K230 V3.0开发板上电检测不到wifi模块
Viewed 92
上电检测不到wifi模块,更换确认正常的wifi模块仍未解决,wifi模块为tl8189
[2025-08-24 11:43:47.273]# RECV ASCII>
U-Boot SPL 2022.10-00006-ge0fedf31 (Aug 05 2025 - 05:52:36 +0000)
lpddr4 2660
[2025-08-24 11:43:47.329]# RECV ASCII>
[2025-08-24 11:43:47.483]# RECV ASCII>
load image 305953 bytes, time 117860 us, speed 2000 KB/s
U-Boot 2022.10-00006-ge0fedf31 (Aug 05 2025 - 05:52:36 +0000)
CPU: rv64imafdcvsu
Model: kendryte k230 canmv v3.0
DRAM: 1 GiB
Core: 26 devices, 13 uclasses, devicetree: embed
Loading Environment from MMC...
[2025-08-24 11:43:47.591]# RECV ASCII>
OK
In: serial@91400000
Out: serial@91400000
Err: serial@91400000
Net: No ethernet found.
[2025-08-24 11:43:47.733]# RECV ASCII>
load image 1667649 bytes, time 75175 us, speed 22000 KB/s
Jump to big hart
OpenSBI v1.2.2
heap: [0x0051a280 - 0x0451a280], size 65536 KB
page: [0x0451a288 - 0x1fffec00], size 453522 KB
lwIP-2.1.2 initialized!
[E/drv_touch] touch probe failed.
[2025-08-24 11:43:47.827]# RECV ASCII>
[I/SDIO] SD card capacity 62367744 KB.
found part[0], begin: 52428800, size: 10.0MB
found part[1], begin: 62914560, size: 500.0MB
found part[2], begin: 1073741824, size: 58.489GB
[2025-08-24 11:43:48.093]# RECV ASCII>
Can't find sensor on csi0
find sensor(gc2093_csi1) on csi1
Can't find sensor on csi2
vicap_mcm_init
SDK : v0.5-20250818-011442-gitlab-runner-jyosdfnqv-project-1631-concurrent-0-6c572e2
CanMV : v1.3-20250818-011442-gitlab-runner-jyosdfnqv-project-1631-concurrent-0-dd8c455
nncase: 2.9.0
msh />
[2025-08-24 11:43:48.218]# RECV ASCII>
usb disconnect
[2025-08-24 11:43:48.781]# RECV ASCII>
Interface Descriptor:
bLength: 0x09
bDescriptorType: 0x04
bInterfaceNumber: 0x00
bAlternateSetting: 0x00
bNumEndpoints: 0x03
bInterfaceClass: 0xff
bInterfaceSubClass: 0xff
bInterfaceProtocol: 0x00
iInterface: 0x00
[2025-08-24 11:43:49.465]# RECV ASCII>
usb disconnect
[2025-08-24 11:43:50.505]# RECV ASCII>
CanMV K230 start in 3264249 us
IDE debugger built Aug 18 2025 01:14:58
[mpy] enter repl
[2025-08-24 11:47:36.305]# RECV ASCII>
[hal_netmgmt]: _netmgmt_ioctl_with_type_rt_wlan_connect_config failed
[2025-08-24 11:47:46.629]# RECV ASCII>
你好,这个是你购买的v3.0板子,还是自己做的?
