OV5647: Not getting higher FPS
Viewed 141
I'm testing example code for sensor camera_single_show_hdmi.py.
I tried all CSI ports (CSI0-1-2), Frame size & FPS, but not getting FPS higher than 30. It always remain at 30 FPS whether any setting.
# Camera Example
import time, os, sys
sensor = None
    print("camera_test")
    sensor = Sensor(id = 1, fps = 60)
    # sensor reset
    # set hmirror
    # sensor.set_hmirror(False)
    # sensor vflip
    # sensor.set_vflip(False)
    # set chn0 output size, 1920x1080
    sensor.set_framesize(Sensor.VGA)
    # set chn0 output format
    # bind sensor chn0 to display layer video 1
    # set chn1 output format
    sensor.set_framesize(width = 640, height = 480, chn = CAM_CHN_ID_1)
    sensor.set_pixformat(Sensor.RGB888, chn = CAM_CHN_ID_1)
    # set chn2 output format
    sensor.set_framesize(width = 640, height = 480, chn = CAM_CHN_ID_2)
    sensor.set_pixformat(Sensor.RGB565, chn = CAM_CHN_ID_2)
    # use hdmi as display output
    Display.init(Display.VIRT, to_ide = True, osd_num = 2)
    # init media manager
    # sensor start run
        img = sensor.snapshot(chn = CAM_CHN_ID_1)
        Display.show_image(img, alpha = 128)
        img = sensor.snapshot(chn = CAM_CHN_ID_2)
        Display.show_image(img, x = 1920 - 640, layer = Display.LAYER_OSD1)
    print("user stop: ", e)
    # sensor stop run
    # deinit display
    # release media buffer
CanMV-K230-LP4-V3.0
CanMV_K230_V3P0_micropython_v1.4-0-g6cce59c_nncase_v2.9.0.img
Logs:
find sensor ov5647_csi1, type 6, output 1920x1080@30
vb common pool count 6
In the above code, I already set framesize to VGA.
Still getting "output 1920x1080@30"
How to set camera output to VGA to get more FPS?
@xelll
sensor = Sensor(id = 2, width = 640, height = 480, fps = 90)
You should use this to selet 640x480@90 sensor type.
