霍夫圆检测显示问题
Viewed 232
镜像版本:CanMV v1.3-91-g1ea9b3b(based on Micropython e00a144) on 2025-07-28; k230_canmv_01studio with K230
我想实现类似这个连接的代码示例显示效果:https://wiki.01studio.cc/docs/canmv_k230/machine_vision/image_detection/find_circles
但我基于霍夫圆检测示例无法实现,测试只能用800x480得统一尺寸显示在屏上,我得代码如下:
# MicroPython 基于 cv_lite 的 RGB888 霍夫圆检测测试代码
# RGB888 Hough Circle Detection Test using cv_lite extension
import time, os, sys, gc
from machine import Pin
from media.sensor import *    # 导入摄像头接口 / Camera interface
from media.display import *   # 导入显示接口 / Display interface
from media.media import *     # 导入媒体资源管理器 / Media manager
import _thread
import cv_lite                # 导入 cv_lite 扩展模块 / cv_lite extension
import ulab.numpy as np       # MicroPython 类 NumPy 库
# 图像尺寸设置 / Image resolution
image_shape = [480, 800]  # 高 x 宽 / Height x Width
# 初始化摄像头(RGB888格式) / Initialize camera (RGB888 format)
sensor = Sensor(id=2, width=1280, height=960)
sensor.set_framesize(width=320, height=240) #设置帧大小,默认通道0
sensor.set_pixformat(Sensor.RGB888)  # 设置 RGB888 像素格式 / Set RGB888 pixel format
# 初始化显示器(IDE虚拟显示) / Initialize display (IDE virtual output)
Display.init(Display.ST7701, width=image_shape[1], height=image_shape[0], to_ide=True, quality=100)
# 初始化媒体资源管理器 / Initialize media manager
# 启动帧率计时器 / Start FPS timer
# 霍夫圆检测参数 / Hough Circle parameters
dp = 1           # 累加器分辨率与图像分辨率的反比 / Inverse ratio of accumulator resolution
minDist = 30     # 检测到的圆心最小距离 / Minimum distance between detected centers
param1 = 80      # Canny边缘检测高阈值 / Higher threshold for Canny edge detection
param2 = 20      # 霍夫变换圆心检测阈值 / Threshold for center detection in accumulator
minRadius = 10   # 检测圆最小半径 / Minimum circle radius
maxRadius = 50   # 检测圆最大半径 / Maximum circle radius
# 主循环 / Main loop
    # 拍摄一帧图像 / Capture a frame
    img = sensor.snapshot()
    img_np = img.to_numpy_ref()  # 获取 RGB888 ndarray 引用
    # 调用 cv_lite 扩展的霍夫圆检测函数,返回圆参数列表 [x, y, r, ...]
    circles = cv_lite.rgb888_find_circles(
        image_shape, img_np, dp, minDist, param1, param2, minRadius, maxRadius
    # 遍历检测到的圆形,绘制圆形框
    for i in range(0, len(circles), 3):
        x = circles[i]
        y = circles[i + 1]
        r = circles[i + 2]
        img.draw_circle(x, y, r, color=(255, 0, 0), thickness=2)  # 红色圆圈
    # 显示带有检测圆的图像 / Display image with circles drawn
    # 垃圾回收 / Garbage collect
    # 打印帧率 / Print FPS
    print("findcircles:", clock.fps())
# 程序退出时释放资源 / Cleanup on exit
你好,参考这个。
import _thread
image_shape = [480, 640]  # 高 x 宽 / Height x Width
def calculate_crop(sensor_width, sensor_height, target_width, target_height):
    Calculate center crop rectangle from sensor resolution to match target resolution
    with preserved aspect ratio.
    Returns:
        (crop_x, crop_y, crop_width, crop_height)
    scale = min(sensor_width // target_width, sensor_height // target_height)
    crop_width = int(target_width * scale)
    crop_height = int(target_height * scale)
    crop_x = (sensor_width - crop_width) // 2
    crop_y = (sensor_height - crop_height) // 2
    return (crop_x, crop_y, crop_width, crop_height)
# 初始化摄像头(灰度图模式) / Initialize camera (grayscale mode)
sensor = Sensor(id=2, fps = 90)
sensor_width = sensor.width(None)
sensor_height = sensor.height(None)
sensor.set_framesize(width=image_shape[1], height=image_shape[0], crop = calculate_crop(sensor_width,sensor_height,image_shape[1],image_shape[0]))
sensor.set_pixformat(Sensor.RGB888)  # 灰度图格式 / Grayscale format
Display.init(Display.ST7701, to_ide=True, quality=50)
# 主循环 / Main loop
    # 遍历检测到的圆形,绘制圆形框
        x = circles[i]
        y = circles[i + 1]
        r = circles[i + 2]
    # 打印帧率 / Print FPS
参考这个代码
frame_shape, img_np, dp, minDist, param1, param2, minRadius, maxRadius
主要是之前这个函数的第一个参数不对导致出错了,把第一个参数改成你送进来的图像大小就可以了
import _thread
frame_shape = [240, 320]  # 高 x 宽 / Height x Width
sensor = Sensor(id=2, width=1280, height=720)
# 主循环 / Main loop
    # 遍历检测到的圆形,绘制圆形框
        x = circles[i]
        y = circles[i + 1]
        r = circles[i + 2]
    Display.show_image(img, x=240, y=120)
    # 打印帧率 / Print FPS
参考这个代码
import _thread
image_shape = [240, 320]  # 高 x 宽 / Height x Width
sensor = Sensor(id=2)
Display.init(Display.ST7701, width=800, height=480, to_ide=True, quality=100)
# 主循环 / Main loop
    # 遍历检测到的圆形,绘制圆形框
        x = circles[i]
        y = circles[i + 1]
        r = circles[i + 2]
    Display.show_image(img,x=(800-image_shape[1])//2,y=(480-image_shape[0])//2)
    # 打印帧率 / Print FPS
需要根据你的图片和显示的情况调整这些参数吧
只能统一480X800不然屏幕显示不了,黑屏,我之前是可以这样写法,然后能成功像01教程那样显示,现在这个只能一个800X480来用
要小于800x480,或者大于这个尺寸的图片,做一个resize来显示,不然放不下
那这个怎么整,之前矩形检测我都可以800X480中 显示320x240 用了这个cv模块反而不可了
