onnx转kmodel环境安装过程中,pip install onnxsim 报错
Viewed 208
pip install onnxsim
可以跑onnx转kmodel
windows10
nncase2.9.0
.NET 7.0.0
nncase-kpu2.9.0
引用
报错信息放到正文中就无法发出,尝试过了用引用和代码块的方式包裹,都无效
补充报错信息如下:
Looking in indexes: https://pypi.tuna.tsinghua.edu.cn/simple
Collecting onnxsim
  Using cached https://pypi.tuna.tsinghua.edu.cn/packages/ce/9e/f34238413ebeda9a3a8802feeaa5013934455466b9ab390b48ad9c7e184f/onnxsim-0.4.36.tar.gz (21.0 MB)
  Installing build dependencies ... done
  Getting requirements to build wheel ... done
  Installing backend dependencies ... done
  Preparing metadata (pyproject.toml) ... done
Collecting onnx (from onnxsim)
  Using cached https://pypi.tuna.tsinghua.edu.cn/packages/e8/92/048ba8fafe6b2b9a268ec2fb80def7e66c0b32ab2cae74de886981f05a27/onnx-1.18.0-cp312-cp312-win_amd64.whl (15.9 MB)
Collecting rich (from onnxsim)
  Using cached https://pypi.tuna.tsinghua.edu.cn/packages/0d/9b/63f4c7ebc259242c89b3acafdb37b41d1185c07ff0011164674e9076b491/rich-14.0.0-py3-none-any.whl (243 kB)
Requirement already satisfied: numpy>=1.22 in d:\python\lib\site-packages (from onnx->onnxsim) (2.3.0)
Requirement already satisfied: protobuf>=4.25.1 in d:\python\lib\site-packages (from onnx->onnxsim) (6.31.1)
Collecting typing_extensions>=4.7.1 (from onnx->onnxsim)
  Using cached https://pypi.tuna.tsinghua.edu.cn/packages/b5/00/d631e67a838026495268c2f6884f3711a15a9a2a96cd244fdaea53b823fb/typing_extensions-4.14.1-py3-none-any.whl (43 kB)
Collecting markdown-it-py>=2.2.0 (from rich->onnxsim)
  Using cached https://pypi.tuna.tsinghua.edu.cn/packages/42/d7/1ec15b46af6af88f19b8e5ffea08fa375d433c998b8a7639e76935c14f1f/markdown_it_py-3.0.0-py3-none-any.whl (87 kB)
Collecting pygments<3.0.0,>=2.13.0 (from rich->onnxsim)
  Using cached https://pypi.tuna.tsinghua.edu.cn/packages/c7/21/705964c7812476f378728bdf590ca4b771ec72385c533964653c68e86bdc/pygments-2.19.2-py3-none-any.whl (1.2 MB)
Collecting mdurl~=0.1 (from markdown-it-py>=2.2.0->rich->onnxsim)
  Using cached https://pypi.tuna.tsinghua.edu.cn/packages/b3/38/89ba8ad64ae25be8de66a6d463314cf1eb366222074cfda9ee839c56a4b4/mdurl-0.1.2-py3-none-any.whl (10.0 kB)
Building wheels for collected packages: onnxsim
  Building wheel for onnxsim (pyproject.toml) ... error
  error: subprocess-exited-with-error
  × Building wheel for onnxsim (pyproject.toml) did not run successfully.
  │ exit code: 1
  ╰─> [204 lines of output]
      <string>:28: DeprecationWarning: Use shutil.which instead of find_executable
      fatal: not a git repository (or any of the parent directories): .git
      C:\Users\kekoukele\AppData\Local\Temp\pip-build-env-itn5niml\overlay\Lib\site-packages\setuptools\dist.py:759: SetuptoolsDeprecationWarning: License classifiers are deprecated.
              Please consider removing the following classifiers in favor of a SPDX license expression:
              License :: OSI Approved :: Apache Software License
              See https://packaging.python.org/en/latest/guides/writing-pyproject-toml/#license for details.
        self._finalize_license_expression()
      running bdist_wheel
      running build
      running build_py
      running create_version
      creating build\lib.win-amd64-cpython-312\onnxsim
      copying onnxsim\model_checking.py -> build\lib.win-amd64-cpython-312\onnxsim
      copying onnxsim\model_info.py -> build\lib.win-amd64-cpython-312\onnxsim
      copying onnxsim\onnx_simplifier.py -> build\lib.win-amd64-cpython-312\onnxsim
      copying onnxsim\version.py -> build\lib.win-amd64-cpython-312\onnxsim
      copying onnxsim\__init__.py -> build\lib.win-amd64-cpython-312\onnxsim
      copying onnxsim\__main__.py -> build\lib.win-amd64-cpython-312\onnxsim
      running egg_info
      writing onnxsim.egg-info\PKG-INFO
      writing dependency_links to onnxsim.egg-info\dependency_links.txt
      writing entry points to onnxsim.egg-info\entry_points.txt
      writing requirements to onnxsim.egg-info\requires.txt
      writing top-level names to onnxsim.egg-info\top_level.txt
      reading manifest file 'onnxsim.egg-info\SOURCES.txt'
      reading manifest template 'MANIFEST.in'
      warning: no files found matching '*.c' under directory 'onnxsim'
      warning: no files found matching '*.proto' under directory 'onnxsim'
      warning: no previously-included files matching '*' found under directory 'third_party\onnxruntime'
      warning: no previously-included files matching '*' found under directory 'third_party\onnx-optimizer\build'
      warning: no previously-included files matching '*' found under directory 'third_party\onnx\build'
      warning: no previously-included files matching '*' found under directory 'third_party\onnx\onnx\backend'
      adding license file 'LICENSE'
      writing manifest file 'onnxsim.egg-info\SOURCES.txt'
      C:\Users\kekoukele\AppData\Local\Temp\pip-build-env-itn5niml\overlay\Lib\site-packages\setuptools\command\build_py.py:212: _Warning: Package 'onnxsim.bin' is absent from the `packages` configuration.
              # Package would be ignored #
              Python recognizes 'onnxsim.bin' as an importable package[^1],
              but it is absent from setuptools' `packages` configuration.
              This leads to an ambiguous overall configuration. If you want to distribute this
              package, please make sure that 'onnxsim.bin' is explicitly added
              to the `packages` configuration field.
              Alternatively, you can also rely on setuptools' discovery methods
              (for example by using `find_namespace_packages(...)`/`find_namespace:`
              instead of `find_packages(...)`/`find:`).
              You can read more about "package discovery" on setuptools documentation page:
              - https://setuptools.pypa.io/en/latest/userguide/package_discovery.html
              If you don't want 'onnxsim.bin' to be distributed and are
              already explicitly excluding 'onnxsim.bin' via
              `find_namespace_packages(...)/find_namespace` or `find_packages(...)/find`,
              you can try to use `exclude_package_data`, or `include-package-data=False` in
              combination with a more fine grained `package-data` configuration.
              You can read more about "package data files" on setuptools documentation page:
              - https://setuptools.pypa.io/en/latest/userguide/datafiles.html
              [^1]: For Python, any directory (with suitable naming) can be imported,
                    even if it does not contain any `.py` files.
                    On the other hand, currently there is no concept of package data
                    directory, all directories are treated like packages.
        check.warn(importable)
      copying onnxsim\cpp2py_export.cc -> build\lib.win-amd64-cpython-312\onnxsim
      copying onnxsim\cxxopts.hpp -> build\lib.win-amd64-cpython-312\onnxsim
      copying onnxsim\onnxsim.cpp -> build\lib.win-amd64-cpython-312\onnxsim
      copying onnxsim\onnxsim.h -> build\lib.win-amd64-cpython-312\onnxsim
      creating build\lib.win-amd64-cpython-312\onnxsim\bin
      copying onnxsim\bin\onnxsim_bin.cpp -> build\lib.win-amd64-cpython-312\onnxsim\bin
      copying onnxsim\bin\onnxsim_option.cpp -> build\lib.win-amd64-cpython-312\onnxsim\bin
      copying onnxsim\bin\onnxsim_option.h -> build\lib.win-amd64-cpython-312\onnxsim\bin
      running build_ext
      running cmake_build
      -- Building for: Visual Studio 17 2022
      -- Selecting Windows SDK version 10.0.22621.0 to target Windows 10.0.19045.
      -- The CXX compiler identification is MSVC 19.42.34435.0
      -- Detecting CXX compiler ABI info
      -- Detecting CXX compiler ABI info - done
      -- Check for working CXX compiler: D:/Visual Studio/Microsoft Visual Studio/2022/Professional/VC/Tools/MSVC/14.42.34433/bin/Hostx64/x64/cl.exe - skipped
      -- Detecting CXX compile features
      -- Detecting CXX compile features - done
      -- The C compiler identification is MSVC 19.42.34435.0
      -- Detecting C compiler ABI info
      -- Detecting C compiler ABI info - done
      -- Check for working C compiler: D:/Visual Studio/Microsoft Visual Studio/2022/Professional/VC/Tools/MSVC/14.42.34433/bin/Hostx64/x64/cl.exe - skipped
      -- Detecting C compile features
      -- Detecting C compile features - done
      CMake Deprecation Warning at third_party/onnx-optimizer/third_party/protobuf/cmake/CMakeLists.txt:2 (cmake_minimum_required):
        Compatibility with CMake < 3.10 will be removed from a future version of
        CMake.
        Update the VERSION argument <min> value.  Or, use the <min>...<max> syntax
        to tell CMake that the project requires at least <min> but has been updated
        to work with policies introduced by <max> or earlier.
      -- 3.20.1.0
      -- Performing Test protobuf_HAVE_LD_VERSION_SCRIPT
      -- Performing Test protobuf_HAVE_LD_VERSION_SCRIPT - Success
      -- Performing Test CMAKE_HAVE_LIBC_PTHREAD
      -- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Failed
      -- Looking for pthread_create in pthreads
      -- Looking for pthread_create in pthreads - not found
      -- Looking for pthread_create in pthread - not found
      -- Found Threads: TRUE
      -- Could NOT find ZLIB (missing: ZLIB_LIBRARY ZLIB_INCLUDE_DIR)
      CMake Error at third_party/onnx-optimizer/third_party/onnx/CMakeLists.txt:2 (cmake_minimum_required):
        Compatibility with CMake < 3.5 has been removed from CMake.
        Or, add -DCMAKE_POLICY_VERSION_MINIMUM=3.5 to try configuring anyway.
      -- Configuring incomplete, errors occurred!
      Run command ['D:\\CMake\\bin\\cmake.exe', '-DPython_INCLUDE_DIR=D:\\python\\include', '-DPython_EXECUTABLE=D:\\python\\python.exe', '-DPYTHON_EXECUTABLE=D:\\python\\python.exe', '-DBUILD_ONNX_PYTHON=OFF', '-DONNXSIM_PYTHON=ON', '-DONNXSIM_BUILTIN_ORT=OFF', '-DONNX_USE_LITE_PROTO=OFF', '-DCMAKE_EXPORT_COMPILE_COMMANDS=ON', '-DONNX_NAMESPACE=onnx', '-DPY_EXT_SUFFIX=.cp312-win_amd64.pyd', '-DONNX_OPT_USE_SYSTEM_PROTOBUF=OFF', '-DCMAKE_BUILD_TYPE=Release', '-DPY_VERSION=3.12', '-A', 'x64', '-T', 'host=x64', '-DONNX_ML=1', 'C:\\Users\\kekoukele\\AppData\\Local\\Temp\\pip-install-a3w2ujhz\\onnxsim_ebc3ddb3775541ce9487d6f5ffbc355b']
        File "D:\python\Lib\site-packages\pip\_vendor\pyproject_hooks\_in_process\_in_process.py", line 389, in <module>
          main()
        File "D:\python\Lib\site-packages\pip\_vendor\pyproject_hooks\_in_process\_in_process.py", line 373, in main
          json_out["return_val"] = hook(**hook_input["kwargs"])
        File "D:\python\Lib\site-packages\pip\_vendor\pyproject_hooks\_in_process\_in_process.py", line 280, in build_wheel
          return _build_backend().build_wheel(
        File "C:\Users\kekoukele\AppData\Local\Temp\pip-build-env-itn5niml\overlay\Lib\site-packages\setuptools\build_meta.py", line 435, in build_wheel
          return _build(['bdist_wheel', '--dist-info-dir', str(metadata_directory)])
        File "C:\Users\kekoukele\AppData\Local\Temp\pip-build-env-itn5niml\overlay\Lib\site-packages\setuptools\build_meta.py", line 423, in _build
          return self._build_with_temp_dir(
        File "C:\Users\kekoukele\AppData\Local\Temp\pip-build-env-itn5niml\overlay\Lib\site-packages\setuptools\build_meta.py", line 404, in _build_with_temp_dir
          self.run_setup()
        File "C:\Users\kekoukele\AppData\Local\Temp\pip-build-env-itn5niml\overlay\Lib\site-packages\setuptools\build_meta.py", line 512, in run_setup
          super().run_setup(setup_script=setup_script)
        File "C:\Users\kekoukele\AppData\Local\Temp\pip-build-env-itn5niml\overlay\Lib\site-packages\setuptools\build_meta.py", line 317, in run_setup
          exec(code, locals())
        File "<string>", line 279, in <module>
        File "C:\Users\kekoukele\AppData\Local\Temp\pip-build-env-itn5niml\overlay\Lib\site-packages\setuptools\__init__.py", line 115, in setup
          return distutils.core.setup(**attrs)
        File "C:\Users\kekoukele\AppData\Local\Temp\pip-build-env-itn5niml\overlay\Lib\site-packages\setuptools\_distutils\core.py", line 186, in setup
          return run_commands(dist)
        File "C:\Users\kekoukele\AppData\Local\Temp\pip-build-env-itn5niml\overlay\Lib\site-packages\setuptools\_distutils\core.py", line 202, in run_commands
          dist.run_commands()
        File "C:\Users\kekoukele\AppData\Local\Temp\pip-build-env-itn5niml\overlay\Lib\site-packages\setuptools\_distutils\dist.py", line 1002, in run_commands
          self.run_command(cmd)
        File "C:\Users\kekoukele\AppData\Local\Temp\pip-build-env-itn5niml\overlay\Lib\site-packages\setuptools\dist.py", line 1102, in run_command
          super().run_command(command)
        File "C:\Users\kekoukele\AppData\Local\Temp\pip-build-env-itn5niml\overlay\Lib\site-packages\setuptools\_distutils\dist.py", line 1021, in run_command
          cmd_obj.run()
        File "C:\Users\kekoukele\AppData\Local\Temp\pip-build-env-itn5niml\overlay\Lib\site-packages\setuptools\command\bdist_wheel.py", line 370, in run
          self.run_command("build")
        File "C:\Users\kekoukele\AppData\Local\Temp\pip-build-env-itn5niml\overlay\Lib\site-packages\setuptools\_distutils\cmd.py", line 357, in run_command
          self.distribution.run_command(command)
          cmd_obj.run()
        File "C:\Users\kekoukele\AppData\Local\Temp\pip-build-env-itn5niml\overlay\Lib\site-packages\setuptools\_distutils\command\build.py", line 135, in run
          self.run_command(cmd_name)
          cmd_obj.run()
        File "<string>", line 220, in run
          cmd_obj.run()
        File "<string>", line 194, in run
        File "D:\python\Lib\subprocess.py", line 413, in check_call
          raise CalledProcessError(retcode, cmd)
      subprocess.CalledProcessError: Command '['D:\\CMake\\bin\\cmake.exe', '-DPython_INCLUDE_DIR=D:\\python\\include', '-DPython_EXECUTABLE=D:\\python\\python.exe', '-DPYTHON_EXECUTABLE=D:\\python\\python.exe', '-DBUILD_ONNX_PYTHON=OFF', '-DONNXSIM_PYTHON=ON', '-DONNXSIM_BUILTIN_ORT=OFF', '-DONNX_USE_LITE_PROTO=OFF', '-DCMAKE_EXPORT_COMPILE_COMMANDS=ON', '-DONNX_NAMESPACE=onnx', '-DPY_EXT_SUFFIX=.cp312-win_amd64.pyd', '-DONNX_OPT_USE_SYSTEM_PROTOBUF=OFF', '-DCMAKE_BUILD_TYPE=Release', '-DPY_VERSION=3.12', '-A', 'x64', '-T', 'host=x64', '-DONNX_ML=1', 'C:\\Users\\kekoukele\\AppData\\Local\\Temp\\pip-install-a3w2ujhz\\onnxsim_ebc3ddb3775541ce9487d6f5ffbc355b']' returned non-zero exit status 1.
      [end of output]
  note: This error originates from a subprocess, and is likely not a problem with pip.
  ERROR: Failed building wheel for onnxsim
Failed to build onnxsim
ERROR: Failed to build installable wheels for some pyproject.toml based projects (onnxsim)
可能是版本的问题,你可以将python版本换到3.9或者3.10
python版本用的是3.9的
后续有解决吗,啥问题啊
