k230编译报错:Your PATH contains spaces, TABs, and/or newline (\n) characters
Viewed 123
make -f tools/sync.mk sync BR_SRC_DIR=output/buildroot-2025.02.1 BR_OVERLAY_DIR=buildroot-overlay BR_NAME=buildroot-2025.02.1
make[1]: Entering directory '/home/jlinkx/workspace/devel-board/k230/k230_linux_sdk'
make[1]: Leaving directory '/home/jlinkx/workspace/devel-board/k230/k230_linux_sdk'
mkdir -p /home/jlinkx/workspace/devel-board/k230/k230_linux_sdk/output/k230_canmv_defconfig/images/deb
make -C output/buildroot-2025.02.1 k230_canmv_defconfig O=/home/jlinkx/workspace/devel-board/k230/k230_linux_sdk/output/k230_canmv_defconfig
make[1]: Entering directory '/home/jlinkx/workspace/devel-board/k230/k230_linux_sdk/output/buildroot-2025.02.1'
GEN /home/jlinkx/workspace/devel-board/k230/k230_linux_sdk/output/k230_canmv_defconfig/Makefile
configuration written to /home/jlinkx/workspace/devel-board/k230/k230_linux_sdk/output/k230_canmv_defconfig/.config
make[1]: Leaving directory '/home/jlinkx/workspace/devel-board/k230/k230_linux_sdk/output/buildroot-2025.02.1'
touch /home/jlinkx/workspace/devel-board/k230/k230_linux_sdk/output/k230_canmv_defconfig/.config
make -C /home/jlinkx/workspace/devel-board/k230/k230_linux_sdk/output/k230_canmv_defconfig all
make[1]: Entering directory '/home/jlinkx/workspace/devel-board/k230/k230_linux_sdk/output/k230_canmv_defconfig'
/usr/bin/make -j1 O=/home/jlinkx/workspace/devel-board/k230/k230_linux_sdk/output/k230_canmv_defconfig HOSTCC="/usr/bin/gcc" HOSTCXX="/usr/bin/g++" syncconfig
Your PATH contains spaces, TABs, and/or newline (\n) characters.
This doesn't work. Fix you PATH.
make[2]: *** [support/dependencies/dependencies.mk:27: dependencies] Error 1
make[1]: *** [Makefile:23: _all] Error 2
make[1]: Leaving directory '/home/jlinkx/workspace/devel-board/k230/k230_linux_sdk/output/k230_canmv_defconfig'
make: *** [Makefile:26: buildroot] Error 2
k230执行make CONF=k230_canmv_defconfig编译的时候出现这个报错,需要怎么解决?一定是要先生产dorker才能编译吗
提示已经比较清楚了,你的环境变量PATH存在空格、TAB、或者换行等异常字符,修改好再编译
