我想写一个静态识别检测得功能
Viewed 74
下面是物体检测得代码,我想加入按键按下才实现检测识别的代码,但是发现PipeLine接口会一直刷新摄像头画面,尝试过用sensor,sensor.snapshot() #拍摄一张图传给ai但是一直卡死也并无报错日志,我想请问下怎么在下面得这个代码中实现我想要的静态识别功能呢,就是按下按键才刷新画面,不按就保留上一次检测得画面
实验名称:物体检测(基于yolov8n)
实验平台:01Studio CanMV K230
教程:wiki.01studio.cc
说明:可以通过display="xxx"参数选择"hdmi"、"lcd3_5"(3.5寸mipi屏)或"lcd2_4"(2.4寸mipi屏)显示方式
from libs.AI2D import Ai2d
from time import *
import utime
import random
import aidemo
# 自定义YOLOv8检测类
        self.kmodel_path=kmodel_path
        self.labels=labels
        # 模型输入分辨率
        # 阈值设置
        # sensor给到AI的图像分辨率
        # 显示分辨率
        self.debug_mode=debug_mode
        # 检测框预置颜色值
        self.color_four=[(255, 220, 20, 60), (255, 119, 11, 32), (255, 0, 0, 142), (255, 0, 0, 230),
                         (255, 0, 226, 252), (255, 182, 182, 255), (255, 0, 82, 0), (255, 120, 166, 157)]
        # 宽高缩放比例
        # Ai2d实例,用于实现模型预处理
        self.ai2d=Ai2d(debug_mode)
        # 设置Ai2d的输入输出格式和类型
    # 配置预处理操作,这里使用了resize,Ai2d支持crop/shift/pad/resize/affine,具体代码请打开/sdcard/libs/AI2D.py查看
    # 自定义当前任务的后处理
            result=results[0]
            result = result.reshape((result.shape[0] * result.shape[1], result.shape[2]))
            output_data = result.transpose()
            boxes_ori = output_data[:,0:4]
            scores_ori = output_data[:,4:]
            confs_ori = np.max(scores_ori,axis=-1)
            inds_ori = np.argmax(scores_ori,axis=-1)
            boxes,scores,inds = [],[],[]
            for i in range(len(boxes_ori)):
                if confs_ori[i] > confidence_threshold:
                    scores.append(confs_ori[i])
                    inds.append(inds_ori[i])
                    x = boxes_ori[i,0]
                    y = boxes_ori[i,1]
                    w = boxes_ori[i,2]
                    h = boxes_ori[i,3]
                    left = int((x - 0.5 * w) * self.x_factor)
                    top = int((y - 0.5 * h) * self.y_factor)
                    right = int((x + 0.5 * w) * self.x_factor)
                    bottom = int((y + 0.5 * h) * self.y_factor)
                    boxes.append([left,top,right,bottom])
            if len(boxes)==0:
                return []
            boxes = np.array(boxes)
            scores = np.array(scores)
            inds = np.array(inds)
            # NMS过程
            keep = self.nms(boxes,scores,nms_threshold)
            dets = np.concatenate((boxes, scores.reshape((len(boxes),1)), inds.reshape((len(boxes),1))), axis=1)
            dets_out = []
            for keep_i in keep:
                dets_out.append(dets[keep_i])
            dets_out = np.array(dets_out)
            dets_out = dets_out[:self.max_boxes_num, :]
            return dets_out
    # 绘制结果
    def draw_result(self,pl,dets):
            if dets:
                pl.osd_img.clear()
                for det in dets:
                    x= x1*self.display_size[0] // self.rgb888p_size[0]
                    y= y1*self.display_size[1] // self.rgb888p_size[1]
                    w = (x2 - x1) * self.display_size[0] // self.rgb888p_size[0]
                    h = (y2 - y1) * self.display_size[1] // self.rgb888p_size[1]
                    pl.osd_img.draw_rectangle(x,y, w, h, color=self.get_color(int(det[5])),thickness=4)
                    pl.osd_img.draw_string_advanced( x , y-50,32," " + self.labels[int(det[5])] + " " + str(round(det[4],2)) , color=self.get_color(int(det[5])))
                pl.osd_img.clear()
    # 多目标检测 非最大值抑制方法实现
    def nms(self,boxes,scores,thresh):
        x1,y1,x2,y2 = boxes[:, 0],boxes[:, 1],boxes[:, 2],boxes[:, 3]
        keep = []
        while order.size > 0:
            i = order[0]
            keep.append(i)
            new_x1,new_y1,new_x2,new_y2,new_areas = [],[],[],[],[]
            for order_i in order:
                new_x1.append(x1[order_i])
                new_x2.append(x2[order_i])
                new_y1.append(y1[order_i])
                new_y2.append(y2[order_i])
            new_x1 = np.array(new_x1)
            new_x2 = np.array(new_x2)
            new_y1 = np.array(new_y1)
            new_y2 = np.array(new_y2)
            inter = w * h
            new_order = []
                if ind < thresh:
        return keep
    # 根据当前类别索引获取框的颜色
    def get_color(self, x):
        idx=x%len(self.color_four)
        return self.color_four[idx]
    # 显示模式,可以选择"hdmi"、"lcd3_5"(3.5寸mipi屏)和"lcd2_4"(2.4寸mipi屏)
    display="lcd3_5"
    if display=="hdmi":
        display_mode='hdmi'
    elif display=="lcd3_5":
        display_mode= 'st7701'
        display_size=[800,480]
    elif display=="lcd2_4":
        display_size=[640,480]
    rgb888p_size=[320,320] #特殊尺寸定义
    # 模型路径
    kmodel_path="/sdcard/examples/kmodel/yolov8n_320.kmodel"
    # 其它参数设置
    confidence_threshold = 0.2
    nms_threshold = 0.2
    max_boxes_num = 50
    # 初始化PipeLine
    if display =="lcd2_4":
        pl.create(Sensor(width=1280, height=960))  # 创建PipeLine实例,画面4:3
        pl.create(Sensor(width=1920, height=1080))  # 创建PipeLine实例
    # 初始化自定义目标检测实例
    ob_det=ObjectDetectionApp(kmodel_path,labels=labels,model_input_size=[320,320],max_boxes_num=max_boxes_num,confidence_threshold=confidence_threshold,nms_threshold=nms_threshold,rgb888p_size=rgb888p_size,display_size=display_size,debug_mode=0)
    ob_det.config_preprocess()
        img=pl.get_frame() # 获取当前帧数据
        res=ob_det.run(img) # 推理当前帧
        ob_det.draw_result(pl,res) # 绘制结果到PipeLine的osd图像
        print(res)  # 打印当前结果
        pl.show_image() # 显示当前的绘制结果
        print(clock.fps()) #打印帧率
01studioK230
CanMV v1.4(based on Micropython e00a144) on 2025-09-08; k230_canmv_01studio with K230
复杂功能丢弃PipeLine,直接使用sensor实现拿图显示,可以参考https://www.kendryte.com/answer/questions/10010000000007579/10020000000007580
把PipeLine的内容拿出来,然后再把按键的功能集成进去
