求助大佬,我训练了两个AI数字识别模型,我想在一块K230上同时用两个摄像头识别前后的数字,前后分开识别的两份代码单独运行都好好的,但是怎么弄都不能把这两份代码合在一个程序里面运行,怎么改都有报错,ai也问了,弄了好久好久,求解答
Viewed 240
from libs.YOLO import YOLOv8
import os,sys,gc
from machine import UART, FPIOA
sensor=Sensor(id=0, fps=60, vflip=True)
    display_mode="lcd"
    rgb888p_size=[640,640]
    if display_mode=="lcd":
        display_size=[640,480]
        display_size=[640,640]
    labels = ["1","2","3","4","5","6"]
    confidence_threshold = 0.8
    nms_threshold=0.45
    model_input_size=[640,640]
    # 自定义六个区域的坐标范围 (x1, y1, x2, y2),基于模型输入尺寸 [640, 640]
    custom_regions = [
        (0, 0, 97,640),      # 区域0: 左上
        (97, 0, 208, 640),    # 区域1: 中上
        (208, 0, 319, 640),    # 区域2: 右上
        (319, 0, 430, 640),    # 区域3: 左下
        (430, 0, 520, 640),  # 区域4: 中下
        (520, 0, 640, 640),  # 区域5: 右下
    fpioa.set_function(3, FPIOA.UART1_TXD)
    fpioa.set_function(4, FPIOA.UART1_RXD)
    uart = UART(UART.UART1, 115200)
    # 初始化PipeLine
    pl.create(sensor=sensor,hmirror=True)
    # 初始化YOLOv8实例
    yolo=YOLOv8(task_type="detect",mode="video",kmodel_path=kmodel_path,labels=labels,rgb888p_size=rgb888p_size,model_input_size=model_input_size,display_size=display_size,conf_thresh=confidence_threshold,nms_thresh=nms_threshold,max_boxes_num=50,debug_mode=0)
    yolo.config_preprocess()
    detection_regions = [{} for _ in range(6)]
    frame_counter = 0
    ANALYSIS_FRAMES = 5
            with ScopedTiming("total",1):
                # 逐帧推理
                img=pl.get_frame()
                res=yolo.run(img)
                for det in res:
                    x1, y1, x2, y2 = det[:4]
                    cx = (x1 + x2) / 2
                    cy = (y1 + y2) / 2
                    # 判断目标中心点位于哪个自定义区域
                    region_idx = -1  # 默认值,表示未匹配到任何区域
                    for i, region in enumerate(custom_regions):
                        rx1, ry1, rx2, ry2 = region
                        if rx1 <= cx < rx2 and ry1 <= cy < ry2:
                            region_idx = i
                    if 0 <= region_idx < 6:
                        label = labels[int(det[5])]
                        detection_regions[region_idx][label] = detection_regions[region_idx].get(label, 0) + 1
                frame_counter += 1
                if frame_counter >= ANALYSIS_FRAMES:
                    output = []
                    for region in detection_regions:
                        if region:
                            output.append(max(region, key=region.get))
                            output.append("0")  # 区域内没有识别内容,返回0
                    output_str = " ".join(output)
                    uart.write(output_str)
                    print(f"Sent: {output_str}")
                    frame_counter = 0
                pl.show_image()
        print(e)
        yolo.deinit()
        uart.deinit()
import os,sys,gc
    display_mode="lcd"
    confidence_threshold = 0.6
    nms_threshold=0.45
    custom_regions = [
        (0, 0, 251,400),      # 区域0: 左上
        (251, 0, 398, 400),    # 区域1: 中上
        (398, 0, 640, 400),    # 区域2: 右上
        (0, 400, 259, 640),    # 区域3: 左下
        (259, 400, 385, 640),  # 区域4: 中下
        (385, 400, 640, 640),  # 区域5: 右下
    fpioa.set_function(44, FPIOA.UART2_TXD)
    fpioa.set_function(45, FPIOA.UART2_RXD)
    uart = UART(UART.UART2, 115200)
    # 初始化PipeLine
    # 初始化YOLOv8实例
    frame_counter = 0
    ANALYSIS_FRAMES = 5
                # 逐帧推理
                img=pl.get_frame()
                res=yolo.run(img)
                for det in res:
                    cx = (x1 + x2) / 2
                    cy = (y1 + y2) / 2
                    # 判断目标中心点位于哪个自定义区域
                            region_idx = i
                frame_counter += 1
                    output = []
                        if region:
                            output.append("")
                    output_str = " ".join([x for x in output if x])
                    if output_str:
                    frame_counter = 0
                pl.show_image()
        yolo.deinit()
        uart.deinit()
`期待结果和实际结果`
<!-- 你期待的结果是什么?实际看到的结果是什么? -->
`软硬件版本信息`
<!-- 硬件版本信息?软件版本信息? -->
`错误日志`
<!-- 是否有任何错误信息或日志?请附上相关内容。 -->
`尝试解决过程`
<!-- 你为解决这个问题尝试过哪些方法?请提供更多详细信息。 -->
`补充材料`
<!-- 请提供其他相关信息(如代码片段、配置文件、截图等)。 -->
