i2c无法使用
Viewed 72
我在庐山派上i2c都正常使用,在canmv_v3上i2c连地址都读不到,模块有上拉,用stc32g12k128也能读,但是用v3就是读不到
这是i2c的输出
[root@canaan /sharefs/execfile ]#dmesg | grep i2c
[ 2.764362] i2c /dev entries driver
[ 2.768338] i2c_designware 91405000.i2c: GPIO lookup for consumer scl
[ 2.774851] i2c_designware 91405000.i2c: using device tree for GPIO lookup
[ 2.781773] of_get_named_gpiod_flags: can't parse 'scl-gpios' property of node '/soc/i2c@91405000[0]'
[ 2.791033] of_get_named_gpiod_flags: can't parse 'scl-gpio' property of node '/soc/i2c@91405000[0]'
[ 2.800186] i2c_designware 91405000.i2c: using lookup tables for GPIO lookup
[ 2.807257] i2c_designware 91405000.i2c: No GPIO consumer scl found
[ 2.814373] i2c_designware 91406000.i2c: GPIO lookup for consumer scl
[ 2.820900] i2c_designware 91406000.i2c: using device tree for GPIO lookup
[ 2.827822] of_get_named_gpiod_flags: can't parse 'scl-gpios' property of node '/soc/i2c@91406000[0]'
[ 2.837083] of_get_named_gpiod_flags: can't parse 'scl-gpio' property of node '/soc/i2c@91406000[0]'
[ 2.846248] i2c_designware 91406000.i2c: using lookup tables for GPIO lookup
[ 2.853318] i2c_designware 91406000.i2c: No GPIO consumer scl found
[ 2.860657] i2c_designware 91407000.i2c: GPIO lookup for consumer scl
[ 2.867149] i2c_designware 91407000.i2c: using device tree for GPIO lookup
[ 2.874081] of_get_named_gpiod_flags: can't parse 'scl-gpios' property of node '/soc/i2c@91407000[0]'
[ 2.883336] of_get_named_gpiod_flags: can't parse 'scl-gpio' property of node '/soc/i2c@91407000[0]'
[ 2.892495] i2c_designware 91407000.i2c: using lookup tables for GPIO lookup
[ 2.899561] i2c_designware 91407000.i2c: No GPIO consumer scl found
[ 2.906725] i2c_designware 91408000.i2c: GPIO lookup for consumer scl
[ 2.913238] i2c_designware 91408000.i2c: using device tree for GPIO lookup
[ 2.920162] of_get_named_gpiod_flags: can't parse 'scl-gpios' property of node '/soc/i2c@91408000[0]'
[ 2.929427] of_get_named_gpiod_flags: can't parse 'scl-gpio' property of node '/soc/i2c@91408000[0]'
[ 2.938586] i2c_designware 91408000.i2c: using lookup tables for GPIO lookup
[ 2.945652] i2c_designware 91408000.i2c: No GPIO consumer scl found
这是设备树:
/* Copyright (c) 2023, Canaan Bright Sight Co., Ltd
  • Redistribution and use in source and binary forms, with or without
  • modification, are permitted provided that the following conditions are met:
    1. Redistributions of source code must retain the above copyright
  • notice, this list of conditions and the following disclaimer.
    1. Redistributions in binary form must reproduce the above copyright
  • notice, this list of conditions and the following disclaimer in the
  • documentation and/or other materials provided with the distribution.
  • THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
  • CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES,
  • INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
  • MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  • DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
  • CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
  • SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
  • BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  • SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
  • INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
  • WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
  • NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  • OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    /dts-v1/;
    #include <dt-bindings/pinctrl/k230_evb.h>
#define BANK_VOLTAGE_IO0_IO1 K230_MSC_1V8 // FIXED
#define BANK_VOLTAGE_IO2_IO13 K230_MSC_3V3
#define BANK_VOLTAGE_IO14_IO25 K230_MSC_3V3
#define BANK_VOLTAGE_IO26_IO37 K230_MSC_3V3
#define BANK_VOLTAGE_IO38_IO49 K230_MSC_3V3
#define BANK_VOLTAGE_IO50_IO61 K230_MSC_3V3
#define BANK_VOLTAGE_IO62_IO63 K230_MSC_3V3
#include "k230.dtsi"
model = "kendryte k230 canmv v2";
compatible = "kendryte,k230_canmv_v2";
memory@0 {
	device_type = "memory";
	reg = <
			0x0 0 0x0 0x20000000
&mmc0 {
status = "okay";
&mmc1 {
status = "okay";
&usbotg1 {
status = "okay";
&iomux {
pinctrl-names = "default";
pinctrl-0 = <&pins>;
// Please pay attention to the bank voltage! will damage the chip.
pins: iomux_pins {
u-boot,dm-pre-reloc;
pinctrl-single,pins = <
	// boot
	(IO0 ) ( 1<<SEL | 0<<SL | BANK_VOLTAGE_IO0_IO1 <<MSC | 0<<IE | 1<<OE | 1<<PU | 0<<PD | 2<<DS | 0<<ST )
	// boot1
	(IO1 ) ( 1<<SEL | 0<<SL | BANK_VOLTAGE_IO0_IO1 <<MSC | 0<<IE | 1<<OE | 1<<PU | 0<<PD | 2<<DS | 0<<ST )
	// JP1-PIN11 JTAG
	(IO2 ) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO2_IO13 <<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
	// JP1-PIN18
	(IO3 ) ( 3<<SEL | 0<<SL | BANK_VOLTAGE_IO2_IO13 <<MSC | 0<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
	// JP1-PIN11
	(IO4 ) ( 3<<SEL | 0<<SL | BANK_VOLTAGE_IO2_IO13 <<MSC | 1<<IE | 0<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
	// JP1-PIN17
	(IO5 ) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO2_IO13 <<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
	// JP1-PIN20
	(IO6 ) ( 1<<SEL | 0<<SL | BANK_VOLTAGE_IO2_IO13 <<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 4<<DS | 0<<ST )
	// iic4
	(IO7 ) ( 2<<SEL | 0<<SL | BANK_VOLTAGE_IO2_IO13 <<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
	(IO8 ) ( 2<<SEL | 0<<SL | BANK_VOLTAGE_IO2_IO13 <<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
	// gpio_csi0
	(IO9 ) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO2_IO13 <<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
	(IO10) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO2_IO13 <<MSC | 1<<IE | 0<<OE | 0<<PU | 0<<PD | 8<<DS | 1<<ST )
    // gpio _csi1
	(IO11) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO2_IO13 <<MSC | 0<<IE | 1<<OE | 0<<PU | 0<<PD | 8<<DS | 1<<ST )
	(IO12) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO2_IO13 <<MSC | 0<<IE | 1<<OE | 0<<PU | 0<<PD | 8<<DS | 1<<ST )
	// RGB_MCLK -> OV5647
	(IO13) ( 1<<SEL | 0<<SL | BANK_VOLTAGE_IO2_IO13 <<MSC | 1<<IE | 1<<OE | 0<<PU | 1<<PD | 4<<DS | 1<<ST )
	// ext jp
	(IO14) ( 3<<SEL | 0<<SL | BANK_VOLTAGE_IO14_IO25<<MSC | 0<<IE | 1<<OE | 1<<PU | 0<<PD | 15<<DS | 1<<ST )
	(IO15) ( 3<<SEL | 0<<SL | BANK_VOLTAGE_IO14_IO25<<MSC | 0<<IE | 1<<OE | 0<<PU | 0<<PD | 15<<DS | 1<<ST )
	(IO16) ( 3<<SEL | 0<<SL | BANK_VOLTAGE_IO14_IO25<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 15<<DS | 1<<ST )
	(IO17) ( 3<<SEL | 0<<SL | BANK_VOLTAGE_IO14_IO25<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 15<<DS | 1<<ST )
	(IO18) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO14_IO25<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 15<<DS | 1<<ST )
	(IO19) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO14_IO25<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 15<<DS | 1<<ST )
	(IO20) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO14_IO25<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 15<<DS | 1<<ST )
	// cam2 rst,gpio
	(IO21) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO14_IO25<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 15<<DS | 1<<ST )
	// lcd_rst
	(IO22) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO14_IO25<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 15<<DS | 1<<ST )
	// hdmi_int,gpio
	(IO23) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO14_IO25<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 15<<DS | 1<<ST )
	// hdmi_rset ,gpio
	(IO24) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO14_IO25<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 15<<DS | 1<<ST )
	// LCD_EN
	(IO25) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO14_IO25<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
	// 26-35 ext jp
	(IO26) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO26_IO37<<MSC | 0<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
	(IO27) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO26_IO37<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
	(IO28) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO26_IO37<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
	(IO29) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO26_IO37<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
	(IO30) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO26_IO37<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
	(IO31) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO26_IO37<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
	//i2c1和i2c0
	(IO32) ( 1<<SEL | 0<<SL | BANK_VOLTAGE_IO26_IO37<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
	(IO33) ( 1<<SEL | 0<<SL | BANK_VOLTAGE_IO26_IO37<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
	(IO34) ( 1<<SEL | 0<<SL | BANK_VOLTAGE_IO26_IO37<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
	(IO35) ( 1<<SEL | 0<<SL | BANK_VOLTAGE_IO26_IO37<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
	// i2c3
	(IO36) ( 1<<SEL | 0<<SL | BANK_VOLTAGE_IO26_IO37<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
	// BT_UART_TXD
	(IO37) ( 1<<SEL | 0<<SL | BANK_VOLTAGE_IO26_IO37<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
	// UART0_TXD
	(IO38) ( 1<<SEL | 0<<SL | BANK_VOLTAGE_IO38_IO49<<MSC | 0<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
	// UART0_RXD
	(IO39) ( 1<<SEL | 0<<SL | BANK_VOLTAGE_IO38_IO49<<MSC | 1<<IE | 0<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
	// I2C1_SCL -> camera
	(IO40) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO38_IO49<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
	// I2C1_SDA -> camera
	(IO41) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO38_IO49<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
	// 42-47 ext jp
	(IO42) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO38_IO49<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
	(IO43) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO38_IO49<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
	(IO44) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO38_IO49<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
	(IO45) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO38_IO49<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
	(IO46) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO38_IO49<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
	(IO47) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO38_IO49<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
	//iic0
	(IO48) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO38_IO49<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
	(IO49) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO38_IO49<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
	// UART3_TXD
	(IO50) ( 1<<SEL | 0<<SL | BANK_VOLTAGE_IO50_IO61<<MSC | 0<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
	// UART3_RXD
	(IO51) ( 1<<SEL | 0<<SL | BANK_VOLTAGE_IO50_IO61<<MSC | 1<<IE | 0<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
	// ext jp
	(IO52) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO50_IO61<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
	// ext jp
	(IO53) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO50_IO61<<MSC | 1<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
	// MMC1 -> TFCARD
	(IO54) ( 2<<SEL | 0<<SL | BANK_VOLTAGE_IO50_IO61<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
	(IO55) ( 2<<SEL | 0<<SL | BANK_VOLTAGE_IO50_IO61<<MSC | 0<<IE | 1<<OE | 0<<PU | 0<<PD | 7<<DS | 1<<ST )
	(IO56) ( 2<<SEL | 0<<SL | BANK_VOLTAGE_IO50_IO61<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
	(IO57) ( 2<<SEL | 0<<SL | BANK_VOLTAGE_IO50_IO61<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
	(IO58) ( 2<<SEL | 0<<SL | BANK_VOLTAGE_IO50_IO61<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
	(IO59) ( 2<<SEL | 0<<SL | BANK_VOLTAGE_IO50_IO61<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
	//gpio_csi1
	(IO60) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO50_IO61<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
	//gpio_csi0
	(IO61) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO50_IO61<<MSC | 1<<IE | 1<<OE | 1<<PU | 0<<PD | 7<<DS | 1<<ST )
	// ext jp
	(IO62) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO62_IO63<<MSC | 1<<IE | 1<<OE | 0<<PU | 1<<PD | 4<<DS | 1<<ST )
	(IO63) ( 0<<SEL | 0<<SL | BANK_VOLTAGE_IO62_IO63<<MSC | 1<<IE | 1<<OE | 0<<PU | 1<<PD | 4<<DS | 1<<ST )
k230_canmv_v3
sdk
用的那套sdk? 双系统sdk吗?
是的,双系统
