K230mpy利用UVC进行YOLO11推理卡死
Viewed 239
请问各位大佬有无UVC摄像头进行YOLO11推理的例程,我看了官方给出的UVC run yolo8例程,感觉看的不是太懂,于是自己按照yolo视频推理教程和UVCapi自己写了一个代码。但是问题有些多要么就运行了可以打印fps但是屏幕显示并且检测不到物体要么就是卡死,如果有大佬做光相关工作能否分享或者官方能否给一个UVC run YOLO11 demo ,感谢.
import time, os, urandom, sys, gc
from media.uvc import *
from nonai2d import CSC
from libs.YOLO import YOLO11
csc = CSC(0, CSC.PIXEL_FORMAT_RGB_888)
# use lcd as display output
Display.init(Display.ST7701,width = DISPLAY_WIDTH, height = DISPLAY_HEIGHT, to_ide = True)
# init media manager
    plugin, dev = UVC.probe()
    if plugin:
        print(f"detect USB Camera {dev}")
mode = UVC.video_mode(640, 480, UVC.FORMAT_MJPEG, 30)
succ, mode = UVC.select_video_mode(mode)
print(f"select mode success: {succ}, mode: {mode}")
UVC.start(cvt = True)
kmodel_path="/data/Brid1.kmodel"
labels = ["Brid"]
model_input_size=[640,640]
rgb888p_size=[640,480]
confidence_threshold = 0.5
nms_threshold=0.45
# 初始化YOLO11实例
yolo=YOLO11(task_type="detect",
            mode="video",
            kmodel_path=kmodel_path,
            labels=labels,
            rgb888p_size=rgb888p_size,
            model_input_size=model_input_size,
            display_size=[800,480],
            conf_thresh=confidence_threshold,
            nms_thresh=nms_threshold,
            max_boxes_num=50,
            debug_mode=0)
yolo.config_preprocess()
    img = None
    while img is None:
            img = UVC.snapshot()
        except:
            print("drop frame")
    img = csc.convert(img)
    # Convert to Ulab.Numpy.ndarray
    img_np_hwc = img.to_numpy_ref()
#    print(img_np_hwc.shape[0])
#    print(img_np_hwc.shape[1])
    img_np_nhwc=img_np_hwc.reshape((1,3,img_np_hwc.shape[0],img_np_hwc.shape[1]))
    # Run YOLOv11 inference on the current frame
    res = yolo.run(img_np_hwc)
    print(res)
    yolo.draw_result(res,img)
    img.__del__()
    print(f"fps: {clock.fps()}")
# deinit display
yolo.deinit()
csc.destroy()
UVC.stop()
# release media buffer
01studio mini
CanMV v1.4(based on Micropython e00a144) on 2025-09-08; k230_canmv_01studio with K230
你好,其实你只需要在示例代码上换一个模型、改一些参数就行就可以,YOLOv8和YOLO11的模型输出是一样的,后处理步骤也是一样的。
参考如下代码:
from libs.AI2D import Ai2d
import os,sys,ujson,gc,math, urandom
import aidemo
# Custom YOLO11 object detection class
    def __init__(self, kmodel_path, labels, model_input_size, max_boxes_num, confidence_threshold=0.5, nms_threshold=0.2, rgb888p_size=[224,224], display_size=[1920,1080], debug_mode=0):
        Initialize object detection system.
        Parameters:
        - kmodel_path: Path to YOLO11 KModel.
        - labels: List of class labels.
        - model_input_size: Model input size.
        - max_boxes_num: Max detection results to keep.
        - confidence_threshold: Detection score threshold.
        - nms_threshold: Non-max suppression threshold.
        - rgb888p_size: Camera input size (aligned to 16-width).
        - display_size: Output display size.
        - debug_mode: Enable debug timing logs.
        self.labels = labels
        self.confidence_threshold = confidence_threshold
        self.nms_threshold = nms_threshold
        self.max_boxes_num = max_boxes_num
        # Align width to multiple of 16 for hardware compatibility
        self.debug_mode = debug_mode
        # Predefined colors for each class
        self.color_four = get_colors(len(self.labels))
        # Input scaling factors
        self.x_factor = float(self.rgb888p_size[0]) / self.model_input_size[0]
        self.y_factor = float(self.rgb888p_size[1]) / self.model_input_size[1]
        # Ai2d instance for preprocessing
        self.ai2d = Ai2d(debug_mode)
        self.ai2d.set_ai2d_dtype(nn.ai2d_format.RGB_packed, nn.ai2d_format.NCHW_FMT, np.uint8, np.uint8)
        Configure pre-processing: padding and resizing using Ai2d.
            top, bottom, left, right, self.scale = letterbox_pad_param(self.rgb888p_size, self.model_input_size)
            self.ai2d.build(
                [1, ai2d_input_size[1], ai2d_input_size[0], 3],
                [1, 3, self.model_input_size[1], self.model_input_size[0]]
        Apply YOLOv8 post-processing including NMS and thresholding.
            new_result = results[0][0].transpose()
            det_res = aidemo.yolov8_det_postprocess(
                new_result.copy(),
                [self.rgb888p_size[1], self.rgb888p_size[0]],
                [self.model_input_size[1], self.model_input_size[0]],
                [self.display_size[1], self.display_size[0]],
                len(self.labels),
                self.confidence_threshold,
                self.nms_threshold,
                self.max_boxes_num
            return det_res
    def draw_result(self, img, dets):
        Draw detection results and send label info via UART.
            if dets:
                for i in range(len(dets[0])):
                    x, y, w, h = map(lambda x: int(round(x, 0)), dets[0][i])
                    img.draw_rectangle(x,y, w, h, color=self.color_four[dets[1][i]],thickness=4)
                    img.draw_string_advanced( x , y-50,32," " + self.labels[dets[1][i]] + " " + str(round(dets[2][i],2)) , color=self.color_four[dets[1][i]])
    # Align display width to 16 bytes for hardware requirement
    # Create CSC instance for pixel format conversion (e.g., to RGB888)
    # Initialize LCD display (ST7701) and enable IDE display
    # Initialize media manager to manage frame buffers and UVC stream
    # Wait for USB camera to be detected
        if plugin:
    # Select and configure UVC video mode: 640x480 @ 30 FPS, MJPEG format
    # Define input image from USB camera (sensor side)
    rgb888p_size = [640, 480]
    # Path to the YOLO11n kmodel
    kmodel_path = "/sdcard/examples/kmodel/fruit_det_yolo11n_320.kmodel"
    # COCO class labels used for detection
    labels = ["apple", "banana", "orange"]
    # Detection parameters
    confidence_threshold = 0.5  # Minimum confidence to accept a detection
    nms_threshold = 0.4         # Non-Maximum Suppression threshold
    max_boxes_num = 30          # Max boxes per frame after filtering
    # Initialize object detection application with YOLOv8 model
    ob_det = ObjectDetectionApp(
        kmodel_path,
        labels=labels,
        model_input_size=[320, 320],
        max_boxes_num=max_boxes_num,
        confidence_threshold=confidence_threshold,
        nms_threshold=nms_threshold,
        display_size=rgb888p_size,
        debug_mode=0
    # Configure Ai2d preprocessing (resize + letterbox pad)
    ob_det.config_preprocess()
    # Start UVC video stream with pixel format conversion enabled
    UVC.start(cvt=True)
    # Main loop: acquire frame, run inference, draw and display
        if img is not None:
            # Convert format (e.g., to RGB888)
            # Run YOLOv8 inference on the current frame
            res = ob_det.run(img_np_nhwc)
            # Draw detection results on the frame
            ob_det.draw_result(img, res)
            # Show result on display
            # Explicitly release image buffer
            img.__del__()
        # Print current frame rate
    # Clean up: stop display and media system
    ob_det.deinit()
    csc.destroy()
    UVC.stop()
