Can the K230 SDIO interface function in slave mode?
Viewed 36
the K230 Technical reference manual lists under
12.4 eMMC/SD/SDIO Controller
12.4.1.2 Features
  • Supports Slave-Only mode as a configuration option for better area and power efficiency
Does that mean that the K230 can act as an SDIO slave device and is there driver support for this?
K230D
Currently our driver can not support sdio serve as slave.
Also not supported.
Thank you for your reply!
And what about QSPI slave?
