嘉立创 庐山派 K230 Linux SDK LCD屏幕无法显示,只有背光亮
Viewed 165
屏幕无任何显示,背光亮起,无异常报告。
硬件:嘉立创 庐山派 K230 + 3.1寸LCD屏幕扩展板 + 嘉立创调焦摄像头
固件:CanMV-K230_LCKFB_linux_v0.6.9_nncase_v2.10.0.img
复现:
1、上电启动开发板
2、将linux主机中的./output/k230_canmv_lckfb_defconfig/target/usr/bin/v4l2-drm拷贝到k230中。
3、执行v4l2-drm -d 1 -w 480 -h 800。
参考文档:https://www.kendryte.com/k230_linux/zh/dev/app_develop_guide/user_develop/k230_linux_demo_doc.html
按d的话可以正确保存图片,只是无法显示在屏幕上
还尝试了其他的方法显示屏幕,均以失败告终
v4l2-drm -d 1 -w 480 -h 800执行log如下
[root@canaan ~ ]#v4l2-drm -d 1 -w 480 -h 800
display_get_plane get yuv plane fourcc is 842094158 DRM_FORMAT_NV12 is 842094158
[display] Added plane prop 8:type
[display] Added plane prop 17:FB_ID
[display] Added plane prop 18:IN_FENCE_FD
[display] Added plane prop 20:CRTC_ID
[display] Added plane prop 13:CRTC_X
[display] Added plane prop 14:CRTC_Y
[display] Added plane prop 15:CRTC_W
[display] Added plane prop 16:CRTC_H
[display] Added plane prop 9:SRC_X
[display] Added plane prop 10:SRC_Y
[display] Added plane prop 11:SRC_W
[display] Added plane prop 12:SRC_H
[display] Added plane prop 30:IN_FORMATS
[v4l2-drm] /dev/video1 support format NV16
[v4l2-drm] /dev/video1 support format NV12
[v4l2-drm] /dev/video1 support format YUYV
[v4l2-drm] /dev/video1 support format BGR3
[v4l2-drm] /dev/video1 support format BG3P
[v4l2-drm] /dev/video1 support format P010
poll: 40.75, display: 40.75, [0]: 30.81,
庐山派k230
庐山派k230
庐山派k230
庐山派k230
庐山派k230
庐山派k230
庐山派k230
庐山派k230
庐山派k230
庐山派k230
庐山派k230
庐山派k230
庐山派k230
庐山派k230
庐山派k230
庐山派k230
检查下线连的是否正确,检查下线是否连接反了。
补充下 v4l2-drm -d 1 -w 480 -h 800 命令的 执行log,
已经补充了老师
