新手小白,我写了一个轮询来开两个摄像头来进行检测,但是出了问题,请大佬解惑
Viewed 52
以下是代码部分
from libs.YOLO import YOLOv8
import os, sys, gc, time
from machine import UART, FPIOA
# 配置参数
display_mode = "lcd"
rgb888p_size = [640, 640]
display_size = [640, 480] if display_mode == "lcd" else [640, 640]
kmodel_path = "/data/fang.kmodel"
labels = ["1", "2", "3", "4", "5", "6"]
confidence_threshold = 0.8
nms_threshold = 0.45
model_input_size = [640, 640]
# 自定义区域
custom_regions = [
    (0, 0, 97, 640),
    (97, 0, 208, 640),
    (208, 0, 319, 640),
    (319, 0, 430, 640),
    (430, 0, 520, 640),
    (520, 0, 640, 640),
# 初始化UART
fpioa.set_function(3, FPIOA.UART1_TXD)
uart = UART(UART.UART1, 115200)
# 初始化推理系统
def init_inference_system():
    MediaManager._config()
    pl.create(hmirror=True)
    yolo = YOLOv8(
        task_type="detect",
        mode="image",
        kmodel_path=kmodel_path,
        labels=labels,
        rgb888p_size=rgb888p_size,
        model_input_size=model_input_size,
        display_size=display_size,
        conf_thresh=confidence_threshold,
        nms_thresh=nms_threshold,
        max_boxes_num=50,
        debug_mode=0
    yolo.config_preprocess()
    return pl, yolo
# 处理单帧
def process_frame(yolo, pl, img, camera_id, frame_num):
        img = img.resize(rgb888p_size)
        with ScopedTiming(f"camera_{camera_id}_frame_{frame_num}", 1):
            res = yolo.run(img)
            detection_regions = [{} for _ in range(6)]
            for det in res:
                x1, y1, x2, y2 = det[:4]
                cx, cy = (x1 + x2)/2, (y1 + y2)/2
                region_idx = -1
                for i, (rx1, ry1, rx2, ry2) in enumerate(custom_regions):
                    if rx1 <= cx < rx2 and ry1 <= cy < ry2:
                        region_idx = i
                if 0 <= region_idx < 6:
                    label = labels[int(det[5])]
                    detection_regions[region_idx][label] = detection_regions[region_idx].get(label, 0) + 1
            output = [max(reg, key=reg.get) if reg else "0" for reg in detection_regions]
            output_str = f"Camera {camera_id} Frame {frame_num}: " + " ".join(output)
            uart.write(output_str)
            print(output_str)
            yolo.draw_result(res, pl.osd_img)
            pl.show_image()
            return output_str
        print(f"处理摄像头 {camera_id} 第{frame_num}帧时出错: {e}")
        return None
# 配置摄像头(返回实例)
def config_camera(sensor_id):
    if sensor_id==0:
        sensor1 = Sensor(id=sensor_id, vflip=True)
        sensor1.reset()
        sensor1.set_pixformat(sensor.RGB565)
        sensor1.set_framesize(sensor.SVGA)
        sensor1.set_framerate(30)
        sensor2 = Sensor(id=sensor_id, vflip=True)
        sensor2.reset()
        sensor2.set_pixformat(sensor.RGB565)
        sensor2.set_framesize(sensor.SVGA)
        sensor2.set_framerate(30)
    print(f"摄像头 {sensor_id} 配置完成")
    return sensor
# 采集并处理帧(接收 sensor 实例)
def capture_and_process_frames(yolo, pl, sensor, num_frames):
    camera_id = sensor.id
    print(f"开始从摄像头 {camera_id} 采集并处理 {num_frames} 帧...")
    for i in range(num_frames):
        img = sensor.snapshot()
        process_frame(yolo, pl, img, camera_id, i + 1)
        time.sleep_ms(10)
    print(f"摄像头 {camera_id} 采集与处理完成")
# 主程序
def main():
    camera1_id = 0
    camera2_id = 2
    frames_per_cycle = 10
    sensor1 = None
    sensor2 = None
    pl = None
    yolo = None
        pl, yolo = init_inference_system()
        # 获取配置好的 sensor 实例
        sensor1 = config_camera(camera1_id)
        if sensor1 is None:
            print(f"配置 camera {camera1_id} 失败,无法获取 sensor 实例")
        sensor2 = config_camera(camera2_id)
        if sensor2 is None:
            print(f"配置 camera {camera2_id} 失败,无法获取 sensor 实例")
        print("开始轮询采集与推理...")
            capture_and_process_frames(yolo, pl, sensor1, frames_per_cycle)
            capture_and_process_frames(yolo, pl, sensor2, frames_per_cycle)
    except KeyboardInterrupt:
        print("程序被用户中断")
        print(f"发生错误: {e}")
        yolo.deinit()
        uart.deinit()
        # 用实例重置
        sensor1.reset()
        sensor2.reset()
        print("程序结束")
    main()
以下是报错
AttributeError: 'NoneType' object has no attribute 'deinit'
File "", line 152, in
File "", line 143, in main
MPY: soft reboot
发生错误: _config() takes 2 positional arguments but 1 were given
你打印一下main方法中的yolo,看一下类型是不是对的
