我使用的是亚博的k230,现在我已经本地部署好yolo环境也训练出来了,但是我直接魔改例程权重也就是kmodel跑不了,分析出来可能问题是预训练权重没选对,因此我有两个问题
Viewed 193
from libs.AI2D import Ai2d
from time import *
import utime
import random
import aicube
person_det = None
from libs.YbProtocol import YbProtocol
from ybUtils.YbUart import YbUart
# uart = None
uart = YbUart(baudrate=115200)
pto = YbProtocol()
# 自定义人体检测类
# (Custom person detection class)
class PersonDetectionApp(AIBase):
    def __init__(self, kmodel_path, model_input_size, labels, anchors, confidence_threshold=0.2, nms_threshold=0.5, nms_option=False, strides=[8, 16, 32], rgb888p_size=[224, 224], display_size=[640, 360], debug_mode=0):
        初始化人体检测应用类
        (Initialize the person detection application class)
        参数:
        kmodel_path: 模型文件路径
        (kmodel_path: Path to the model file)
        model_input_size: 模型输入分辨率
        (model_input_size: Model input resolution)
        labels: 标签列表
        (labels: List of labels)
        anchors: 检测anchors设置
        (anchors: Detection anchor settings)
        confidence_threshold: 置信度阈值
        (confidence_threshold: Confidence threshold)
        nms_threshold: nms阈值
        (nms_threshold: NMS threshold)
        nms_option: nms是否开启
        (nms_option: Whether NMS is enabled)
        strides: 特征图降采样倍数
        (strides: Feature map downsampling factor)
        rgb888p_size: 传感器输入图像分辨率
        (rgb888p_size: Sensor input image resolution)
        display_size: 显示分辨率
        (display_size: Display resolution)
        debug_mode: 调试模式级别
        (debug_mode: Debug mode level)
        # 模型输入分辨率
        # (Model input resolution)
        # 标签
        # (Labels)
        self.labels = labels
        # 检测anchors设置
        # (Detection anchor settings)
        self.anchors = anchors
        # 特征图降采样倍数
        # (Feature map downsampling factor)
        self.strides = strides
        # 置信度阈值设置
        # (Confidence threshold setting)
        self.confidence_threshold = confidence_threshold
        # nms阈值设置
        # (NMS threshold setting)
        self.nms_threshold = nms_threshold
        self.nms_option = nms_option
        # sensor给到AI的图像分辨率
        # (Image resolution from sensor to AI)
        # 显示分辨率
        # (Display resolution)
        self.debug_mode = debug_mode
        # Ai2d实例,用于实现模型预处理
        # (Ai2d instance for model preprocessing)
        self.ai2d = Ai2d(debug_mode)
        # 设置Ai2d的输入输出格式和类型
        # (Set Ai2d input and output formats and types)
    # (Configure preprocessing operations, using pad and resize here, Ai2d supports crop/shift/pad/resize/affine)
        配置模型输入数据的预处理操作
        (Configure preprocessing operations for model input data)
        参数:
        input_image_size: 输入图像尺寸,如果为None则使用默认rgb888p_size
        (input_image_size: Input image size, if None uses default rgb888p_size)
            # (Initialize ai2d preprocessing configuration, default is the size from sensor to AI)
            top, bottom, left, right = self.get_padding_param()
            self.ai2d.pad([0, 0, 0, 0, top, bottom, left, right], 0, [0, 0, 0])
            self.ai2d.build([1, 3, ai2d_input_size[1], ai2d_input_size[0]], [1, 3, self.model_input_size[1], self.model_input_size[0]])
    # 自定义当前任务的后处理
    # (Custom post-processing for the current task)
        对模型输出进行后处理
        (Post-process the model output)
        参数:
        results: 模型的原始输出
        (results: Raw output from the model)
        返回:
        处理后的检测结果
        (Processed detection results)
            # 这里使用了aicube模型的后处理接口anchorbasedet_post_preocess
            # (Use the anchorbasedet_post_process interface from the aicube model for post-processing)
            dets = aicube.anchorbasedet_post_process(results[0], results[1], results[2], self.model_input_size, self.rgb888p_size, self.strides, len(self.labels), self.confidence_threshold, self.nms_threshold, self.anchors, self.nms_option)
            return dets
    # 绘制结果
    # (Draw results)
        在画布上绘制人体检测结果
        (Draw person detection results on the canvas)
        参数:
        pl: 画布对象
        (pl: Canvas object)
        dets: 检测结果
        (dets: Detection results)
            if dets:
                pl.osd_img.clear()
                for det_box in dets:
                    # 计算检测框在显示分辨率下的坐标和尺寸
                    # (Calculate the coordinates and size of the detection box in the display resolution)
                    x1, y1, x2, y2 = det_box[2], det_box[3], det_box[4], det_box[5]
                    w = float(x2 - x1) * self.display_size[0] // self.rgb888p_size[0]
                    h = float(y2 - y1) * self.display_size[1] // self.rgb888p_size[1]
                    x1 = int(x1 * self.display_size[0] // self.rgb888p_size[0])
                    y1 = int(y1 * self.display_size[1] // self.rgb888p_size[1])
                    x2 = int(x2 * self.display_size[0] // self.rgb888p_size[0])
                    y2 = int(y2 * self.display_size[1] // self.rgb888p_size[1])
                    # 过滤掉尺寸太小的检测框
                    # (Filter out detection boxes that are too small)
                    if (h < (0.1 * self.display_size[0])):
                    if (w < (0.25 * self.display_size[0]) and ((x1 < (0.03 * self.display_size[0])) or (x2 > (0.97 * self.display_size[0])))):
                    if (w < (0.15 * self.display_size[0]) and ((x1 < (0.01 * self.display_size[0])) or (x2 > (0.99 * self.display_size[0])))):
                    # 在画布上绘制检测框和标签
                    # (Draw the detection box and label on the canvas)
                    pl.osd_img.draw_rectangle(x1, y1, int(w), int(h), color=(255, 0, 255, 0), thickness=2)
#                    uart.send(f"${x1},{y1},{w},{h}#")
                    pl.osd_img.draw_string_advanced(x1, y1 - 50, 32, " " + self.labels[det_box[0]] + " " + str(round(det_box[1], 2)), color=(255, 0, 255, 0))
                    pto_data = pto.get_person_detect_data(x1, y1, w, h)
                    uart.send(pto_data)
                    print(pto_data)
                pl.osd_img.clear()
    # 计算padding参数
    # (Calculate padding parameters)
    def get_padding_param(self):
        计算将输入图像等比缩放到模型输入尺寸时需要的padding参数
        (Calculate the padding parameters required to proportionally scale the input image to the model input size)
        返回:
        padding参数 [top, bottom, left, right]
        (Padding parameters [top, bottom, left, right])
        input_width = self.rgb888p_size[0]
        input_high = self.rgb888p_size[1]
        ratio_w = dst_w / input_width
        ratio_h = dst_h / input_high
        if ratio_w < ratio_h:
            ratio = ratio_w
            ratio = ratio_h
        new_w = (int)(ratio * input_width)
        new_h = (int)(ratio * input_high)
        dw = (dst_w - new_w) / 2
        dh = (dst_h - new_h) / 2
        top = int(round(dh - 0.1))
        bottom = int(round(dh + 0.1))
        left = int(round(dw - 0.1))
        right = int(round(dw - 0.1))
def exce_demo(pl):
    执行人体检测演示
    (Execute person detection demo)
    参数:
    pl: PipeLine对象
    (pl: PipeLine object)
    global person_det
    display_mode = pl.display_mode
    rgb888p_size = pl.rgb888p_size
    display_size = pl.display_size
    # 设置模型路径和其他参数
    # (Set model path and other parameters)
    kmodel_path = "/data/best.kmodel"
    # 其它参数设置
    # (Other parameter settings)
    confidence_threshold = 0.2
    nms_threshold = 0.6
    labels = ["stm32"]
    anchors = [10, 13, 16, 30, 33, 23, 30, 61, 62, 45, 59, 119, 116, 90, 156, 198, 373, 326]
        # 初始化自定义人体检测实例
        # (Initialize the custom person detection instance)
        person_det = PersonDetectionApp(kmodel_path, model_input_size=[640, 640], labels=labels, anchors=anchors, confidence_threshold=confidence_threshold, nms_threshold=nms_threshold, nms_option=False, strides=[8, 16, 32], rgb888p_size=rgb888p_size, display_size=display_size, debug_mode=0)
        person_det.config_preprocess()
                # 获取当前帧数据
                # (Get the current frame data)
                img = pl.get_frame()
                # 推理当前帧
                # (Inference on the current frame)
                res = person_det.run(img)
                # 绘制结果到PipeLine的osd图像
                # (Draw the results on the PipeLine's osd image)
                person_det.draw_result(pl, res)
                # 显示当前的绘制结果
                # (Display the current drawing results)
                pl.show_image()
        print("stm32检测功能退出")
        # (Person detection function exited)
        person_det.deinit()                       # 反初始化
        # (Deinitialize)
def exit_demo():
    退出人体检测演示
    (Exit person detection demo)
    global person_det
    person_det.deinit()
    rgb888p_size = [640, 360]
    display_size = [640, 480]
    display_mode = "lcd"
    # 初始化PipeLine,用于图像处理流程
    # (Initialize PipeLine for image processing)
    pl.create()  # 创建PipeLine实例
    # (Create PipeLine instance)
    # 初始化自定义人脸检测实例
    exce_demo(pl)
两个问题:1.如果要本地训练在环境确认是没有问题之后还应该注意哪些事项;2.有没有通用的能运行kmodel的例程。我在下面附上了我改动过的代码
File "", line 97, in run_demo
File "/sdcard/libs/AIBase.py", line 74, in run
File "", line 44, in postprocess
IndexError: list index out of range
MPY: soft reboot
CanMV v1.3.5(based on Micropython e00a144) on 2025-06-30; k230_canmv_yahboom with K230
find sensor gc2093_csi2, type 8, output 1920x1080@30
total took 21.07 ms
人体检测功能退出
MPY: soft reboot
[DEBUG] main IDE interrupt
部署yolo模型请使用yolo大作战的文档中代码:https://www.kendryte.com/k230_canmv/zh/main/zh/example/ai/YOLO%E5%A4%A7%E4%BD%9C%E6%88%98.html
