立创k230linux镜像启动后进入parted,无法退出
Viewed 73
使用 K230BurningTool.exe 烧录CanMV-K230_LCKFB_linux_v0.6.4_nncase_v2.9.0.img
期望正常启动 实际进入parted
U-Boot 2022.10 (Apr 02 2025 - 09:44:30 +0800)
CPU:   rv64imafdcvsu
Model: kendryte k230 canmv lckfb
DRAM:  1 GiB
Core:  26 devices, 13 uclasses, devicetree: embed
MMC:   mmc0@91580000: 0, mmc1@91581000: 1
In:    serial@91400000
Out:   serial@91400000
Err:   serial@91400000
Net:   No ethernet found.
Hit any key to stop autoboot:  0
139720 bytes read in 10 ms (13.3 MiB/s)
18485760 bytes read in 1043 ms (16.9 MiB/s)
55140 bytes read in 4 ms (13.1 MiB/s)
## Booting kernel from Legacy Image at 03000000 ...
   Image Name:   linux
   Created:      2025-04-02   1:44:44 UTC
   Image Type:   RISC-V Linux Kernel Image (uncompressed)
   Data Size:    139656 Bytes = 136.4 KiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 02200000
   Booting using the fdt blob at 0x2200000
   Loading Kernel Image
   Loading Device Tree to 000000000a0ef000, end 000000000a0ff763 ... OK
Starting kernel ...
OpenSBI v1.4
   ____                    _____ ____ _____
  / __ \                  / ____|  _ \_   _|
 | |  | |_ __   ___ _ __ | (___ | |_) || |
 | |  | | '_ \ / _ \ '_ \ \___ \|  _ < | |
 | |__| | |_) |  __/ | | |____) | |_) || |_
  \____/| .__/ \___|_| |_|_____/|____/_____|
        |_|
Platform Name             : Canaan CanMV-K230
Platform Features         : medeleg
Platform HART Count       : 1
Platform IPI Device       : aclint-mswi
Platform Timer Device     : aclint-mtimer @ 27000000Hz
Platform Console Device   : uart8250
Platform HSM Device       : ---
Platform PMU Device       : thead,c900-pmu
Platform Reboot Device    : ---
Platform Shutdown Device  : ---
Platform Suspend Device   : system-suspend-test
Platform CPPC Device      : ---
Firmware Base             : 0x0
Firmware Size             : 195 KB
Firmware RW Offset        : 0x20000
Firmware RW Size          : 67 KB
Firmware Heap Offset      : 0x28000
Firmware Heap Size        : 35 KB (total), 2 KB (reserved), 9 KB (used), 23 KB (free)
Firmware Scratch Size     : 4096 B (total), 328 B (used), 3768 B (free)
Runtime SBI Version       : 2.0
Domain0 Name              : root
Domain0 Boot HART         : 0
Domain0 HARTs             : 0*
Domain0 Region00          : 0x0000000091400000-0x0000000091400fff M: (I,R,W) S/U: (R,W)
Domain0 Region01          : 0x0000000f04008000-0x0000000f0400bfff M: (I,R,W) S/U: ()
Domain0 Region02          : 0x0000000f04000000-0x0000000f04007fff M: (I,R,W) S/U: ()
Domain0 Region03          : 0x0000000000000000-0x000000000001ffff M: (R,X) S/U: ()
Domain0 Region04          : 0x0000000000020000-0x000000000003ffff M: (R,W) S/U: ()
Domain0 Region05          : 0x0000000f00000000-0x0000000f03ffffff M: (I,R,W) S/U: (R,W)
Domain0 Region06          : 0x0000000000000000-0xffffffffffffffff M: () S/U: (R,W,X)
Domain0 Next Address      : 0x0000000000200000
Domain0 Next Arg1         : 0x0000000002200000
Domain0 Next Mode         : S-mode
Domain0 SysReset          : yes
Domain0 SysSuspend        : yes
Boot HART ID              : 0
Boot HART Domain          : root
Boot HART Priv Version    : v1.12
Boot HART Base ISA        : rv64imafdcbvx
Boot HART ISA Extensions  : sstc,zicntr,zihpm,zicboz,zicbom,svpbmt
Boot HART PMP Reserved    : 2
Boot HART PMP Count       : 64
Boot HART PMP Granularity : 12 bits
Boot HART PMP Address Bits: 38
Boot HART MHPM Info       : 16 (0x0007fff8)
Boot HART MIDELEG         : 0x0000000000020222
Boot HART MEDELEG         : 0x000000000000b109
[    0.000000] Linux version 6.6.36 (gitlab@runner) (riscv64-unknown-linux-gnu-gcc (Xuantie-900 linux-6.6.0 glibc gcc Toolchain V2.10.1 B-20240712) 10.4.0, GNU ld (GNU Binutils) 2.35) #2 SMP Wed Apr  2 09:08:07 CST 2025
[    0.000000] Machine model: Canaan CanMV-K230
[    0.000000] SBI specification v2.0 detected
[    0.000000] SBI implementation ID=0x1 Version=0x10004
[    0.000000] SBI TIME extension detected
[    0.000000] SBI IPI extension detected
[    0.000000] SBI RFENCE extension detected
[    0.000000] efi: UEFI not found.
[    0.000000] OF: reserved mem: 0x0000000000000000..0x000000000001ffff (128 KiB) nomap non-reusable mmode_resv0@0
[    0.000000] OF: reserved mem: 0x0000000000020000..0x000000000003ffff (128 KiB) nomap non-reusable mmode_resv1@20000
[    0.000000] cma: Reserved 512 MiB at 0x0000000020000000 on node -1
[    0.000000] Zone ranges:
[    0.000000]   DMA32    [mem 0x0000000000000000-0x000000003fffffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000000003ffff]
[    0.000000]   node   0: [mem 0x0000000000040000-0x000000003fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000003fffffff]
[    0.000000] SBI HSM extension detected
[    0.000000] riscv: base ISA extensions acdfimv
[    0.000000] riscv: ELF capabilities acdfimv
[    0.000000] percpu: Embedded 20 pages/cpu s41464 r8192 d32264 u81920
[    0.000000] pcpu-alloc: s41464 r8192 d32264 u81920 alloc=20*4096
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Kernel command line: root=/dev/mmcblk1p2 loglevel=8 rw rootdelay=4 rootfstype=ext4 console=ttyS0,115200  earlycon=sbi
[    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 258048
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Virtual kernel memory layout:
[    0.000000]       fixmap : 0xffffffc6fea00000 - 0xffffffc6ff000000   (6144 kB)
[    0.000000]       pci io : 0xffffffc6ff000000 - 0xffffffc700000000   (  16 MB)
[    0.000000]      vmemmap : 0xffffffc700000000 - 0xffffffc800000000   (4096 MB)
[    0.000000]      vmalloc : 0xffffffc800000000 - 0xffffffd800000000   (  64 GB)
[    0.000000]      modules : 0xffffffff01220000 - 0xffffffff80000000   (2029 MB)
[    0.000000]       lowmem : 0xffffffd800000000 - 0xffffffd840000000   (1024 MB)
[    0.000000]       kernel : 0xffffffff80000000 - 0xffffffffffffffff   (2047 MB)
[    0.000000] Memory: 470664K/1048576K available (11115K kernel code, 1131K rwdata, 5350K rodata, 447K init, 503K bss, 53624K reserved, 524288K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=1.
[    0.000000] rcu:     RCU debug extended QS entry/exit.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] riscv-intc: 64 local interrupts mapped
[    0.000000] plic: interrupt-controller@f00000000: mapped 208 interrupts with 1 handlers for 2 contexts.
[    0.000000] riscv: providing IPIs using SBI IPI extension
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x63a1e71a3, max_idle_ns: 440795203123 ns
[    0.000000] sched_clock: 64 bits at 27MHz, resolution 37ns, wraps every 4398046511093ns
[    0.000389] Console: colour dummy device 80x25
[    0.000433] Calibrating delay loop (skipped), value calculated using timer frequency.. 54.00 BogoMIPS (lpj=108000)
[    0.000444] pid_max: default: 32768 minimum: 301
[    0.000507] LSM: initializing lsm=capability,integrity
[    0.000594] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[    0.000604] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[    0.002303] RCU Tasks Trace: Setting shift to 0 and lim to 1 rcu_task_cb_adjust=1.
[    0.002409] riscv: ELF compat mode supported
[    0.002437] ASID allocator using 16 bits (65536 entries)
[    0.002560] rcu: Hierarchical SRCU implementation.
[    0.002565] rcu:     Max phase no-delay instances is 1000.
[    0.002772] EFI services will not be available.
[    0.002905] smp: Bringing up secondary CPUs ...
[    0.002921] smp: Brought up 1 node, 1 CPU
[    0.003578] devtmpfs: initialized
[    0.012316] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.012335] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[    0.022314] pinctrl core: initialized pinctrl subsystem
[    0.023317] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.024427] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
[    0.024546] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.024602] audit: initializing netlink subsys (disabled)
[    0.025151] thermal_sys: Registered thermal governor 'step_wise'
[    0.025209] audit: type=2000 audit(0.024:1): state=initialized audit_enabled=0 res=1
[    0.025222] cpuidle: using governor menu
[    0.048204] cpu0: Ratio of byte access time to unaligned word access is 6.32, unaligned accesses are fast
[    0.048233] suspend: SBI SUSP extension detected
[    0.053311] platform soc: Fixed dependency cycle(s) with /soc/interrupt-controller@f00000000
[    0.108105] platform 90840000.vo: Fixed dependency cycle(s) with /soc/dsi@90850000
[    0.108228] platform 90840000.vo: Fixed dependency cycle(s) with /soc/dsi@90850000
[    0.108288] platform 90850000.dsi: Fixed dependency cycle(s) with /soc/dsi@90850000/panel@0
[    0.108300] platform 90850000.dsi: Fixed dependency cycle(s) with /soc/vo@90840000
[    0.110103] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.110111] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[    0.110116] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.110119] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[    0.110677] ACPI: Interpreter disabled.
[    0.111079] k230-powerdomain 91103000.sysctl_power: powerdomain init ok
[    0.111611] iommu: Default domain type: Translated
[    0.111619] iommu: DMA domain TLB invalidation policy: strict mode
[    0.112027] SCSI subsystem initialized
[    0.112242] libata version 3.00 loaded.
[    0.112400] usbcore: registered new interface driver usbfs
[    0.112429] usbcore: registered new interface driver hub
[    0.112457] usbcore: registered new device driver usb
[    0.113871] mc: Linux media interface: v0.10
[    0.113930] videodev: Linux video capture interface: v2.00
[    0.114179] Advanced Linux Sound Architecture Driver Initialized.
[    0.115020] vgaarb: loaded
[    0.115394] clocksource: Switched to clocksource riscv_clocksource
[    0.115752] pnp: PnP ACPI: disabled
[    0.123490] NET: Registered PF_INET protocol family
[    0.123662] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.124796] tcp_listen_portaddr_hash hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.124834] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.124846] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.124892] TCP bind hash table entries: 8192 (order: 7, 524288 bytes, linear)
[    0.126362] TCP: Hash tables configured (established 8192 bind 8192)
[    0.126474] UDP hash table entries: 512 (order: 3, 49152 bytes, linear)
[    0.126563] UDP-Lite hash table entries: 512 (order: 3, 49152 bytes, linear)
[    0.126791] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.127403] RPC: Registered named UNIX socket transport module.
[    0.127413] RPC: Registered udp transport module.
[    0.127416] RPC: Registered tcp transport module.
[    0.127418] RPC: Registered tcp-with-tls transport module.
[    0.127420] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.128380] PCI: CLS 0 bytes, default 64
[    0.129187] Initialise system trusted keyrings
[    0.129580] workingset: timestamp_bits=46 max_order=18 bucket_order=0
[    0.130204] NFS: Registering the id_resolver key type
[    0.130257] Key type id_resolver registered
[    0.130261] Key type id_legacy registered
[    0.130287] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.130291] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.130495] fuse: init (API version 7.39)
[    0.130661] 9p: Installing v9fs 9p2000 file system support
[    0.130865] NET: Registered PF_ALG protocol family
[    0.130876] Key type asymmetric registered
[    0.130880] Asymmetric key parser 'x509' registered
[    0.130929] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.130936] io scheduler mq-deadline registered
[    0.130939] io scheduler kyber registered
[    0.130964] io scheduler bfq registered
[    0.146116] [K230_RESET]:sysctl reset phy addr 0x91101000
[    0.146127] [K230_RESET]: ok!
[    0.191118] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    0.193575] printk: console [ttyS0] disabled
[    0.213931] 91400000.serial: ttyS0 at MMIO 0x91400000 (irq = 79, base_baud = 3125000) is a 16550A
[    0.213964] printk: console [ttyS0] enabled
[    1.093275] 91403000.serial: ttyS3 at MMIO 0x91403000 (irq = 80, base_baud = 3125000) is a 16550A
[    1.103594] SuperH (H)SCI(F) driver initialized
[    1.109936] random: crng init done
[    1.113393] k230-rng 91213000.trng: K230 TRNG driver register!
[    1.120314] i2c_add_driver start
[    1.124057] canaan-vo 90840000.vo: probe
[    1.128652] canaan-mipi-dsi 90850000.dsi: Fixed dependency cycle(s) with /soc/dsi@90850000/panel@0
[    1.137726] mipi-dsi 90850000.dsi.0: Fixed dependency cycle(s) with /soc/dsi@90850000
[    1.559440] canaan-mipi-dsi 90850000.dsi: Attached device universal
[    1.567140] canaan-vo 90840000.vo: background color is ffffff
[    1.573103] canaan-drm soc:display-subsystem: bound 90840000.vo (ops 0xffffffff80befc30)
[    1.581254] canaan-drm soc:display-subsystem: bound 90850000.dsi (ops 0xffffffff80bf0150)
[    1.590306] [drm] Initialized canaan-drm 1.0.0 20230501 for soc:display-subsystem on minor 0
[    1.598861] canaan-drm soc:display-subsystem: [drm] bpp/depth value of 32/24 not supported
[    1.607148] canaan-drm soc:display-subsystem: [drm] No compatible format found
[    1.616120] canaan-drm soc:display-subsystem: [drm] *ERROR* fbdev: Failed to setup generic emulation (ret=-22)
[    1.626166] canaan-drm soc:display-subsystem: [drm:canaan_drm_bind] Canaan K230 DRM driver register successfully
[    1.637237] canaan-drm soc:display-subsystem: [drm] bpp/depth value of 32/24 not supported
[    1.645554] canaan-drm soc:display-subsystem: [drm] No compatible format found
[    1.657660] loop: module loaded
[    1.662469] canaan-drm soc:display-subsystem: [drm] *ERROR* fbdev: Failed to setup generic emulation (ret=-22)
[    1.690044] misc mmz: registered.
[    1.697501] e1000e: Intel(R) PRO/1000 Network Driver
[    1.702510] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    1.709919] usbcore: registered new device driver r8152-cfgselector
[    1.716257] usbcore: registered new interface driver r8152
[    1.721779] usbcore: registered new interface driver asix
[    1.727207] usbcore: registered new interface driver ax88179_178a
[    1.733325] usbcore: registered new interface driver cdc_ether
[    1.739185] usbcore: registered new interface driver net1080
[    1.744871] usbcore: registered new interface driver cdc_subset
[    1.750820] usbcore: registered new interface driver zaurus
[    1.756432] usbcore: registered new interface driver cdc_ncm
[    1.762122] usbcore: registered new interface driver r8153_ecm
[    1.769139] dwc2 91500000.usb: supply vusb_d not found, using dummy regulator
[    1.776456] dwc2 91500000.usb: supply vusb_a not found, using dummy regulator
[    1.903445] dwc2 91500000.usb: EPs: 7, dedicated fifos, 3016 entries in SPRAM
[    1.910741] dwc2 91500000.usb: DWC OTG Controller
[    1.915487] dwc2 91500000.usb: new USB bus registered, assigned bus number 1
[    1.922565] dwc2 91500000.usb: irq 85, io mem 0x91500000
[    1.928015] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[    1.936294] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.943523] usb usb1: Product: DWC OTG Controller
[    1.948233] usb usb1: Manufacturer: Linux 6.6.36 dwc2_hsotg
[    1.953810] usb usb1: SerialNumber: 91500000.usb
[    1.958899] hub 1-0:1.0: USB hub found
[    1.962734] hub 1-0:1.0: 1 port detected
[    1.967433] dwc2 91540000.usb: supply vusb_d not found, using dummy regulator
[    1.974720] dwc2 91540000.usb: supply vusb_a not found, using dummy regulator
[    2.099466] dwc2 91540000.usb: EPs: 7, dedicated fifos, 3016 entries in SPRAM
[    2.116814] dwc2 91540000.usb: DWC OTG Controller
[    2.121561] dwc2 91540000.usb: new USB bus registered, assigned bus number 2
[    2.128640] dwc2 91540000.usb: irq 86, io mem 0x91540000
[    2.134095] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[    2.142374] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.149611] usb usb2: Product: DWC OTG Controller
[    2.154321] usb usb2: Manufacturer: Linux 6.6.36 dwc2_hsotg
[    2.159897] usb usb2: SerialNumber: 91540000.usb
[    2.165017] hub 2-0:1.0: USB hub found
[    2.168845] hub 2-0:1.0: 1 port detected
[    2.173639] usbcore: registered new interface driver usb-storage
[    2.179989] mousedev: PS/2 mouse device common for all mice
[    2.186659] i2c_dev: i2c /dev entries driver
[    2.191273] edt_ft5x06 1-0038: supply vcc not found, using dummy regulator
[    2.198310] edt_ft5x06 1-0038: supply iovcc not found, using dummy regulator
[    2.207166] MVX dev: Linlon v5276 identified. cores=1, nlsid=4, id=0. (mvx_dev.c:416)
[    2.215296] usbcore: registered new interface driver uvcvideo
[    2.249727] sdhci: Secure Digital Host Controller Interface driver
[    2.255961] sdhci: Copyright(c) Pierre Ossman
[    2.260989] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.268204] Kendryte crypto driver probe!
[    2.272749] Kendryte sha256 driver probe!
[    2.277323] Kendryte RSA driver probe!
[    2.281346] usbcore: registered new interface driver usbhid
[    2.286945] usbhid: USB HID core driver
[    2.294111] riscv-pmu-sbi: SBI PMU extension is available
[    2.299596] riscv-pmu-sbi: 16 firmware and 18 hardware counters
[    2.330687] mmc0: SDHCI controller on 91580000.sdhci0 [91580000.sdhci0] using ADMA
[    2.338370] mmc1: SDHCI controller on 91581000.sdhci1 [91581000.sdhci1] using ADMA
[    2.350376] sdhci-dwcmshc-kendryte 91580000.sdhci0: card claims to support voltages below defined range
[    2.360832] mmc1: Got command interrupt 0x00000001 even though no command operation was in progress.
[    2.369968] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[    2.376407] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00000005
[    2.382846] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[    2.389284] mmc1: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
[    2.395722] mmc1: sdhci: Present:   0x03ff0000 | Host ctl: 0x00000000
[    2.402160] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000000
[    2.408599] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00007d27
[    2.415037] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[    2.421475] mmc1: sdhci: Int enab:  0x00ff1083 | Sig enab: 0x00ff1083
[    2.427913] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[    2.434350] mmc1: sdhci: Caps:      0x276a6481 | Caps_1:   0x08008071
[    2.440789] mmc1: sdhci: Cmd:       0x00000502 | Max curr: 0x00000000
[    2.447226] mmc1: sdhci: Resp[0]:   0x000001aa | Resp[1]:  0x00000000
[    2.453663] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[    2.460101] mmc1: sdhci: Host ctl2: 0x00000000
[    2.464541] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[    2.470978] mmc1: sdhci: ============================================
[    2.481903] mmc0: new high speed SDIO card at address 0001
[    2.512917] mmc1: new high speed SDHC card at address 21b7
[    2.518876] mmcblk1: mmc1:21b7 APPSD 29.1 GiB
[    2.528688] Alternate GPT is invalid, using primary GPT.
[    2.534043]  mmcblk1: p1 p2
[    2.563467] edt_ft5x06 1-0038: touchscreen probe failed
[    2.568876] edt_ft5x06: probe of 1-0038 failed with error -121
[    2.739241] NET: Registered PF_INET6 protocol family
[    2.745030] Segment Routing with IPv6
[    2.748762] In-situ OAM (IOAM) with IPv6
[    2.752749] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    2.759141] NET: Registered PF_PACKET protocol family
[    2.764311] 9pnet: Installing 9P2000 support
[    2.768661] Key type dns_resolver registered
[    2.772989] start plist test
[    2.778476] end plist test
[    2.788871] Loading compiled-in X.509 certificates
[    2.799167] debug_vm_pgtable: [debug_vm_pgtable         ]: Validating architecture page table helpers
[    2.818246] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    2.828255] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[    2.836255] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    2.842015] clk: Disabling unused clocks
[    2.846046] ALSA device list:
[    2.849033]   #0: K230_I2S_INNO
[    2.852487] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    2.861140] cfg80211: failed to load regulatory.db
[    2.866110] Waiting 4 sec before mounting root device...
^C[    7.965496] EXT4-fs (mmcblk1p2): warning: mounting fs with errors, running e2fsck is recommended
[    8.310542] EXT4-fs (mmcblk1p2): recovery complete
[    8.633134] EXT4-fs (mmcblk1p2): mounted filesystem d69b4bbd-94a6-48fe-9026-1ee5a8047ffc r/w with ordered data mode. Quota mode: disabled.
[    8.645643] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    8.652132] devtmpfs: mounted
[    8.655204] Freeing unused kernel image (initmem) memory: 444K
[    8.661061] Kernel memory protection not selected by kernel config.
[    8.667341] Run /sbin/init as init process
[    8.671442]   with arguments:
[    8.674407]     /sbin/init
[    8.677117]   with environment:
[    8.680261]     HOME=/
[    8.682618]     TERM=linux
[    8.831446] EXT4-fs (mmcblk1p2): re-mounted d69b4bbd-94a6-48fe-9026-1ee5a8047ffc r/w. Quota mode: disabled.
Seeding 256 bits and crediting
Saving 256 bits of creditable seed for next boot
Starting syslogd: OK
Starting klogd: OK
Running sysctl: OK
[   14.155841] EXT4-fs error (device mmcblk1p2): ext4_validate_block_bitmap:421: comm ext4lazyinit: bg 1009: bad block bitmap checksum
[   14.188562] EXT4-fs error (device mmcblk1p2): ext4_validate_block_bitmap:421: comm ext4lazyinit: bg 1137: bad block bitmap checksum
[   14.246373] EXT4-fs error (device mmcblk1p2): ext4_validate_block_bitmap:421: comm ext4lazyinit: bg 1265: bad block bitmap checksum
[   14.304586] 8189fs: loading out-of-tree module taints kernel.
[   14.892768] EXT4-fs error (device mmcblk1p2): ext4_validate_block_bitmap:421: comm ext4lazyinit: bg 1393: bad block bitmap checksum
[   14.913424] EXT4-fs error (device mmcblk1p2): ext4_validate_block_bitmap:421: comm ext4lazyinit: bg 1521: bad block bitmap checksum
[   14.933195] EXT4-fs error (device mmcblk1p2): ext4_validate_block_bitmap:421: comm ext4lazyinit: bg 1649: bad block bitmap checksum
[   14.960036] EXT4-fs error (device mmcblk1p2): ext4_validate_block_bitmap:421: comm ext4lazyinit: bg 1777: bad block bitmap checksum
[   14.991510] EXT4-fs error (device mmcblk1p2): ext4_validate_block_bitmap:421: comm ext4lazyinit: bg 1905: bad block bitmap checksum
[   15.021934] EXT4-fs error (device mmcblk1p2): ext4_validate_block_bitmap:421: comm ext4lazyinit: bg 2033: bad block bitmap checksum
[   15.053363] EXT4-fs error (device mmcblk1p2): ext4_validate_block_bitmap:421: comm ext4lazyinit: bg 2161: bad block bitmap checksum
[   15.131002] aic_bluetooth_mod_init
[   15.134539] RELEASE DATE:2024_0929_2e313139
[   15.138980] usbcore: registered new interface driver aic_load_fw
[   15.375482] usbcore: registered new interface driver aic8800_fdrv
[   16.740220] Bluetooth: Core ver 2.22
[   16.743884] NET: Registered PF_BLUETOOTH protocol family
[   16.749211] Bluetooth: HCI device and connection manager initialized
[   16.755581] Bluetooth: HCI socket layer initialized
[   16.760468] Bluetooth: L2CAP socket layer initialized
[   16.765535] Bluetooth: SCO socket layer initialized
[   16.776934] aic_btusb: AICBT_RELEASE_NAME: 202012_ANDROID
[   16.782393] aic_btusb: AicSemi Bluetooth USB driver module init, version 2.1.0
[   16.789626] aic_btusb: RELEASE DATE: 2023_1211_1958 CONFIG_BLUEDROID =0
[   16.789626]
[   16.797961] usbcore: registered new interface driver aic_btusb
Starting system message bus: done
Starting bluetoothd: OK
Starting network: Waiting for interface eth0 to appear............... timeout!
run-parts: /etc/network/if-pre-up.d/wait_iface: exit status 1
FAIL
Starting sntp: sntp 4.2.8p17@1.4004-o Wed Apr  2 01:25:49 UTC 2025 (1)
pool.ntp.org lookup error Temporary failure in name resolution
FAIL
Starting ntpd: OK
Starting sshd: OK
Starting telnetd: OK
first boot flag
Error: The backup GPT table is corrupt, but the primary appears OK, so that will
be used.
parted: invalid token: a
parted: invalid token: asdsa
parted: invalid token: s
/dev/mmcblk1lid token:
parted: invalid token: /dev/mmcblk1lid
parted: invalid token: print
[  316.387379] EXT4-fs (mmcblk1p2): error count since last fsck: 88
[  316.393416] EXT4-fs (mmcblk1p2): initial error at time 16: ext4_validate_block_bitmap:421
[  316.401598] EXT4-fs (mmcblk1p2): last error at time 15: ext4_validate_block_bitmap:421
检查下下载的文件md5是否正确,或者换个tf卡重新试下。
换了tf卡就行了
