运行示例代码都报错
Viewed 173
venc_test start
使用CanMv IDE 文件->示例->Media->mp4muxer.py直接报错
File "", line 232, in
File "", line 65, in vi_bind_venc_mp4_test
File "", line 25, in mp4_muxer_init
OSError: kd_mp4_create failed.
MPY: soft reboot
CanMV v1.4(based on Micropython e00a144) on 2025-09-08; k230_canmv_lckfb with K230
CanMV_K230_LCKFB_micropython_v1.4-0-g6cce59c_nncase_v2.9.0.img.gz
# Save MP4 file example
# Note: You will need an SD card to run this example.
# You can capture audio and video and save them as MP4.The current version only supports MP4 format, video supports 264/265, and audio supports g711a/g711u.
from media.mp4format import *
from mpp.mp4_format import *
from media.vencoder import *
import uctypes
def mp4_muxer_init(file_name,  fmp4_flag):
    mp4_cfg = k_mp4_config_s()
    mp4_cfg.config_type = K_MP4_CONFIG_MUXER
    mp4_cfg.muxer_config.file_name[:] = bytes(file_name, 'utf-8')
    mp4_cfg.muxer_config.fmp4_flag = fmp4_flag
    handle = k_u64_ptr()
    ret = kd_mp4_create(handle, mp4_cfg)
    if ret:
        raise OSError("kd_mp4_create failed.")
    return handle.value
def mp4_muxer_create_video_track(mp4_handle, width, height, video_payload_type):
    video_track_info = k_mp4_track_info_s()
    video_track_info.track_type = K_MP4_STREAM_VIDEO
    video_track_info.time_scale = 1000
    video_track_info.video_info.width = width
    video_track_info.video_info.height = height
    video_track_info.video_info.codec_id = video_payload_type
    video_track_handle = k_u64_ptr()
    ret = kd_mp4_create_track(mp4_handle, video_track_handle, video_track_info)
    if ret:
        raise OSError("kd_mp4_create_track failed.")
    return video_track_handle.value
def mp4_muxer_create_audio_track(mp4_handle,channel,sample_rate, bit_per_sample ,audio_payload_type):
    audio_track_info = k_mp4_track_info_s()
    audio_track_info.track_type = K_MP4_STREAM_AUDIO
    audio_track_info.time_scale = 1000
    audio_track_info.audio_info.channels = channel
    audio_track_info.audio_info.codec_id = audio_payload_type
    audio_track_info.audio_info.sample_rate = sample_rate
    audio_track_info.audio_info.bit_per_sample = bit_per_sample
    audio_track_handle = k_u64_ptr()
    ret = kd_mp4_create_track(mp4_handle, audio_track_handle, audio_track_info)
    if ret:
    return audio_track_handle.value
def vi_bind_venc_mp4_test(file_name,width=1280, height=720,venc_payload_type = K_PT_H264,fmp4_flag = False):
    print("venc_test start")
    venc_chn = VENC_CHN_ID_0
    width = ALIGN_UP(width, 16)
    frame_data = k_mp4_frame_data_s()
    save_idr = bytearray(width * height * 3 // 4)
    idr_index = 0
    # mp4 muxer init
    mp4_handle = mp4_muxer_init(file_name, fmp4_flag)
    # create video track
    if venc_payload_type == K_PT_H264:
        video_payload_type = K_MP4_CODEC_ID_H264
    elif venc_payload_type == K_PT_H265:
        video_payload_type = K_MP4_CODEC_ID_H265
    mp4_video_track_handle = mp4_muxer_create_video_track(mp4_handle, width, height, video_payload_type)
    # 初始化sensor
    sensor = Sensor()
    # 设置camera 输出buffer
    # set chn0 output size
    sensor.set_framesize(width = width, height = height, alignment=12)
    # set chn0 output format
    # 实例化video encoder
    encoder = Encoder()
    # 设置video encoder 输出buffer
    encoder.SetOutBufs(venc_chn, 8, width, height)
    # 绑定camera和venc
    link = MediaManager.link(sensor.bind_info()['src'], (VIDEO_ENCODE_MOD_ID, VENC_DEV_ID, venc_chn))
    # init media manager
    if (venc_payload_type == K_PT_H264):
        chnAttr = ChnAttrStr(encoder.PAYLOAD_TYPE_H264, encoder.H264_PROFILE_MAIN, width, height)
    elif (venc_payload_type == K_PT_H265):
        chnAttr = ChnAttrStr(encoder.PAYLOAD_TYPE_H265, encoder.H265_PROFILE_MAIN, width, height)
    streamData = StreamData()
    # 创建编码器
    encoder.Create(venc_chn, chnAttr)
    # 开始编码
    encoder.Start(venc_chn)
    # 启动camera
    frame_count = 0
    print("save stream to file: ", file_name)
    video_start_timestamp = 0
    get_first_I_frame = False
            ret = encoder.GetStream(venc_chn, streamData,timeout = -1) # 获取一帧或多帧码流
            if ret != 0:
            # Retrieve first IDR frame and write to MP4 file. Note: The first frame must be an IDR frame.
            if not get_first_I_frame:
                for pack_idx in range(0, streamData.pack_cnt):
                    stream_type = streamData.stream_type[pack_idx]
                    if stream_type == encoder.STREAM_TYPE_I:
                        get_first_I_frame = True
                        video_start_timestamp = streamData.pts[pack_idx]
                        save_idr[idr_index:idr_index+streamData.data_size[pack_idx]] = uctypes.bytearray_at(streamData.data[pack_idx], streamData.data_size[pack_idx])
                        idr_index += streamData.data_size[pack_idx]
                        frame_data.codec_id = video_payload_type
                        frame_data.data = uctypes.addressof(save_idr)
                        frame_data.data_length = idr_index
                        frame_data.time_stamp = streamData.pts[pack_idx] - video_start_timestamp
                        ret = kd_mp4_write_frame(mp4_handle, mp4_video_track_handle, frame_data)
                        if ret:
                            raise OSError("kd_mp4_write_frame failed.")
                    elif stream_type == encoder.STREAM_TYPE_HEADER:
                encoder.ReleaseStream(venc_chn, streamData)
            # Write video stream to MP4 file (not first idr frame)
                frame_data.data = streamData.data[pack_idx]
                frame_data.data_length = streamData.data_size[pack_idx]
                #print("video size: ", streamData.data_size[pack_idx], "video type: ", streamData.stream_type[pack_idx],"video timestamp:",frame_data.time_stamp)
                if ret:
                frame_count += 1
            encoder.ReleaseStream(venc_chn, streamData) # 释放一帧码流
            print("frame_count = ", frame_count)
            if frame_count >= 200:
    # 停止camera
    # 销毁camera和venc的绑定
    del link
    # 停止编码
    encoder.Stop(venc_chn)
    # 销毁编码器
    encoder.Destroy(venc_chn)
    # 清理buffer
    # mp4 muxer destroy
    kd_mp4_destroy_tracks(mp4_handle)
    kd_mp4_destroy(mp4_handle)
    print("record mp4 done")
def mp4_muxer_test():
    print("mp4_muxer_test start")
    width = 1280
    height = 720
    # 实例化mp4 container
    mp4_muxer = Mp4Container()
    #mp4_muxer = Mp4Container(sensor_csi_id = 2)  # 指定探测CSI2的sensor
    mp4_cfg = Mp4CfgStr(mp4_muxer.MP4_CONFIG_TYPE_MUXER)
    if mp4_cfg.type == mp4_muxer.MP4_CONFIG_TYPE_MUXER:
        file_name = "/data/test.mp4"
        mp4_cfg.SetMuxerCfg(file_name, mp4_muxer.MP4_CODEC_ID_H265, width, height, mp4_muxer.MP4_CODEC_ID_G711U)
    # 创建mp4 muxer
    mp4_muxer.Create(mp4_cfg)
    # 启动mp4 muxer
    mp4_muxer.Start()
    frame_count = 0
            # 处理音视频数据,按MP4格式写入文件
            mp4_muxer.Process()
            frame_count += 1
    # 停止mp4 muxer
    mp4_muxer.Stop()
    # 销毁mp4 muxer
    mp4_muxer.Destroy()
    print("mp4_muxer_test stop")
    vi_bind_venc_mp4_test("/data/test.mp4", 1280, 720)
    #mp4_muxer_test()
你好,请修改这2个文件名,保证文件创建成功。
我直接复制你的代码,运行也是报错
venc_test start
MPY: soft reboot
