关于osd层配置和DMA的使用
Viewed 74
运行后报错,Traceback (most recent call last):
File "", line 188, in
File "/sdcard/libs/PipeLine.py", line 142, in show_image
File "media/display.py", line 811, in show_image
RuntimeError: OSD rotate error 3, -1
下面是串口终端
[tuning] dev: 0
acq_win.width: 1920
acq_win.height: 1080
pipe_ctrl: 4261412857
sensor_fd: 10
sensor_type: 9
sensor_name: gc2093_csi2
database_name: gc2093-1920x1080
buffer_num: 0
buffer_size: 0
[tuning] chn: 0
out_win.width: 960
out_win.height: 536
bit_width: 0
pix_format: 5
buffer_num: 6
buffer_size: 774144
yraw_size: 0
uv_size: 0
v_size: 0
block_type: 1
wait_time: 500
chn_enable: 1
kd_mpi_isp_set_output_chn_format, width(960), height(536), pix_format(5)
kd_mpi_isp_set_output_chn_format, width(320), height(320), pix_format(16)
[dw] init, version Apr 23 2025 00:06:17
=== OSD旋转调试 ===
旋转标志: 2
输入尺寸: 960x536
输出尺寸: 536x960
输入stride: 3840
输出stride: 2144
90/270度旋转: 原高度=536, 旋转后宽度=536
旋转后宽度是否8对齐: 是
<3>[20] [Func]:gdma_vb_source_init [Line]:348 [Info]:no blk
kd_mpi_isp_stop_stream chn enable is 1
kd_mpi_isp_stop_stream chn enable is 0
release reserved vb 549309440
release reserved vb 559648768
ch 3: 131 pictures encoded. Average FrameRate = 37 Fps
ch 3: total used pages 549
[mpy] exit, reset
did't init dma_dev
<3>[4] [Func]:vb_do_exit [Line]:1569 [Info]:vb already exited!
[mpy] enter script
我在终端cat /proc/umap/dma结果是和文档例程结果一样的
使用NT35516屏幕,执行烧录的aikmodel,实现摄像头(gc2093)摄像,ide和lcd同时显示,并运行ai。
rt-smart ai学习套件
k230_canmv_dongshanpi_sdcard__nncase_v2.9.0
main.py
本程序遵循GPL V3协议, 请遵循协议
实验平台: DshanPI CanMV
开发板文档站点	: https://eai.100ask.net/
百问网学习平台   : https://www.100ask.net
百问网官方B站    : https://space.bilibili.com/275908810
百问网官方淘宝   : https://100ask.taobao.com
from libs.AI2D import Ai2d
from time import *
import utime
import random
import aidemo
# ===================== 2. 核心外设配置(仅保留需要的,整洁清晰) =====================
DISPLAY_WIDTH = 960  # LCD物理宽度(原生)
DISPLAY_HEIGHT = 540 # LCD物理高度(原生)
# 对齐函数(按需保留,适配Camera要求)
def align_to_8(x):
    return (x // 8) * 8
def align_to_16(x):
    return (x // 16) * 16
# Sensor输出尺寸(对齐后,替换原1280x720)
SENSOR_WIDTH = DISPLAY_WIDTH
SENSOR_HEIGHT = 536
# 自定义人脸检测类,继承自AIBase基类
    def __init__(self, kmodel_path, anchors, model_input_size=[640,640], confidence_threshold=0.5, nms_threshold=0.2, rgb888p_size=[224,224], display_size=[1920,1080], debug_mode=0):
        super().__init__(kmodel_path, model_input_size, rgb888p_size, debug_mode)  # 调用基类的构造函数
        self.kmodel_path = kmodel_path  # 模型文件路径
        self.model_input_size = model_input_size  # 模型输入分辨率
        self.confidence_threshold = confidence_threshold  # 置信度阈值
        self.nms_threshold = nms_threshold  # NMS(非极大值抑制)阈值
        self.anchors = anchors  # 锚点数据,用于目标检测
        self.rgb888p_size = [align_to_16(rgb888p_size[0]), rgb888p_size[1]]  # sensor给到AI的图像分辨率,并对宽度进行16的对齐
        self.display_size = [align_to_16(display_size[0]), display_size[1]]  # 显示分辨率,并对宽度进行16的对齐
        self.debug_mode = debug_mode  # 是否开启调试模式
        self.ai2d = Ai2d(debug_mode)  # 实例化Ai2d,用于实现模型预处理
        self.ai2d.set_ai2d_dtype(nn.ai2d_format.NCHW_FMT, nn.ai2d_format.NCHW_FMT, np.uint8, np.uint8)  # 设置Ai2d的输入输出格式和类型
        # ========== 注释掉打印:初始化时的尺寸信息 ==========
        # print(f"【初始化】rgb888p_size: {self.rgb888p_size}, 宽度16对齐后是否8对齐?{self.rgb888p_size[0]%8==0}")
        # print(f"【初始化】display_size: {self.display_size}, 宽度16对齐后是否8对齐?{self.display_size[0]%8==0}")
        with ScopedTiming("set preprocess config", self.debug_mode > 0):  # 计时器,如果debug_mode大于0则开启
            ai2d_input_size = input_image_size if input_image_size else self.rgb888p_size  # 初始化ai2d预处理配置,默认为sensor给到AI的尺寸,可以通过设置input_image_size自行修改输入尺寸
            # ========== 注释掉打印:AI2D输入尺寸 ==========
            # print(f"【AI2D】输入尺寸: {ai2d_input_size}, 宽度是否8对齐?{ai2d_input_size[0]%8==0}")
            top, bottom, left, right = self.get_padding_param()  # 获取padding参数
            self.ai2d.pad([0, 0, 0, 0, top, bottom, left, right], 0, [104, 117, 123])  # 填充边缘
            self.ai2d.resize(nn.interp_method.tf_bilinear, nn.interp_mode.half_pixel)  # 缩放图像
            self.ai2d.build([1,3,ai2d_input_size[1],ai2d_input_size[0]],[1,3,self.model_input_size[1],self.model_input_size[0]])  # 构建预处理流程
    # 自定义当前任务的后处理,results是模型输出array列表,这里使用了aidemo库的face_det_post_process接口
            if len(post_ret) == 0:
                return post_ret
                return post_ret[0]
    # 绘制检测结果到画面上
            if dets:
                pl.osd_img.clear()  # 清除OSD图像
                # ========== 注释掉打印:PipeLine内部实际尺寸 ==========
                # print(f"【PipeLine】内部rgb888p_size: {pl.rgb888p_size}, 宽度是否8对齐?{pl.rgb888p_size[0]%8==0}")
                # print(f"【PipeLine】内部display_size: {pl.display_size}, 宽度是否8对齐?{pl.display_size[0]%8==0}")
                for i, det in enumerate(dets):
                    # 将检测框的坐标转换为显示分辨率下的坐标
                    x_origin = x  # 原始值
                    y_origin = y
                    w_origin = w
                    h_origin = h
                    # ========== 注释掉打印:检测框坐标信息 ==========
                    # print(f"【检测框{i}】原始坐标: x={x_origin}, y={y_origin}, w={w_origin}, h={h_origin}")
                    # print(f"【检测框{i}】缩放后坐标: x={x}, y={y}, w={w}, h={h}")
                    # print(f"【检测框{i}】缩放后宽度w是否8对齐?{w%8==0}, x是否8对齐?{x%8==0}")
                    pl.osd_img.draw_rectangle(x, y, w, h, color=(255, 255, 0, 255), thickness=2)  # 绘制矩形框
                pl.osd_img.clear()
                # ========== 注释掉打印:无检测框时也打印PipeLine尺寸 ==========
                # print(f"【无检测框】PipeLine内部display_size: {pl.display_size}, 宽度是否8对齐?{pl.display_size[0]%8==0}")
    # 获取padding参数
    def get_padding_param(self):
        dst_w = self.model_input_size[0]  # 模型输入宽度
        dst_h = self.model_input_size[1]  # 模型输入高度
        ratio_w = dst_w / self.rgb888p_size[0]  # 宽度缩放比例
        ratio_h = dst_h / self.rgb888p_size[1]  # 高度缩放比例
        new_w = int(ratio * self.rgb888p_size[0])  # 新宽度
        new_h = int(ratio * self.rgb888p_size[1])  # 新高度
        # ========== 注释掉打印:Padding参数 ==========
        # print(f"【Padding】模型输入尺寸: {self.model_input_size}, 缩放后宽度new_w={new_w}, 是否8对齐?{new_w%8==0}")
        dw = (dst_w - new_w) / 2  # 宽度差
        dh = (dst_h - new_h) / 2  # 高度差
        top = int(round(0))
        left = int(round(0))
    display_mode="lcd"
    # k230保持不变,k230d可调整为[640,360]
    #osd层内容,保证和sensor层一致
    rgb888p_size = [320, 320]
    #rgb888p_size = [640,480]
    display_size = [960, 540]
    # ========== 注释掉打印:主程序初始尺寸 ==========
    # print(f"【主程序】初始rgb888p_size: {rgb888p_size}, 宽度是否8对齐?{rgb888p_size[0]%8==0}")
    # print(f"【主程序】初始display_size: {display_size}, 宽度是否8对齐?{display_size[0]%8==0}")
    # 设置模型路径和其他参数
    # 其它参数
    confidence_threshold = 0.5
    nms_threshold = 0.2
    anchor_len = 4200
    det_dim = 4
    # 初始化PipeLine,用于图像处理流程
    '''Display.init(
        type=Display.NT35516,
        width=960,
        height=540,
        flag=Display.FLAG_ROTATION_0,  # 强制关闭旋转,替换默认的90度
        osd_num=3,
        to_ide=True
    pl = PipeLine(rgb888p_size=rgb888p_size, display_size=display_size, display_mode=display_mode,osd_layer_num=3)
    pl.create()  # 创建PipeLine实例
    #pl.display_size = [536, 960]
    # ========== 注释掉打印:PipeLine初始化后尺寸 ==========
    # print(f"【PipeLine初始化后】rgb888p_size: {pl.rgb888p_size}, 宽度是否8对齐?{pl.rgb888p_size[0]%8==0}")
    # print(f"【PipeLine初始化后】display_size: {pl.display_size}, 宽度是否8对齐?{pl.display_size[0]%8==0}")
    # 初始化自定义人脸检测实例
    face_det.config_preprocess()  # 配置预处理
            os.exitpoint()                      # 检查是否有退出信号
            with ScopedTiming("total",1):
                img = pl.get_frame()            # 获取当前帧数据
                # ========== 注释掉打印:获取帧后的尺寸 ==========
                # print(f"【获取帧】img尺寸: {img.shape if hasattr(img, 'shape') else '未知'}, 宽度是否8对齐?{img.shape[2]%8==0 if hasattr(img, 'shape') else '未知'}")
                res = face_det.run(img)         # 推理当前帧
                face_det.draw_result(pl, res)   # 绘制结果
                # ========== 注释掉打印:显示前最终尺寸 ==========
                # print(f"【显示前】最终传给show_image的display宽度: {pl.display_size[0]}, 是否8对齐?{pl.display_size[0]%8==0}")
                pl.show_image()                 # 显示结果
                gc.collect()                    # 垃圾回收
        sys.print_exception(e)                  # 打印异常信息
        face_det.deinit()                       # 反初始化
        pl.destroy()                            # 销毁PipeLine实例
PipeLine.py
from libs.Utils import ScopedTiming
import utime
#NT35516强制要求960x540,底层硬件和驱动要求对齐,此函数保证对齐到8
def align_up(value,alignment):
    return ((value + alignment - 1) // alignment) * alignment
def align_to_8(value):
    return (value // 8) * 8
def align_to_16(value):
    return (value // 16) * 16
# PipeLine类
class PipeLine:
    def __init__(self,rgb888p_size=[224,224],display_mode="hdmi",display_size=None,osd_layer_num=1,debug_mode=0):
        # sensor给AI的图像分辨率
        self.rgb888p_size=[align_to_16(rgb888p_size[0]),rgb888p_size[1]]
        #self.rgb888p_size=[ALIGN_UP(rgb888p_size[0],16),rgb888p_size[1]]
        # 视频输出VO图像分辨率
        if display_size is None:
            self.display_size=None
            self.display_size=[display_size[0],display_size[1]]
        # 视频显示模式,支持:"lcd"(default st7701 800*480),"hdmi"(default lt9611),"lt9611","st7701","hx8399"
        self.display_mode=display_mode
        # sensor对象
        self.sensor=None
        # osd显示Image对象
        self.osd_img=None
        self.cur_frame=None
        self.debug_mode=debug_mode
        self.osd_layer_num = osd_layer_num
    # PipeLine初始化函数
    def create(self,sensor=None,hmirror=None,vflip=None,fps=60):
        with ScopedTiming("init PipeLine",self.debug_mode > 0):
            nn.shrink_memory_pool()
            # 初始化并配置sensor
            brd=os.uname()[-1]
            if brd=="k230d_canmv_bpi_zero":
                self.sensor = Sensor(fps=30) if sensor is None else sensor
            elif brd=="k230_canmv_lckfb":
            elif brd=="k230d_canmv_atk_dnk230d":
                self.sensor = Sensor(fps=fps) if sensor is None else sensor
            self.sensor.reset()
            if hmirror is not None and (hmirror==True or hmirror==False):
                self.sensor.set_hmirror(hmirror)
            if vflip is not None and (vflip==True or vflip==False):
                self.sensor.set_vflip(vflip)
            # 初始化显示
            if self.display_mode=="hdmi":
                # 设置为LT9611显示,默认1920x1080
                if self.display_size==None:
                    Display.init(Display.LT9611,osd_num=self.osd_layer_num, to_ide = True)
                    Display.init(Display.LT9611, width=self.display_size[0], height=self.display_size[1],osd_num=self.osd_layer_num, to_ide = True)
            elif self.display_mode=="lcd":
                #改成NT35516(rtsmart ai套件板载的是NT35516)
                    Display.init(Display.NT35516,osd_num=self.osd_layer_num,to_ide =False)
                    Display.init(Display.NT35516, width=self.display_size[0], height=self.display_size[1],osd_num=self.osd_layer_num, to_ide = False)
                # 默认设置为ST7701显示,480x800
                #if self.display_size==None:
                #    Display.init(Display.ST7701, osd_num=self.osd_layer_num, to_ide=True)
                #else:
                #    Display.init(Display.ST7701, width=self.display_size[0], height=self.display_size[1], osd_num=self.osd_layer_num, to_ide=True)
            elif self.display_mode=="lt9611":
            elif self.display_mode=="st7701":
                # 设置为ST7701显示,480x800
            elif self.display_mode=="hx8399":
                # 设置为HX8399显示,默认1920x1080
                    Display.init(Display.HX8399, osd_num=self.osd_layer_num, to_ide=True)
                    Display.init(Display.HX8399, width=self.display_size[0], height=self.display_size[1], osd_num=self.osd_layer_num, to_ide=True)
            self.display_size=[Display.width(),Display.height()]
            # 通道0直接给到显示VO,格式为YUV420
                self.sensor.set_framesize(width = self.display_size[0], height = align_to_8(self.display_size[1]))
                self.sensor.set_pixformat(PIXEL_FORMAT_YUV_SEMIPLANAR_420)
                self.sensor.set_framesize(w = self.display_size[0], h = self.display_size[1])
            # 通道2给到AI做算法处理,格式为RGB888
            self.sensor.set_framesize(w = self.rgb888p_size[0], h = self.rgb888p_size[1], chn=CAM_CHN_ID_2)
            # set chn2 output format
            self.sensor.set_pixformat(PIXEL_FORMAT_RGB_888_PLANAR, chn=CAM_CHN_ID_2)
            # OSD图像初始化
            osd_width = self.display_size[0]
            osd_height = align_to_8(self.display_size[1])
            print(f"OSD图像尺寸: {osd_width}x{osd_height}, 高度是否8对齐: {osd_height%8==0}")
            self.osd_img = image.Image(osd_width, osd_height, image.ARGB8888)
            sensor_bind_info = self.sensor.bind_info(x = 0, y = 0, chn = CAM_CHN_ID_0)
            Display.bind_layer(**sensor_bind_info, dstlayer = Display.LAYER_VIDEO1)
            # media初始化
            # 启动sensor
            self.sensor.run()
    # 获取一帧图像数据,返回格式为ulab的array数据
    def get_frame(self):
        with ScopedTiming("get a frame",self.debug_mode > 0):
            self.cur_frame = self.sensor.snapshot(chn=CAM_CHN_ID_2)
            input_np=self.cur_frame.to_numpy_ref()
            return input_np
    # 在屏幕上显示osd_img
    def show_image(self):
        with ScopedTiming("show result",self.debug_mode > 0):
            Display.show_image(self.osd_img, 0, 0, Display.LAYER_OSD3)
    def get_display_size(self):
        return self.display_size
    # PipeLine销毁函数
    def destroy(self):
        with ScopedTiming("deinit PipeLine",self.debug_mode > 0):
            # stop sensor
            self.sensor.stop()
            # deinit lcd
            utime.sleep_ms(50)
            # deinit media buffer
你好,可以测试一下daily build的固件,pipeline这部分有改进
