k230有时候出现这个报错,是为什么啊
Viewed 231
复制代码如下:
from time import ticks_ms
sensor = None
自定义函数
# 初始化摄像头,分辨率确保为8的倍数(避免尺寸错误)
sensor = Sensor(width=480, height=320)
sensor.set_framesize(width=480, height=320)
# 初始化显示(虚拟显示模式,适配电脑IDE查看)
Display.init(Display.LT9611, to_ide=True)
    # 预处理:转为灰度图并二值化
    img_rect = img.to_grayscale(copy=True)
    img_rect = img_rect.binary([(0, 75)])
    # 查找所有矩形
    rects = img_rect.find_rects(threshold=10000)
    # 初始化参数
    max_area = 0
    max_corners = None
第一步:锁定A4纸边框
    # 遍历所有矩形,筛选最大面积矩形
    if rects:  # 确保找到矩形再处理
        for rect in rects:
            corners = rect.corners()  # 获取矩形四个角点坐标 [(x0,y0), (x1,y1), (x2,y2), (x3,y3)]
            # 转换8个坐标值为int型
            int_corners = [(int(c[0]), int(c[1])) for c in corners]
            # 计算矩形宽高(基于角点坐标,适用于轴对齐矩形)
            # 宽:x方向差值(corner[1]-corner[0])
            width = abs(corners[1][0] - corners[0][0])
            # 高:y方向差值(corner[3]-corner[0])
            height = abs(corners[3][1] - corners[0][1])
            # 计算面积(避免负数,取绝对值)
            area = width * height
            # 更新最大矩形信息
            if area > max_area:
                max_area = area
                max_corners = corners  # 保存最大矩形的角点
    # 绘制最大矩形(用红线突出显示)
    if max_corners:
        # 锁定最大矩形边框
        img.draw_line(max_corners[0][0], max_corners[0][1], max_corners[1][0], max_corners[1][1], color=(255, 0, 0), thickness=2)
        img.draw_line(max_corners[1][0], max_corners[1][1], max_corners[2][0], max_corners[2][1], color=(255, 0, 0), thickness=2)
        img.draw_line(max_corners[2][0], max_corners[2][1], max_corners[3][0], max_corners[3][1], color=(255, 0, 0), thickness=2)
        img.draw_line(max_corners[3][0], max_corners[3][1], max_corners[0][0], max_corners[0][1], color=(255, 0, 0), thickness=2)
第二步:flood-fill算法填充排除外界干扰
        img.flood_fill(x = max_corners[0][0]-5,y = max_corners[0][1]-5,color = (255,255,255))
    # 显示帧率
    img.draw_string_advanced(10, 10, 20, "fps: {}".format(int(clock.fps())), color=(255, 0, 0))
    # 传输到IDE显示
    img.compressed_for_ide()
print("用户停止: ", e)
print(f"异常: {e}")
希望正常运行,实际有时候能运行有时候不行
硬件为k230庐山派,ide版本为4.0.7-0,固件版本0.4.0
报错如下:
MPY: soft reboot
CanMV v1.3-90-gcf5bdef(based on Micropython e00a144) on 2025-07-26; k230_canmv_lckfb with K230
find sensor gc2093_csi2, type 25, output 1280x960@90
vb common pool count 4
异常: function missing 1 required positional arguments
MPY: soft reboot
你好,请参考以下代码
sensor = None
SENSOR_WIDTH = 480
SENSOR_HEIGHT = 320
SENSOR_CROP_WIDTH = 1440
SENSOR_CROP_HEIGHT = 960
sensor = Sensor()
sensor_width = sensor.width(None)
sensor_height = sensor.height(None)
sensor.set_framesize(width=480, height=320, crop = ((sensor_width - SENSOR_CROP_WIDTH) // 2, (sensor_height - SENSOR_CROP_HEIGHT) // 2, SENSOR_CROP_WIDTH, SENSOR_CROP_HEIGHT))
    # 预处理:转为灰度图并二值化
    # 查找所有矩形
    # 初始化参数
    max_area = 0
    max_corners = None
    # 遍历所有矩形,筛选最大面积矩形
        for rect in rects:
            if area > max_area:
                max_area = area
    # 绘制最大矩形(用红线突出显示)
    if max_corners:
        #img.flood_fill(x=max_corners[0][0]-5, y=max_corners[0][1]-5, color=(255, 255, 255))
        img.flood_fill(max_corners[0][0]-5, max_corners[0][1]-5, color=(255, 255, 255))
    # 显示帧率
    # 传输到IDE显示
