mjpeg 解码速度在640*480及160*120分辨率下近似一样?
Viewed 130
【代码】我参考 reference\ai_poc\dec_ai_enc\dec_enc\dec_enc.cc 代码,去掉ai和编码部分,仅保留解码部分代码。
【操作步骤】分别解码640480和160120分辨率的mjpeg格式视频,发现两种分辨率下均为约100帧每秒的解码速度。
【需求】
可否在你们的开发板上验证一下解码速度
【疑问】
1、160*120分辨率下100帧每秒的解码速度与k230芯片手册1.2.9节相差很大。手册中为 20MBit/s。如何调整能接近芯片的理论解码速度
2、为何两种分辨率下解码速度接近
执行命令示例为:
./dec_enc.elf -i 160x120_700fps.mjpeg -o /sharefs/test_gen.h265
代码更新后命令示例为:
./dec_enc_raw.elf -i 160x120_700fps.mjpeg
CanMV-K230-LP4 V3.0
代码及视频文件见 https://github.com/gdyshi/k230_dec_enc
如果还需要其他信息,请提出。我会尽量提供
源代码:
/* Copyright (c) 2023, Canaan Bright Sight Co., Ltd
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions are met:
 * 1. Redistributions of source code must retain the above copyright
 * notice, this list of conditions and the following disclaimer.
 * 2. Redistributions in binary form must reproduce the above copyright
 * notice, this list of conditions and the following disclaimer in the
 * documentation and/or other materials provided with the distribution.
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
 * CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES,
 * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
 * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
 * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
 * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
 * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
 * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
 * NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
 * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
#include <sys/mman.h>
#include <pthread.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <signal.h>
#include <opencv2/opencv.hpp>
#include <opencv2/highgui/highgui.hpp>
#include "k_module.h"
#include "k_type.h"
#include "k_vb_comm.h"
#include "k_video_comm.h"
#include "k_sys_comm.h"
#include "mpi_vb_api.h"
#include "mpi_vdec_api.h"
#include "mpi_vo_api.h"
#include "mpi_sys_api.h"
#include "k_vdec_comm.h"
#include "k_vvo_comm.h"
#include "mpi_venc_api.h"
#include "k_venc_comm.h"
#include "mpi_vvi_api.h"
#include "vo_test_case.h"
#define ENABLE_VDEC_DEBUG    1
#define BIND_VO_LAYER   1
#ifdef ENABLE_VDEC_DEBUG
    #define vdec_debug  printf
#else
    #define vdec_debug(ARGS...)
#endif
#define MAX_WIDTH 1088
#define MAX_HEIGHT 1920
#define STREAM_BUF_SIZE MAX_WIDTH*MAX_HEIGHT
#define FRAME_BUF_SIZE MAX_WIDTH*MAX_HEIGHT*2
#define INPUT_BUF_CNT   4
#define OUTPUT_BUF_CNT  6
#define VENC_MAX_IN_FRAMES   30
#define ENABLE_VENC_DEBUG    1
#ifdef ENABLE_VDSS
    #include "k_vdss_comm.h"
    #include "mpi_vdss_api.h"
#else
    #include "mpi_vicap_api.h"
#endif
#ifdef ENABLE_VENC_DEBUG
    #define venc_debug  printf
#else
    #define venc_debug(ARGS...)
#endif
#define VE_MAX_WIDTH 1920
#define VE_MAX_HEIGHT 1080
#define VE_STREAM_BUF_SIZE ((VE_MAX_WIDTH*VE_MAX_HEIGHT/2 + 0xfff) & ~0xfff)
#define VE_FRAME_BUF_SIZE ((VE_MAX_WIDTH*VE_MAX_HEIGHT*2 + 0xfff) & ~0xfff)
#define OSD_MAX_WIDTH 1920
#define OSD_MAX_HEIGHT 1088
#define OSD_BUF_SIZE OSD_MAX_WIDTH*OSD_MAX_HEIGHT*4
#define VE_INPUT_BUF_CNT   6
#define VE_OUTPUT_BUF_CNT  15
#define OSD_BUF_CNT     20
typedef struct
    k_pixel_format chn_format;
    k_u32 file_size;
    k_s32 pool_id;
    pthread_t input_tid;
    pthread_t output_tid;
    FILE *input_file;
    k_u32 ch_id;
    char *dump_frame;
    k_u32 dump_frame_size;
    k_bool done;
    k_payload_type type;
    k_vb_blk_handle vb_handle[INPUT_BUF_CNT];
    k_pixel_format pic_format;
    k_u32 act_width;
    k_u32 act_height;
    k_u32 input_pool_id;
    k_u32 output_pool_id;
} sample_vdec_conf_t;
static sample_vdec_conf_t g_vdec_conf[VDEC_MAX_CHN_NUMS];
//****************function***********************************
static inline void CHECK_RET(k_s32 ret, const char *func, const int line)
    if (ret)
        printf("error ret %d, func %s line %d\n", ret, func, line);
*单独创建pool给解码器的输入输出使用
static k_s32 vb_create_pool(int ch)
    k_vb_pool_config pool_config;
    memset(&pool_config, 0, sizeof(pool_config));
    pool_config.blk_cnt = INPUT_BUF_CNT;
    pool_config.blk_size =STREAM_BUF_SIZE,VICAP_ALIGN_1K;
    pool_config.mode = VB_REMAP_MODE_NOCACHE;
    g_vdec_conf[ch].input_pool_id = kd_mpi_vb_create_pool(&pool_config);
    vdec_debug("input_pool_id %d\n", g_vdec_conf[ch].input_pool_id);
    pool_config.blk_cnt = OUTPUT_BUF_CNT;
    pool_config.blk_size = FRAME_BUF_SIZE,VICAP_ALIGN_1K;
    g_vdec_conf[ch].output_pool_id = kd_mpi_vb_create_pool(&pool_config);
    vdec_debug("output_pool_id %d\n", g_vdec_conf[ch].output_pool_id);
    return 0;
*销毁创建的pool
static k_s32 vb_destory_pool(int ch)
    vdec_debug("destory_pool input %d \n", g_vdec_conf[ch].input_pool_id);
    kd_mpi_vb_destory_pool(g_vdec_conf[ch].input_pool_id);
    vdec_debug("destory_pool output %d \n", g_vdec_conf[ch].output_pool_id);
    kd_mpi_vb_destory_pool(g_vdec_conf[ch].output_pool_id);
    return 0;
*vb初始化,pool个数为5,先初始化3个pool给编码器,后面再创建两个pool给解码器
static k_s32 sample_vb_init(k_u32 ch_cnt, k_bool osd_enable)
    k_s32 ret;
    k_vb_config config;
    config.max_pool_cnt = 5;
    config.comm_pool[0].blk_cnt = VE_INPUT_BUF_CNT * ch_cnt;
    config.comm_pool[0].blk_size = VE_FRAME_BUF_SIZE;
    config.comm_pool[1].blk_cnt = VE_OUTPUT_BUF_CNT * ch_cnt;
    config.comm_pool[1].blk_size =VE_STREAM_BUF_SIZE;
    config.comm_pool[2].blk_cnt = 4;
    config.comm_pool[2].blk_size =OSD_BUF_SIZE;
    config.comm_pool[2].mode = VB_REMAP_MODE_NOCACHE;
    ret = kd_mpi_vb_set_config(&config);
    venc_debug("-----------venc sample test------------------------\n");
    if (ret)
        venc_debug("vb_set_config failed ret:%d\n", ret);
    ret = kd_mpi_vb_init();
    if (ret)
        venc_debug("vb_init failed ret:%d\n", ret);
    return ret;
*vb退出
static k_s32 sample_vb_exit(void)
    k_s32 ret;
    ret = kd_mpi_vb_exit();
    if (ret)
        vdec_debug("vb_exit failed ret:%d\n", ret);
    return ret;
*解码器输入线程逻辑
static void *input_thread(void *arg)
    sample_vdec_conf_t *vdec_conf;
    k_vdec_stream stream;
    k_vb_blk_handle handle;
    k_s32 pool_id = 0;
    k_u64 phys_addr = 0;
    k_u8 *virt_addr;
    k_u8 *file_buffer = NULL;
    k_u32 blk_size, stream_len;
    k_u32 file_size = 0;
    int i = 0;
    k_s32 ret;
    vdec_conf = (sample_vdec_conf_t *)arg;
    if (vdec_conf->input_file)
        fseek(vdec_conf->input_file, 0L, SEEK_END);
        vdec_conf->file_size = ftell(vdec_conf->input_file);
        fseek(vdec_conf->input_file, 0, SEEK_SET);
    else
        vdec_conf->file_size = 0;
    vdec_debug("input file size %d\n", vdec_conf->file_size);
    blk_size = STREAM_BUF_SIZE;
    int poolid = vdec_conf->input_pool_id;
    vdec_debug("%s>poolid:%d \n", __func__, poolid);
    // 一次性读取整个文件到内存
    if (vdec_conf->input_file && vdec_conf->file_size > 0) {
        file_buffer = (k_u8 *)malloc(vdec_conf->file_size);
        if (file_buffer == NULL) {
            vdec_debug("%s malloc file buffer failed\n", __func__);
            return arg;
        // 将文件指针移动到开头
        // 一次性读取整个文件
        size_t bytes_read = fread(file_buffer, 1, vdec_conf->file_size, vdec_conf->input_file);
        if (bytes_read != vdec_conf->file_size) {
            vdec_debug("%s read file failed, expected %d bytes, got %zu bytes\n",
                       __func__, vdec_conf->file_size, bytes_read);
            free(file_buffer);
            return arg;
        vdec_debug("%s read file to memory successfully, size: %d bytes\n",
                   __func__, vdec_conf->file_size);
    // 从内存循环获取数据
    while (file_size < vdec_conf->file_size && file_buffer != NULL)
        memset(&stream, 0, sizeof(k_vdec_stream));
        handle = kd_mpi_vb_get_block(poolid, blk_size, NULL);
        if (handle == VB_INVALID_HANDLE)
            usleep(3000);
            continue;
        pool_id = kd_mpi_vb_handle_to_pool_id(handle);
        if (pool_id == VB_INVALID_POOLID)
            vdec_debug("%s get pool id error\n", __func__);
            break;
        if(i >= INPUT_BUF_CNT)
            i = 0;
        vdec_conf->pool_id = pool_id;
        vdec_conf->vb_handle[i] = handle;
        phys_addr = kd_mpi_vb_handle_to_phyaddr(handle);
        if (phys_addr == 0)
            vdec_debug("%s get phys addr error\n", __func__);
            break;
        virt_addr = (k_u8 *)kd_mpi_sys_mmap_cached(phys_addr, blk_size);
        if (virt_addr == NULL)
            vdec_debug("%s mmap error\n", __func__);
            break;
        // 从内存缓冲区复制数据,而不是从文件读取
        if (file_size + blk_size > vdec_conf->file_size)
            memcpy(virt_addr, file_buffer + file_size, (vdec_conf->file_size - file_size));
            stream_len = vdec_conf->file_size - file_size;
            stream.end_of_stream = K_TRUE;
        else
            memcpy(virt_addr, file_buffer + file_size, blk_size);
            stream_len = blk_size;
        ret = kd_mpi_sys_mmz_flush_cache(phys_addr, virt_addr, stream_len);
        CHECK_RET(ret, __func__, __LINE__);
        file_size += stream_len;
        stream.phy_addr = phys_addr;
        stream.len = stream_len;
        ret = kd_mpi_vdec_send_stream(vdec_conf->ch_id, &stream, -1);
        ret = kd_mpi_sys_munmap((void *)virt_addr, blk_size);
        ret = kd_mpi_vb_release_block(handle);
        i++;
        if (vdec_conf->done)
            break;
    // 释放内存缓冲区
    if (file_buffer) {
        free(file_buffer);
        file_buffer = NULL;
    vdec_debug("%s>done, total processed %d bytes\n", __func__, file_size);
    return arg;
* NV12(YUV420)数据是解码器输出格式,需要将其转换为RGB格式给AI使用
cv::Mat nv12ToRGBHWC(const uint8_t* nv12Data, int width, int height, uint8_t* rgbChwData) {
    cv::Mat nv12Mat(height + height / 2, width, CV_8UC1, const_cast<uint8_t*>(nv12Data));
    cv::Mat rgbMat(height, width, CV_8UC3, rgbChwData);
    cv::cvtColor(nv12Mat, rgbMat, cv::COLOR_YUV2RGB_NV12);
    // cv::imwrite("test.jpg",rgbMat);
    return rgbMat;
* AI计算后得到的RGB图像要转换成ARGB格式发送给编码器
cv::Mat convertToARGB(const cv::Mat& src) {
    CV_Assert(src.channels() == 3); // 输入图像应该是 3 通道的 RGB 图像
    cv::Mat dst(src.rows, src.cols, CV_8UC4);
    for (int y = 0; y < src.rows; ++y) {
        const cv::Vec3b* src_row = src.ptr<cv::Vec3b>(y);
        cv::Vec4b* dst_row = dst.ptr<cv::Vec4b>(y);
        for (int x = 0; x < src.cols; ++x) {
            // RGB 到 ARGB 的通道转换
            dst_row[x] = cv::Vec4b(255,src_row[x][0], src_row[x][1], src_row[x][2]);
    return dst;
*解码器输出线程逻辑
static void *output_thread(void *arg)
    k_s32 ret;
    int out_cnt;
    k_video_frame_info output;
    k_vdec_supplement_info supplement;
    FILE *output_file=NULL;
    void *virt_addr = NULL;
    k_u32 frame_size=0;
    int frame_number=0;
    //循环解码
    while (1)
        //获取解码器通道状态
        k_vdec_chn_status status;
        ret = kd_mpi_vdec_query_status(vdec_conf->ch_id, &status);
        if (status.end_of_stream)
            vdec_debug("%s>ch %d, receive eos\n", __func__, vdec_conf->ch_id);
            break;
        else
            //获取一帧数据
            ret = kd_mpi_vdec_get_frame(vdec_conf->ch_id, &output, &supplement, -1);
            if (supplement.is_valid_frame)
                out_cnt++;
            //获取nv12格式数据大小
            frame_size = status.width*status.height*3/2;
            //获取数据的虚拟地址,从帧内的物理地址做映射
            virt_addr = kd_mpi_sys_mmap_cached(output.v_frame.phys_addr[0], frame_size);
            // todo 算法运算
            if(0==out_cnt%100){
                printf("phrase %d frames. width:%d, height:%d\n",out_cnt,status.width, status.height);
                // // nv12(YUV420)转换成RGB_HWC数据
                // uint8_t *rgb_buffer = (uint8_t *)malloc(status.width * status.height * 3);
                // cv::Mat rgb_image=nv12ToRGBHWC((uint8_t *)virt_addr,status.width, status.height,rgb_buffer);
                // // 保存为 BMP 格式
                // std::string bmp_filename = "decode_"+std::to_string(out_cnt)+".bmp";
                // if (!cv::imwrite(bmp_filename, rgb_image)) {
                //     std::cerr << "Failed to save image: " << bmp_filename << std::endl;
                // } else {
                //     std::cout << "Image saved successfully: " << bmp_filename << std::endl;
            kd_mpi_sys_munmap(virt_addr, frame_size);
            ret = kd_mpi_vdec_release_frame(vdec_conf->ch_id, &output);
            if (supplement.end_of_stream)
                vdec_debug("%s>ch %d, type %d, receive eos\n", __func__, supplement.type, vdec_conf->ch_id);
                break;
    vdec_conf->done = K_TRUE;
    return arg;
    k_s32 ret;
    //**********************encoder****************************************
    //编码器配置,编码通道编号为0
    int chnum = 1;
    int ve_ch = 0;
    k_u32 output_frames = 10;
    k_u32 bitrate   = 4000;   //kbps
    int width       = 1920;
    int height      = 1080;
    pthread_t exit_thread_handle;
    //**********************decoder****************************************
    //解码器配置,解码通道编号为1
    int ch = 1;
    k_vdec_chn_attr attr;
    k_payload_type type = K_PT_BUTT;
    int j;
    int i;
    FILE *input_file = NULL;
    memset(g_vdec_conf, 0, sizeof(sample_vdec_conf_t)*VDEC_MAX_CHN_NUMS);
    //参数解析
    for (i = 1; i < argc; i += 2)
        if (strcmp(argv[i], "-help") == 0)
            printf("Please input:\n");
            printf("-i: input file name\n");
            printf("-o: output file name\n");
            printf("./sample_vdec.elf -i input_file.h265 -o output_file.h265\n");
            return -1;
        else if (strcmp(argv[i], "-i") == 0)
            printf("The answer is: %d\n", 1);
            char *ptr = strchr(argv[i + 1], '.');
            vdec_debug("infilename: %s\n", argv[i + 1]);
            if ((input_file = fopen(argv[i + 1], "rb")) == NULL)
                vdec_debug("Cannot open input file!!!\n");
                return -1;
            // 计算文件大小
            fseek(input_file, 0L, SEEK_END);
            k_u32 file_size = ftell(input_file);
            fseek(input_file, 0, SEEK_SET);
            // 设置文件大小到解码器配置中
            g_vdec_conf[ch].file_size = file_size;
            vdec_debug("input file size: %d bytes\n", file_size);
           if (strcmp(ptr, ".h265") == 0 || strcmp(ptr, ".hevc") == 0 || strcmp(ptr, ".265") == 0)
                type = K_PT_H265;
                vdec_debug("file type is H265\n");
            else if (strcmp(ptr, ".jpeg") == 0 || strcmp(ptr, ".mjpeg") == 0 || strcmp(ptr, ".jpg") == 0)
                type = K_PT_JPEG;
                vdec_debug("file type is JPEG\n");
            else
                vdec_debug("Error input type\n");
                return -1;
        else
            vdec_debug("Error :Invalid arguments %s\n", argv[i]);
            return -1;
    //vb初始化,申请两个缓冲池
    sample_vb_init(chnum, K_FALSE);
    //在编码器中已完成vb初始化,增加缓冲池用于解码器
    vb_create_pool(ch);
    //解码器设置
    g_vdec_conf[ch].ch_id = ch;
    for (j = 0; j < INPUT_BUF_CNT; j++)
        g_vdec_conf[ch].vb_handle[j] = VB_INVALID_HANDLE;
    g_vdec_conf[ch].input_file = input_file;
    attr.pic_width = MAX_WIDTH;
    attr.pic_height = MAX_HEIGHT;
    attr.frame_buf_cnt = OUTPUT_BUF_CNT;
    attr.frame_buf_size = FRAME_BUF_SIZE;
    attr.stream_buf_size = STREAM_BUF_SIZE;
    attr.type = K_PT_JPEG;
	attr.frame_buf_pool_id = g_vdec_conf[ch].output_pool_id;
    //创建解码器通道
    ret = kd_mpi_vdec_create_chn(ch, &attr);
    //启动解码器通道
    ret = kd_mpi_vdec_start_chn(ch);
    //启动两个线程,一个线程从h265文件中读取数据,另一个线程输出NV12(YUV420)格式的数据
    pthread_create(&g_vdec_conf[ch].input_tid, NULL, input_thread, &g_vdec_conf[ch]);
    pthread_create(&g_vdec_conf[ch].output_tid, NULL, output_thread, &g_vdec_conf[ch]);
    //解码结束后,停止并销毁解码器通道
    while (1)
        if (g_vdec_conf[ch].done == K_TRUE)
            ret = kd_mpi_vdec_stop_chn(ch);
            ret = kd_mpi_vdec_destroy_chn(ch);
            pthread_kill(g_vdec_conf[ch].input_tid, SIGALRM);
            pthread_join(g_vdec_conf[ch].input_tid, NULL);
            pthread_kill(g_vdec_conf[ch].output_tid, SIGALRM);
            pthread_join(g_vdec_conf[ch].output_tid, NULL);
            fclose(g_vdec_conf[ch].input_file);
            vb_destory_pool(ch);
            vdec_debug("kill ch %d thread done!\n", ch);
            usleep(10000);
            break;
        else
            usleep(50000);
    ret = kd_mpi_vdec_close_fd();
    //vb退出
    sample_vb_exit();
    vdec_debug("sample decode done!\n");
    return 0;
请将读写文件部分去掉,从内存加载帧,解码后不做保存,这部分才是解码器真实性能。如还有问题,请贴出上述功能的源码。
感谢关注!
原始代码是从reference\ai_poc\dec_ai_enc\dec_enc\dec_enc.cc改动的,保留了编码相关代码,解码后的数据并没有保存。只是循环从sd卡读取文件送给解码器
更新后的代码已改变逻辑:优化解码器输入线程,改为一次性读取文件到内存。同时为了便于阅读代码,我去掉了无关代码,请查看。
注意:cmakelist跟编译环境有关,这个还烦请自行修改一下。
代码见:https://github.com/gdyshi/k230_dec_enc
或者请提供一下官方解码器示例程序,我来验证,因为我没找到单独验证解码器的示例程序。谢谢
更新后,160120分辨率的视频解码速度仍然是约100fps,与640480分辨率的视频解码速度相当
请问你实验了吗,解码帧率这个问题能解吗?我们产品要用高帧率图片,现在处于选型阶段。如果能解我们就再等等,不能解就要看其他平台了
我发现1280x800分辨率的视频,解码速度也是接近100fps。我已经仔细检查,确认了解码线程里没有任何延时等耗时动作。
