AI Model on multiple camera
Viewed 125
I want to run Person Detection AI model on camera connected on CSI0, CSI1 & CSI2.
I followed triple camera example, but not getting success in running person detection model.
Run the code
Check stream output on canMV IDE
LCKFB
CanMV_K230_LCKFB_micropython_v1.4-0-g6cce59c_nncase_v2.9.0
import time, os, sys, ujson, gc, math
from libs.AI2D import Ai2d
import aicube
sensor0 = None
sensor1 = None
sensor2 = None
class PersonDetectionApp(AIBase):
    def __init__(self,kmodel_path,model_input_size,labels,anchors,confidence_threshold=0.2,nms_threshold=0.5,nms_option=False,strides=[8,16,32],rgb888p_size=[224,224],display_size=[1920,1080],debug_mode=0):
        self.kmodel_path=kmodel_path
        # 模型输入分辨率
        # 标签
        self.labels=labels
        # 检测anchors设置
        self.anchors=anchors
        # 特征图降采样倍数
        self.strides=strides
        # 置信度阈值设置
        # nms阈值设置
        self.nms_option=nms_option
        # sensor给到AI的图像分辨率
        # 显示分辨率
        self.debug_mode=debug_mode
        # Ai2d实例,用于实现模型预处理
        self.ai2d=Ai2d(debug_mode)
        # 设置Ai2d的输入输出格式和类型
            top,bottom,left,right,_=center_pad_param(self.rgb888p_size,self.model_input_size)
            self.ai2d.pad([0,0,0,0,top,bottom,left,right], 0, [0,0,0])
    # 自定义当前任务的后处理
            # 这里使用了aicube模型的后处理接口anchorbasedet_post_preocess
            dets = aicube.anchorbasedet_post_process(results[0], results[1], results[2], self.model_input_size, self.rgb888p_size, self.strides, len(self.labels), self.confidence_threshold, self.nms_threshold, self.anchors, self.nms_option)
            return dets
def draw_result(dets):
    global display_size, labels
    img = image.Image(display_size[0], display_size[1], image.ARGB8888)
    if dets:
        img.clear()
        for det_box in dets:
            x1, y1, x2, y2 = det_box[2],det_box[3],det_box[4],det_box[5]
            w = float(x2 - x1) * display_size[0] // rgb888p_size[0]
            h = float(y2 - y1) * display_size[1] // rgb888p_size[1]
            x1 = int(x1 * display_size[0] // rgb888p_size[0])
            y1 = int(y1 * display_size[1] // rgb888p_size[1])
            x2 = int(x2 * display_size[0] // rgb888p_size[0])
            y2 = int(y2 * display_size[1] // rgb888p_size[1])
            if (h<(0.1*display_size[0])):
            if (w<(0.25*display_size[0]) and ((x1<(0.03*display_size[0])) or (x2>(0.97*display_size[0])))):
            if (w<(0.15*display_size[0]) and ((x1<(0.01*display_size[0])) or (x2>(0.99*display_size[0])))):
            img.draw_rectangle(x1 , y1 , int(w) , int(h), color=(255, 0, 255, 0), thickness = 2)
            img.draw_string_advanced( x1 , y1-50,32, " " + labels[det_box[0]] + " " + str(round(det_box[1],2)), color=(255,0, 255, 0))
        img.clear()
    return img
    rgb888p_size = [1920, 1080]
    kmodel_path="/sdcard/examples/kmodel/person_detect_yolov5n.kmodel"
    confidence_threshold = 0.2
    nms_threshold = 0.6
    labels = ["person"]
    anchors = [10, 13, 16, 30, 33, 23, 30, 61, 62, 45, 59, 119, 116, 90, 156, 198, 373, 326]
    print("camera_test")
    # sensor0
    sensor0 = Sensor(id = 0, width = 1920, height = 1080, fps = 30)
    sensor0.reset()
    sensor0.set_framesize(width = 960, height = 540)
    sensor0.set_pixformat(Sensor.YUV420SP)
    sensor0.set_framesize(width = 1920, height = 1080, chn=CAM_CHN_ID_2)
    sensor0.set_pixformat(PIXEL_FORMAT_RGB_888_PLANAR, chn=CAM_CHN_ID_2)
    bind_info = sensor0.bind_info(x = 0, y = 0)
    # sensor1
    sensor1 = Sensor(id = 1, width = 1920, height = 1080, fps = 30)
    sensor1.reset()
    sensor1.set_framesize(width = 960, height = 540)
    sensor1.set_pixformat(Sensor.YUV420SP)
    bind_info = sensor1.bind_info(x = 960, y = 0)
    Display.bind_layer(**bind_info, layer = Display.LAYER_VIDEO2)
    # sensor2
    sensor2 = Sensor(id = 2, width = 1920, height = 1080, fps = 30)
    sensor2.reset()
    sensor2.set_framesize(width = 960, height = 540)
    sensor2.set_pixformat(Sensor.RGB888)
    display_size=[Display.width(),Display.height()]
    # multiple sensor only need one excute run()
    sensor0.run()
    person_det=PersonDetectionApp(kmodel_path,model_input_size=[640,640],labels=labels,anchors=anchors,confidence_threshold=confidence_threshold,nms_threshold=nms_threshold,nms_option=False,strides=[8,16,32],rgb888p_size=rgb888p_size,display_size=display_size,debug_mode=0)
    person_det.config_preprocess()
        cur_frame = sensor0.snapshot(chn=CAM_CHN_ID_2)
        res=person_det.run(cur_frame)
        osd_img = draw_result(res)
        img = sensor2.snapshot()
        Display.show_image(img, x = 0, y = 540)
    print("user stop: ", e)
    # multiple sensor all need excute stop()
    if sensor0 is not None:
        sensor0.stop()
    if sensor1 is not None:
        sensor1.stop()
    if sensor2 is not None:
        sensor2.stop()
    # or call Sensor.deinit()
    # Sensor.deinit()
    # deinit display
    # deinit media buffer
Could you please clarify your specific requirement? Do you need human detection running simultaneously on all three cameras, or is it sufficient to have three cameras activated but only running human detection on one of them?
