k230 linux sdk 烧录后不正常
Viewed 104
官网现成的镜像和自己编译的镜像表现都一样, 生成img 后,在rufus 烧录后启动,启动报错:Starting system message bus: done
Starting bluetoothd: OK
Starting network: udhcpc: started, v1.36.1
udhcpc: broadcasting discover
udhcpc: no lease, forking to background
OK
Starting sntp: sntp Wed Apr 2 02:39:50 UTC 2025 (1)
pool.ntp.org lookup error Temporary failure in name resolution
FAIL
Starting ntpd: OK
Starting sshd: OK
Starting telnetd: OK
first boot flag
Error: The backup GPT table is corrupt, but the primary appears OK, so that will
be used.
然后就死机,检查确认过sd卡正常,烧录双系统就没事
板子是 CANMV_K230 _LP4 V3.0
烦请指点,感谢答疑解惑
k230 linux sdk
