please run MediaManager._config() before MediaManager.init()
Viewed 60
import time, os
from machine import Pin, PWM, FPIOA, TOUCH
from media.media import MediaManager
DISPLAY_WIDTH, DISPLAY_HEIGHT = 800, 480
# 舵机与流量检测相关
fpioa.set_function(42, FPIOA.PWM0)
S1 = PWM(0, 50, 0, enable=True)
def set_servo_angle(angle):
    min_pulse = 500
    max_pulse = 2500
    angle = max(0.0, min(270.0, angle))
    pulse_width = min_pulse + (angle / 270.0) * (max_pulse - min_pulse)
    duty_cycle = (pulse_width / 20000.0) * 100.0
    S1.duty(duty_cycle)
    return angle, pulse_width, duty_cycle
ROI_X, ROI_Y, ROI_WIDTH, ROI_HEIGHT = 380, 0, 40, 380
ZERO_FLOW_Y = ROI_Y + ROI_HEIGHT
MAX_FLOW_Y = ROI_Y
SCALE_START, SCALE_END = 0.16, 1.6  # 流量范围
EMA_ALPHA = 0.6
def calculate_flow_rate(y_position):
    if y_position < MAX_FLOW_Y:
        y_position = MAX_FLOW_Y
    elif y_position > ZERO_FLOW_Y:
        y_position = ZERO_FLOW_Y
    position_ratio = (ZERO_FLOW_Y - y_position) / (ZERO_FLOW_Y - MAX_FLOW_Y)
    flow_rate = SCALE_START + position_ratio * (SCALE_END - SCALE_START)
    return flow_rate
def detect_flow(img):
    roi_img = img.copy(roi=(ROI_X, ROI_Y, ROI_WIDTH, ROI_HEIGHT))
        roi_img = roi_img.gaussian(3)
    except: pass
    circles = roi_img.find_circles(
        threshold=800,
        x_margin=8,
        y_margin=8,
        r_margin=6,
        r_min=1,
        r_max=3
    detected_circles = []
    if circles:
        for circle in circles:
            x = circle.x() + ROI_X
            y = circle.y() + ROI_Y
            detected_circles.append((x, y, circle.r()))
    return detected_circles
class PIDController:
    def __init__(self, kp=60.0, ki=8.0, kd=2.0, dt=0.2, output_limit=20.0, integral_limit=100.0):
        self.kp = kp; self.ki = ki; self.kd = kd; self.dt = dt
        self.output_limit = output_limit
        self.integral_limit = integral_limit
        self._integral = 0.0
        self._prev_error = 0.0
    def reset(self): self._integral = 0.0; self._prev_error = 0.0
    def update(self, setpoint, measurement):
        error = setpoint - measurement
        self._integral += error * self.dt
        self._integral = min(max(self._integral, -self.integral_limit), self.integral_limit)
        derivative = (error - self._prev_error) / self.dt
        out = self.kp * error + self.ki * self._integral + self.kd * derivative
        out = min(max(out, -self.output_limit), self.output_limit)
        self._prev_error = error
        return out
def load_flow_schedule(filename='/sdcard/data.txt'):
    arr = []
        with open(filename, 'r') as f:
            for line in f:
                vals = line.strip().split(',')
                if len(vals) == 2:
                        flow = float(vals[0].replace('ml','').replace('L','').strip())
                        dur = float(vals[1].replace('s','').replace('min','').strip())
                        arr.append([flow, dur])
                    except: pass
    except: pass
    return arr
def save_flow_schedule(data_array, filename='/sdcard/data.txt'):
        with open(filename, 'w') as f:
            for row in data_array:
                f.write("{},{}\n".format(row[0], row[1]))
    except: pass
# --- 简单数字键盘UI ----
keys = [
    ['1', '2', '3', '←'],
    ['4', '5', '6', 'Clear'],
    ['7', '8', '9', 'OK'],
    ['0', '', '', '']
KEY_W = 180
KEY_H = 90
KEY_START_X = 70
KEY_START_Y = 60
def draw_keyboard(img, input_text, step, data_array):
    img.clear()
    tip = "输入流量:" if step == 0 else "输入时间(秒):"
    img.draw_string(60, 20, tip, scale=2)
    img.draw_string(350, 20, input_text, scale=3)
    for row in range(len(keys)):
        for col in range(len(keys[row])):
            key = keys[row][col]
            key_x = KEY_START_X + col * KEY_W
            key_y = KEY_START_Y + row * KEY_H
            if key:
                img.draw_rectangle(key_x, key_y, KEY_W - 10, KEY_H - 10, thickness=2, fill=True)
                kw = KEY_W - 10
                kh = KEY_H - 10
                text_x = key_x + kw//2 - 20
                text_y = key_y + kh//2 - 20
                img.draw_string(text_x, text_y, key, scale=3)
    # 显示保存的数据
    img.draw_string(60, 450, "已保存数据:", scale=2)
    show_data = data_array[-6:]
    col_x = [60, 320, 560]
    row_y = [410, 440]
    for idx, row in enumerate(show_data):
        s = "{}.流量:{} 时间:{}".format(len(data_array)-len(show_data)+idx+1, row[0], row[1])
        col = idx % 3
        row_idx = idx // 3
        img.draw_string(col_x[col], row_y[row_idx], s, scale=2)
    # 增加返回主界面按钮
    img.draw_rectangle(700, 20, 80, 60, thickness=2, fill=True)
    img.draw_string(710,30,"返回",scale=2)
def get_keyboard_touch(x, y):
    # 按钮区域
            if key and key_x < x < key_x + KEY_W and key_y < y < key_y + KEY_H:
                return key
    # 判断返回主界面按钮
    if 700 < x < 780 and 20 < y < 80:
        return 'Back'
    return None
def draw_main_gui(img, step, elapsed, total_steps, flow_val):
    img.clear()
    img.draw_rectangle(50, 40, 700, 380, thickness=4)
    img.draw_string(320, 70, "Step {}".format(step+1), scale=4)
    img.draw_string(290, 170, "流量: {:.2f}L/min".format(flow_val), scale=4)
    img.draw_string(270, 270, "已累计时间: {:.1f}s".format(elapsed), scale=3)
    img.draw_string(320, 350, "Set", scale=4)  # Set按钮区域
def main():
    tp = TOUCH(0)
    sensor0 = Sensor(id=0)
    sensor0.reset()
    sensor0.set_framesize(width=DISPLAY_WIDTH, height=DISPLAY_HEIGHT)
    sensor0.set_pixformat(Sensor.RGB565)
    sensor0.set_vflip(True)
    sensor0.set_hmirror(True)
    sensor0.run()
    data_array = load_flow_schedule()
    step = 0
    step_start_ms = time.ticks_ms()
    input_text = ""
    input_mode = False
    input_step = 0
    cur_row = [None, None]
    last_touch = False
    current_angle = 135.0
    set_servo_angle(current_angle)
    pid = PIDController()
    filtered_flow = 0.0
        img = image.Image(DISPLAY_WIDTH, DISPLAY_HEIGHT, image.RGB888)
        now_ms = time.ticks_ms()
        if not input_mode:
            raw_elapsed = time.ticks_diff(now_ms, step_start_ms) / 1000
            snap = sensor0.snapshot(chn=0)
            circles = detect_flow(snap)
            measured_flow = 0.0
            if circles:
                x0, y0, r0 = circles[0]
                measured_flow = calculate_flow_rate(y0)
                filtered_flow = EMA_ALPHA * measured_flow + (1 - EMA_ALPHA) * filtered_flow
            target_flow = float(data_array[step][0]) if step < len(data_array) else 0.2
            if circles and step < len(data_array):
                error = target_flow - filtered_flow
                pid_out = pid.update(target_flow, filtered_flow)
                delta = -1 * pid_out
                new_angle = current_angle + delta
                new_angle = max(0.0, min(270.0, new_angle))
                if abs(new_angle - current_angle) >= 0.1:
                    current_angle = new_angle
            if step < len(data_array) and len(data_array) > 0:
                    step_time = float(data_array[step][1]) if data_array[step][1] else 10
                except:
                    step_time = 10
                if raw_elapsed >= step_time:
                    step += 1
                    if step >= len(data_array):
                        step = 0
            draw_main_gui(img, step, raw_elapsed, len(data_array), filtered_flow)
            draw_keyboard(img, input_text, input_step, data_array)
            import IDE
            IDE.display(img)
        except: pass
        p = tp.read()
        if p != () and not last_touch:
            last_touch = True
            for i in range(len(p)):
                x = p[i].x
                y = p[i].y
                if not input_mode:
                    if 320 < x < 480 and 350 < y < 420:  # Set按钮
                        input_mode = True
                        input_text = ""
                        input_step = 0
                    key = get_keyboard_touch(x, y)
                    if key:
                        if key == '←':
                            input_text = input_text[:-1]
                        elif key == 'Clear':
                            data_array = []
                            save_flow_schedule(data_array)
                        elif key == 'Back':
                            input_mode = False
                            step = 0
                        elif key == 'OK':
                            if input_text == "":
                            if input_step == 0:
                                cur_row[0] = input_text
                                input_text = ""
                                input_step = 1
                            elif input_step == 1:
                                cur_row[1] = input_text
                                input_text = ""
                                input_step = 0
                                data_array.append([cur_row[0], cur_row[1]])
                        elif len(key) == 1 and key.isdigit() and len(input_text) < 6:
                            input_text += key
        if p == ():
            last_touch = False
if __name__=='__main__':
    main()
两个脚本分开使用没有问题 整合后出现问题
def main():
你好,这个要放到loop之前。不能这么早调用。
