How to use image.draw_image on RGB888 and ARGB8888 images?
Viewed 48
I tried using draw_image from a ARGB8888 image to draw onto a ARGB8888 image, does not work
expected draw_image to work with RGB888 and ARGB8888 images, it did not
CanMV-K230-V1.1 flashed with commit 6e5135d prerelease https://github.com/kendryte/canmv_k230/releases/tag/PreRelease , using the V1P0_P1 img
I have also tried flashing with v1.3 micropython release, also same problem
board is from youyeetwo.com
no errors
using RGB565 as the image format works, but why not RGB888 and ARGB8888?
import time,os
    DISPLAY_WIDTH = 64
    DISPLAY_HEIGHT = 64
    width = DISPLAY_WIDTH
    height = DISPLAY_HEIGHT
    img = image.Image(width,height,image.RGB565)
#    img = image.Image(width,height,image.RGB888)
#    img = image.Image(width,height,image.ARGB8888)
    img.clear()
    img.draw_line(-10, -10, 10, 10, color=(255,255,255), thickness=10)
    img.draw_image(img, 32, 32, x_scale=1, y_scale=1)
    if img.format()==image.RGB888:
        print("RGB888")
    elif img.format()==image.ARGB8888:
        print("ARGB8888")
    elif img.format()==image.RGB565:
        print("RGB565")
        print(f"unknown {img.format()}")
    Display.init(Display.VIRT, width=DISPLAY_WIDTH, height=DISPLAY_HEIGHT, fps=60)
my test code
The image class is inherit from openmv, the most apis just support rgb565 format, not rgb888 and argb8888.
I see, this wasn't mentioned in the documentation so I was a little confused
