- AI 线程 ----------
def ai_thread():
    global sensor,rgb888p_size,display_size,det_osd_img
    anchors = []
    det_app = DetectionApp("video", kmodel_path, labels, model_input_size, anchors, model_type, confidence_threshold,nms_threshold, rgb888p_size, display_size)
        if det_stop:
        img =sensor.snapshot(chn=CAM_CHN_ID_2)
        img_np=img.to_numpy_ref()
        det_app.cur_result={"boxes":[],"scores":[], "idx":[]}
        res = det_app.run(img_np)
#        scores = res["scores"]
#        idxs = res["idx"]
#        boxes = res["boxes"]
#        for i in range(len(idxs)):
#            class_id = idxs[i]
#            score = scores[i]
#            box = boxes[i]
#            name = labels[class_id]
#            print(f"检测到物品: {name}, 置信度: {score:.2f}, 位置: {box}")
        det_app.draw_result(det_osd_img, res)
        Display.show_image(det_osd_img)
    det_app.deinit()
    media_init()
    # ---------- 启动线程 ----------
    _thread.start_new_thread(redline_thread, ())
    _thread.start_new_thread(ai_thread, ())
            time.sleep_ms(50)
        det_stop=True
        redline_stop=True
    time.sleep(1)
    media_deinit()
pl.create()是怎么改的,为什么不在程序里面了
万分感谢大佬
请问大佬,咱们的群是哪个,能分享一下群号吗?
